dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb2 (root@wbdevenv) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #2 Tue Oct 2 14:35:02 UTC 2018
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] OF: fdt:Machine model: Wiren Board rev. 5.8 (i.MX28)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat c069cc34, node_mem_map c7efb000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyAMA0,115200 ro rootwait fixrtc root=/dev/mmcblk0p2 rootfstype=ext4 video=
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 122700K/131072K available (4569K kernel code, 204K rwdata, 1664K rodata, 160K init, 286K bss, 8372K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff800000 ( 880 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc047e9b0 (4571 kB)
[ 0.000000] .init : 0xc0642000 - 0xc066a000 ( 160 kB)
[ 0.000000] .data : 0xc066a000 - 0xc069d2c0 ( 205 kB)
[ 0.000000] .bss : 0xc069d2c0 - 0xc06e4e70 ( 287 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource: mxs_timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000021] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000688] Console: colour dummy device 80x30
[ 0.000752] Calibrating delay loop… 226.09 BogoMIPS (lpj=1130496)
[ 0.080303] pid_max: default: 32768 minimum: 301
[ 0.080571] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.080615] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.082196] CPU: Testing write buffer coherency: ok
[ 0.083007] Setting up static identity map for 0x40008400 - 0x40008458
[ 0.086691] devtmpfs: initialized
[ 0.117264] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.117339] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.117698] pinctrl core: initialized pinctrl subsystem
[ 0.120349] NET: Registered protocol family 16
[ 0.121843] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.192671] Serial: AMBA PL011 UART driver
[ 0.193547] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 234, base_baud = 0) is a PL011 rev2
[ 0.456418] console [ttyAMA0] enabled
[ 0.483869] mxs-dma 80004000.dma-apbh: initialized
[ 0.493952] mxs-dma 80024000.dma-apbx: initialized
[ 0.503719] usbcore: registered new interface driver usbfs
[ 0.509562] usbcore: registered new interface driver hub
[ 0.515148] usbcore: registered new device driver usb
[ 0.521816] i2c-gpio i2c_rtc_wb59@0: using pins 85 (SDA) and 90 (SCL)
[ 0.530067] Linux video capture interface: v2.00
[ 0.535033] pps_core: LinuxPPS API ver. 1 registered
[ 0.540024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.549320] PTP clock support registered
[ 0.554137] Advanced Linux Sound Architecture Driver Initialized.
[ 0.562642] clocksource: Switched to clocksource mxs_timer
[ 0.604932] NET: Registered protocol family 2
[ 0.610894] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.618043] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.624520] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.631073] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.637047] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.643764] NET: Registered protocol family 1
[ 0.649058] RPC: Registered named UNIX socket transport module.
[ 0.655126] RPC: Registered udp transport module.
[ 0.659854] RPC: Registered tcp transport module.
[ 0.664643] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.671610] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.681198] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.734284] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.741719] io scheduler noop registered (default)
[ 0.750673] 8006a000.serial: ttyAPP0 at MMIO 0x8006a000 (irq = 229, base_baud = 1500000) is a 8006a000.serial
[ 0.761684] mxs-auart 8006a000.serial: Found APPUART 3.1.0
[ 0.768053] 8006c000.serial: ttyAPP1 at MMIO 0x8006c000 (irq = 230, base_baud = 1500000) is a 8006c000.serial
[ 0.779078] mxs-auart 8006c000.serial: Found APPUART 3.1.0
[ 0.785477] 8006e000.serial: ttyAPP2 at MMIO 0x8006e000 (irq = 231, base_baud = 1500000) is a 8006e000.serial
[ 0.796545] mxs-auart 8006e000.serial: Found APPUART 3.1.0
[ 0.802892] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 232, base_baud = 1500000) is a 80070000.serial
[ 0.813872] mxs-auart 80070000.serial: Found APPUART 3.1.0
[ 0.820090] 80072000.serial: ttyAPP4 at MMIO 0x80072000 (irq = 233, base_baud = 1500000) is a 80072000.serial
[ 0.831128] mxs-auart 80072000.serial: Found APPUART 3.1.0
[ 0.857415] loop: module loaded
[ 0.863364] libphy: Fixed MDIO Bus: probed
[ 0.982822] 800f0000.ethernet supply phy not found, using dummy regulator
