Не загружается wb 3.5
Проблема: Устройство первый раз загрузилось, но при выключении и включении перестало загружаться и показывает в логах по сериал цикл из
HTLCmxs_power_init(): mxs_power_init
mxs_power_set_auto_restart(): mxs_power_set_auto_restart
mxs_power_set_linreg(): mxs_power_set_linreg
mxs_power_configure_power_source(): mxs_power_configure_power_source
mxs_get_batt_volt(): mxs_get_batt_volt volt=4192 mV
mxs_power_configure_power_source(): /* 5V source detected, good battery detected        . */
mxs_5v_boot(): mxs_5v_boot
mxs_boot_valid_5v(): mxs_boot_valid_5v
mxs_power_enable_4p2(): mxs_power_enable_4p2
mxs_power_init_4p2_params(): mxs_power_init_4p2_params
mxs_power_init_4p2_regulator(): mxs_power_init_4p2_regulator
mxs_enable_4p2_dcdc_input(): mxs_enable_4p2_dcdc_input
mxs_power_init_dcdc_4p2_source(): mxs_power_init_dcdc_4p2_source
mxs_init_batt_bo(): mxs_init_batt_bo
mxs_switch_vddd_to_dcdc_source(): mxs_switch_vddd_to_dcdc_source
mxs_enable_output_rail_protection(): mxs_enable_output_rail_protection
mxs_power_set_vddx(): mxs_power_set_vddx
mxs_get_vddio_power_source_off(): mxs_get_vddio_power_source_off
mxs_get_vddd_power_source_off(): mxs_get_vddd_power_source_off
mxs_mem_init(): before_init_clock
mxs_mem_init_clock
mxs_mem_init(): after_init_clock
mxs_mem_init(): after_vdda_clock
mx23_mem_init(): DDR frequency is 133 MHz
mx23_mem_init(): EN_LOWPOWER_MODE is on
mx23_mem_init(): DDR CAS latency=2.5
mx23_mem_init(): before vddmem
mx23_mem_setup_vddmem(): before VDDM current limit
mx23_mem_setup_vddmem(): VDDM current limit disabled
mx23_mem_init(): after vddmem
initialize_dram_values
mxs_mem_init(): after_mem_init
LC
U-Boot 2014.07-00012-gef75de6-dirty (Apr 25 2015 - 17:12:29)
CPU:   Freescale i.MX23 rev1.4 at 454 MHz
BOOT:  SSP SD/MMC #0
DRAM:  64 MiB
MMC:   MXS MMC: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
43 bytes read in 230 ms (0 Bytes/s)
Importing environment from mmc (uEnv.txt)...
Checking if uenvcmd is set ...
Running default loadzimage ...
3435640 bytes read in 1515 ms (2.2 MiB/s)
12846 bytes read in 481 ms (25.4 KiB/s)
Booting from mmc ...
Kernel image @ 0x42000000 [ 0x000000 - 0x346c78 ]
## Flattened Device Tree blob at 41000000
   Booting using the fdt blob at 0x41000000
   Loading Device Tree to 43b60000, end 43b6622d ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.19.0-imxv5-x0.1 (root@boger-laptop) (gcc version        4.7.4 (Ubuntu/Linaro 4.7.4-2ubuntu1) ) #481 Mon Nov 23 23:09:11 MSK 2015
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] Machine model: Wiren Board rev. 3.2 (i.MX23)
[    0.000000] Memory policy: Data cache writeback
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag        es: 16256
[    0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/mmcblk0p2 r        o rootfstype=ext4 rootwait fixrtc video=
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 58624K/65536K available (4133K kernel code, 214K rwdata,        1444K rodata, 156K init, 267K bss, 6912K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc4800000 - 0xff000000   ( 936 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc057a8b0   (5579 kB)
[    0.000000]       .init : 0xc057b000 - 0xc05a2000   ( 156 kB)
[    0.000000]       .data : 0xc05a2000 - 0xc05d7ac0   ( 215 kB)
[    0.000000]        .bss : 0xc05d7ac0 - 0xc061a7e0   ( 268 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps ever        y 21474836480000000ns
[    0.000000] Console: colour dummy device 80x30
[    0.070000] Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.080000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.080000] CPU: Testing write buffer coherency: ok
[    0.080000] Setting up static identity map for 0x403eabd8 - 0x403eac30
[    0.080000] devtmpfs: initialized
[    0.080000] pinctrl core: initialized pinctrl subsystem
[    0.100000] NET: Registered protocol family 16
[    0.100000] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.130000] Serial: AMBA PL011 UART driver
[    0.130000] 80070000.serial: ttyAMA0 at MMIO 0x80070000 (irq = 18, base_baud        = 0) is a PL011 rev2
[    0.270000] console [ttyAMA0] enabled
[    0.300000] mxs-dma 80004000.dma-apbh: initialized
[    0.310000] mxs-dma 80024000.dma-apbx: initialized
[    0.320000] usbcore: registered new interface driver usbfs
[    0.320000] usbcore: registered new interface driver hub
[    0.330000] usbcore: registered new device driver usb
[    0.330000] Linux video capture interface: v2.00
[    0.340000] pps_core: LinuxPPS API ver. 1 registered
[    0.340000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
[    0.350000] PTP clock support registered
[    0.350000] Advanced Linux Sound Architecture Driver Initialized.
