Имеется wirenboard
# uname -a
Linux wirenboard-AIRANJO4 4.9.22-wb6 #2 SMP Sat Jan 26 11:34:05 UTC 2019 armv7l GNU/Linux
и docker
версии:
# dockerd --version
Docker version 18.09.6, build 481bc77
установленный из репозитория: deb [arch=armhf] https://download.docker.com/linux/debian stretch stable
При запуске сервиса возникает следующая ошибка:
# systemctl start docker
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
Журнал содержит запись об ошибке:
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.212811279Z" level=warning msg="failed to rename /var/lib/docker/tmp for background deletion: rename /var/lib/doc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.222451895Z" level=info msg="parsed scheme: \"unix\"" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.224791633Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.225391338Z" level=info msg="parsed scheme: \"unix\"" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.225553296Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.246207355Z" level=error msg="'overlay' not found as a supported filesystem on this host. Please ensure kernel is
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.262738560Z" level=error msg="AUFS was not found in /proc/filesystems" storage-driver=aufs
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.271238390Z" level=info msg="ccResolverWrapper: sending new addresses to cc: [{unix:///run/containerd/containerd.
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.274161958Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.280381843Z" level=info msg="pickfirstBalancer: HandleSubConnStateChange: 0x93235b90, CONNECTING" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.286716935Z" level=info msg="pickfirstBalancer: HandleSubConnStateChange: 0x93235b90, READY" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.288974631Z" level=info msg="ccResolverWrapper: sending new addresses to cc: [{unix:///run/containerd/containerd.
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.289341254Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.289774794Z" level=info msg="pickfirstBalancer: HandleSubConnStateChange: 0x93235ce0, CONNECTING" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.301576399Z" level=info msg="pickfirstBalancer: HandleSubConnStateChange: 0x93235ce0, READY" module=grpc
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.308808069Z" level=error msg="'overlay' not found as a supported filesystem on this host. Please ensure kernel is
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.309203025Z" level=error msg="Failed to built-in GetDriver graph devicemapper /var/lib/docker"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.330151083Z" level=info msg="Graph migration to content-addressability took 0.00 seconds"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.333051401Z" level=warning msg="Your kernel does not support cgroup memory limit"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.333278691Z" level=warning msg="Unable to find cpu cgroup in mounts"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.333390691Z" level=warning msg="Unable to find blkio cgroup in mounts"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.333496857Z" level=warning msg="Unable to find cpuset cgroup in mounts"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: time="2019-06-25T10:15:58.336762381Z" level=warning msg="mountpoint for pids not found"
Jun 25 10:15:58 wirenboard-AIRANJO4 dockerd[11143]: Error starting daemon: Devices cgroup isn't mounted
Jun 25 10:15:58 wirenboard-AIRANJO4 systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Jun 25 10:15:58 wirenboard-AIRANJO4 systemd[1]: Failed to start Docker Application Container Engine.