[ 1.104070] libphy: fec_enet_mii_bus: probed
[ 1.113907] 800f4000.ethernet supply phy not found, using dummy regulator
[ 1.124001] PPP generic driver version 2.4.2
[ 1.128917] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.136016] usbcore: registered new interface driver usbserial
[ 1.142019] usbcore: registered new interface driver usbserial_generic
[ 1.148829] usbserial: USB Serial support registered for generic
[ 1.155642] mousedev: PS/2 mouse device common for all mice
[ 2.032696] rtc-pcf8563 1-0051: pcf8563_write_block_data: err=-6 addr=0e, data=03
[ 2.040215] rtc-pcf8563 1-0051: pcf8563_probe: write error
[ 2.045876] rtc-pcf8563: probe of 1-0051 failed with error -5
[ 2.055863] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as rtc0
[ 2.064014] i2c /dev entries driver
[ 2.069893] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with heartbeat 19s
[ 2.080293] 80010000.ssp supply vmmc not found, using dummy regulator
[ 2.142762] mxs-mmc 80010000.ssp: initialized
[ 2.149145] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.161195] usbcore: registered new interface driver usbhid
[ 2.166921] usbhid: USB HID core driver
[ 2.188051] NET: Registered protocol family 10
[ 2.195676] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.204508] NET: Registered protocol family 17
[ 2.209188] Key type dns_resolver registered
[ 2.216225] registered taskstats version 1
[ 2.227863] stmp3xxx-rtc 80056000.rtc: setting system clock to 1970-01-01 00:00:07 UTC (7)
[ 2.236245] of_cfs_init
[ 2.238886] of_cfs_init: OK
[ 2.242845] usb0_vbus: disabling
[ 2.246111] usb1_vbus: disabling
[ 2.249351] ALSA device list:
[ 2.252325] No soundcards found.
[ 2.256198] uart-pl011 80074000.serial: no DMA platform data
[ 2.262055] Waiting for root device /dev/mmcblk0p2…
[ 2.745645] mmc0: new high speed MMC card at address 0001
[ 2.752753] mmcblk0: mmc0:0001 SEM04G 3.69 GiB
[ 2.758033] mmcblk0boot0: mmc0:0001 SEM04G partition 1 1.00 MiB
[ 2.764820] mmcblk0boot1: mmc0:0001 SEM04G partition 2 1.00 MiB
[ 2.771442] mmcblk0rpmb: mmc0:0001 SEM04G partition 3 128 KiB
[ 2.783061] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.852707] random: fast init done
[ 2.865751] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.873201] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.955950] EXT4-fs (mmcblk0p2): recovery complete
[ 2.964095] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.972312] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.988459] devtmpfs: mounted
[ 2.992255] Freeing unused kernel memory: 160K (c0642000 - c066a000)
[ 2.998733] This architecture does not have kernel memory protection.
[ 5.031645] udevd[183]: starting version 175
[ 6.585654] mxs-dcp 80028000.dcp: Failed to register sha1 hash!
[ 6.595186] CAN device driver interface
[ 6.638105] mxs-dcp: probe of 80028000.dcp failed with error -22
[ 6.682278] 80034000.can supply xceiver not found, using dummy regulator
[ 6.803051] flexcan 80034000.can: device registered (reg_base=c892c000, irq=209)
[ 6.982483] mxs-spdif-dai 80054000.spdif: MXS SPDIF Audio Transmitter
[ 8.336647] Driver for 1-wire Dallas network protocol.
[ 8.377021] lirc_dev: IR Remote Control driver registered, major 245
[ 8.409167] mxs-spdif sound-spdif: snd-soc-dummy-dai <-> 80054000.spdif mapping ok
[ 8.534190] lirc_pwm: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.645629] lirc_pwm lirc-rfm69: GPIO receiver on pin 37
[ 8.793831] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 8.798807] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 8.823465] lirc_pwm lirc-rfm69: lirc_dev: driver lirc-rfm69 registered at minor = 0
[ 9.034267] lirc_pwm lirc-rfm69: probed
[ 9.152989] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 9.246232] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.253194] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.260446] usb usb1: Product: EHCI Host Controller
[ 9.265430] usb usb1: Manufacturer: Linux 4.9.22-wb2 ehci_hcd
[ 9.271206] usb usb1: SerialNumber: ci_hdrc.0
[ 9.531716] hub 1-0:1.0: USB hub found
[ 9.562956] hub 1-0:1.0: 1 port detected
[ 9.624008] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 9.629024] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 9.752986] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 9.793318] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.800159] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.807529] usb usb2: Product: EHCI Host Controller
[ 9.812440] usb usb2: Manufacturer: Linux 4.9.22-wb2 ehci_hcd
[ 9.818315] usb usb2: SerialNumber: ci_hdrc.1