[    0.360000] Switched to clocksource mxs_timer
[    0.400000] NET: Registered protocol family 2
[    0.410000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.420000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.420000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.430000] TCP: reno registered
[    0.430000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.440000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.450000] NET: Registered protocol family 1
[    0.450000] RPC: Registered named UNIX socket transport module.
[    0.460000] RPC: Registered udp transport module.
[    0.460000] RPC: Registered tcp transport module.
[    0.470000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.480000] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.490000] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.530000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        48)
[    0.540000] io scheduler noop registered (default)
[    0.550000] of_dma_request_slave_channel: dma-names property of node '/apb@80        000000/apbx@80040000/serial@80070000' missing or empty
[    0.560000] uart-pl011 80070000.serial: no DMA platform data
[    0.570000] 8006c000.serial: ttyAPP0 at MMIO 0x8006c000 (irq = 146, base_baud        = 1500000) is a 8006c000.serial
[    0.580000] mxs-auart 8006c000.serial: Found APPUART 3.0.0
[    0.600000] loop: module loaded
[    0.610000] mxs-spi 80034000.ssp: cs-gpios count: 5
[    0.610000] spi_master spi1: will run message pump with realtime priority
[    0.620000] spi spi1.3: gpio index 0, gpio_cs 3
[    0.630000] sc16is7x2 spi1.3: probe start
[    0.630000] sc16is7x2 spi1.3: gpio-base=120
[    0.640000] sc16is7x2 spi1.3: uartclk=14745600
[    0.640000] sc16is7x2 spi1.3: uart_base=0
[    0.640000] irq: 41
[    0.650000] irq: 41
[    0.650000] sc16is7x2 spi1.3: sc16is7x2 at CS3 (irq 41), 2 UARTs, 8 GPIOs
[    0.650000]     ttyNSC0, ttyNSC1, gpiochip120
[    0.660000] spi spi1.4: gpio index 1, gpio_cs 91
[    0.670000] spi spi1.5: gpio index 2, gpio_cs 51
[    0.680000] spi spi1.6: gpio index 3, gpio_cs 35
[    0.680000] spi spi1.7: gpio index 4, gpio_cs 38
[    0.690000] PPP generic driver version 2.4.2
[    0.700000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.700000] usbcore: registered new interface driver usbserial
[    0.710000] usbcore: registered new interface driver usbserial_generic
[    0.720000] usbserial: USB Serial support registered for generic
[    0.720000] mousedev: PS/2 mouse device common for all mice
[    0.730000] stmp3xxx-rtc 8005c000.rtc: rtc core: registered 8005c000.rtc as r        tc0
[    0.740000] i2c /dev entries driver
[    0.750000] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with hear        tbeat 19s
[    0.760000] Driver 'mmcblk' needs updating - please use bus_type methods
[    0.770000] 80010000.ssp supply vmmc not found, using dummy regulator
[    0.810000] mxs-mmc 80010000.ssp: initialized
[    0.810000] imx23-pinctrl 80018000.pinctrl: pin SSP1_DETECT already requested        by 80018000.pinctrl; cannot claim for leds
[    0.820000] imx23-pinctrl 80018000.pinctrl: pin-65 (leds) status -22
[    0.830000] imx23-pinctrl 80018000.pinctrl: could not request pin 65 (SSP1_DE        TECT) from group led_gpio2_1.0  on device 80018000.pinctrl
[    0.840000] leds-gpio leds: Error applying setting, reverse things back
[    0.850000] ledtrig-cpu: registered to indicate activity on CPUs
[    0.860000] usbcore: registered new interface driver usbhid
[    0.870000] usbhid: USB HID core driver
[    0.890000] mxs-builtin-audio mxs-builtin-audio: mxs-builtin-codec-dai <-> 80        048000.mxs-builtin-cpu-dai mapping ok
[    0.910000] TCP: cubic registered
[    0.910000] mmc0: host does not support reading read-only switch, assuming wr        ite-enable
[    0.920000] NET: Registered protocol family 10
[    0.930000] mmc0: new high speed SDHC card at address b368
[    0.940000] sit: IPv6 over IPv4 tunneling driver
[    0.940000] NET: Registered protocol family 17
[    0.950000] mmcblk0: mmc0:b368 NCard 3.71 GiB
[    0.960000] Key type dns_resolver registered
[    0.960000] registered taskstats version 1
[    0.970000]  mmcblk0: p1 p2
[    0.980000] stmp3xxx-rtc 8005c000.rtc: setting system clock to 1970-01-01 00:        00:05 UTC (5)
[    0.990000] ALSA device list:
[    0.990000]   #0: mxs-builtin-audio
[    1.010000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
[    1.020000] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.040000] devtmpfs: mounted
[    1.040000] Freeing unused kernel memory: 156K (c057b000 - c05a2000)
INIT: version 2.88 booting
[info] Using makefile-style concurrent boot in runlevel S.
[....] Starting the hotplug events dispatcher: udevd[    3.250000] udevd[162]: s        tarting version 175
. ok
[ ok ] Synthesizing the initial hotplug events...done.
[    6.380000] CAN device driver interface
[    6.400000] spi1.4 supply vdd not found, using dummy regulator
[    6.400000] spi1.4 supply xceiver not found, using dummy regulator
[    7.400000] Driver for 1-wire Dallas network protocol.
[    7.430000] 80080000.usb supply vbus not found, using dummy regulator
[    7.530000] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    7.530000] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[....] [    7.600000] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    7.600000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    7.610000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
[    7.620000] usb usb1: Product: EHCI Host Controller
[    7.620000] usb usb1: Manufacturer: Linux 3.19.0-imxv5-x0.1 ehci_hcd
[    7.630000] usb usb1: SerialNumber: ci_hdrc.0
Waiting for /dev to be fully populated...[    7.930000] hub 1-0:1.0: USB hub fou        nd
[    7.930000] hub 1-0:1.0: 1 port detected
[    8.310000] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    8.460000] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    8.460000] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    8.480000] hub 1-1:1.0: USB hub found
[    8.480000] hub 1-1:1.0: 5 ports detected
mxs_get_batt_volt(): mxs_get_batt_volt volt=4120 mV
mxs_mem_init_clock
LC
BOOT:  SSP SD/MMC #0
DRAM:  64 MiB
MMC:   MXS MMC: 0
Пробовал перезаписать на другую карту SD, но ничего не изменилось
Заранее спасибо
Хм, может быть образ неправильный? Пришлите фото без верхней крышки пожалуйста, чтобы была видна маркировка большого чипа на плате, которая вторым этажом (он там один).
Образ с гитхаба офф, точно нормальный
Только их там несколько таких официальных образов.
Пришлите фото пожалуйста и точное название файла с образом.
201511241806_sdcard_wb3_alliance.img
201511241806_sdcard_wb3_hynix.img
sdcard_20140609.dd
Это все те, которые пробовал. На первом один раз завелось.
ух, какой раритет у вас. Прошивать нужно “201511241806_sdcard_wb3_hynix.img”