[ 10.038866] hub 2-0:1.0: USB hub found
[ 10.062821] hub 2-0:1.0: 1 port detected
[ 10.472850] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 10.695351] usb 2-1: New USB device found, idVendor=0bda, idProduct=b720
[ 10.702162] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 10.709476] usb 2-1: Product: 802.11n WLAN Adapter
[ 10.714398] usb 2-1: Manufacturer: Realtek
[ 10.718525] usb 2-1: SerialNumber: 00e04c000001
[ 11.275541] Bluetooth: Core ver 2.22
[ 11.300211] NET: Registered protocol family 31
[ 11.304817] Bluetooth: HCI device and connection manager initialized
[ 11.332062] Bluetooth: HCI socket layer initialized
[ 11.356300] Bluetooth: L2CAP socket layer initialized
[ 11.402951] Bluetooth: SCO socket layer initialized
[ 11.517408] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 11.526231] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 11.539250] usbcore: registered new interface driver btusb
[ 11.545171] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 11.554463] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 11.561019] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 11.581360] Bluetooth: hci0: rom_version status=0 version=1
[ 11.587478] Bluetooth: cfg_sz 0, total size 22496
[ 12.856383] 8723bu: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.952803] RTL871X: module init start
[ 12.956602] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 12.963702] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 13.314644] RTL871X: rtw_ndev_init(wlan0)
[ 13.325681] RTL871X: rtw_ndev_init(wlan1)
[ 13.340204] usbcore: registered new interface driver rtl8723bu
[ 13.346202] RTL871X: module init ret=0
[ 19.458169] Adding 262140k swap on /dev/mmcblk0p5. Priority:-1 extents:1 across:262140k SS
[ 19.729281] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 20.399777] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 32.525632] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: errors=remount-ro
[ 46.685710] i2c-gpio mod1_i2c@0: using pins 91 (SDA) and 125 (SCL)
[ 48.317506] OF: changeset: add_property failed @/symbols/mcp4728
[ 48.324026] OF: Error applying changeset (-17)
[ 48.348537] create_overlay: Failed to create overlay (err=-17)
[ 65.748610] random: crng init done
[ 66.008183] RTL871X: RTW_ADAPTIVITY_EN_
[ 66.011887] AUTO, chplan:0x20, Regulation:3,3
[ 66.016390] RTL871X: RTW_ADAPTIVITY_MODE_
[ 66.020246] NORMAL
[ 66.652852] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 66.933524] SMSC LAN8710/LAN8720 800f0000.etherne:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.etherne:00, irq=-1)
[ 66.963960] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 68.687088] RTL871X: nolinked power save enter
[ 69.087864] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 69.101349] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 78.162095] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 78.167580] Bluetooth: BNEP filters: protocol multicast
[ 78.200407] Bluetooth: RFCOMM TTY layer initialized
[ 78.205572] Bluetooth: BNEP socket layer initialized
[ 78.215572] Bluetooth: RFCOMM socket layer initialized
[ 78.236444] Bluetooth: RFCOMM ver 1.11
[ 79.911886] RTL871X: RTW_ADAPTIVITY_EN_
[ 79.915751] AUTO, chplan:0x20, Regulation:3,3
[ 79.920140] RTL871X: RTW_ADAPTIVITY_MODE_
[ 79.924139] NORMAL
[ 80.813198] RTL871X: nolinked power save leave
[ 81.576322] RTL871X: assoc success
[ 81.580020] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 82.033491] SMSC LAN8710/LAN8720 800f0000.etherne:01: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.etherne:01, irq=-1)
[ 82.097498] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 126.680155] tun: Universal TUN/TAP device driver, 1.6
[ 126.685413] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[164755.413052] i2c-gpio mod1_i2c@0: using pins 91 (SDA) and 125 (SCL)
[164758.638597] OF: changeset: add_property failed @/symbols/mcp4728
[164758.645229] OF: Error applying changeset (-17)
[164758.652003] create_overlay: Failed to create overlay (err=-17)
[164776.964597] OF: changeset: add_property failed @/symbols/mcp4728
[164776.971381] OF: Error applying changeset (-17)
[164777.009156] create_overlay: Failed to create overlay (err=-17)
[451368.391677] RTL871X: sta recv deauth reason code(3) sta:00:00:00:00:00:00, ignore = 0
[452129.602429] RTL871X: sta recv deauth reason code(3) sta:00:00:00:00:00:00, ignore = 0
[452233.983293] RTL871X: sta recv deauth reason code(3) sta:00:00:00:00:00:00, ignore = 0
[452549.601916] RTL871X: sta recv deauth reason code(3) sta:00:00:00:00:00:00, ignore = 0
