Yuriy
14.Октябрь.2019 09:44:40
1
День добрый.
WB5 Версия прошивки 201604211537
При попытке установки wb-mqtt-mbgate получаю:
root@wirenboard:~# apt-get install wb-mqtt-mbgate
Reading package lists… Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
wb-mqtt-mbgate : Depends: liblog4cpp5 but it is not installable
Depends: liblog4cpp5 (>= 1.0) but it is not installable or
liblog4cpp5v5 (>= 1.0) but it is not installable
Kilpio
14.Октябрь.2019 10:29:48
2
Добрый день, Юрий!
А перед обновлением apt-get update делали?
Yuriy
14.Октябрь.2019 10:54:17
4
День добрый.
root@wirenboard:~# apt-get update
Hit http://archive.debian.org wheezy-backports Release.gpg
Hit http://releases.contactless.ru wheezy Release.gpg
Ign http://httpredir.debian.org wheezy Release.gpg
Ign http://archive.debian.org wheezy-backports/main armel Packages/DiffIndex
Ign http://archive.debian.org wheezy-backports/main Translation-en/DiffIndex
Ign http://httpredir.debian.org wheezy-updates Release.gpg
Hit http://releases.contactless.ru wheezy/main armel Packages
Hit http://archive.debian.org wheezy-backports/main Translation-en
Err http://archive.debian.org wheezy-backports/main armel Packages
Hit http://archive.debian.org wheezy-backports/main armel Packages
Ign http://releases.contactless.ru wheezy/main Translation-en
Err http://httpredir.debian.org wheezy/main armel Packages
404 Not Found [IP: 151.101.84.204 80]
Ign http://httpredir.debian.org wheezy/main Translation-en
Err http://httpredir.debian.org wheezy-updates/main armel Packages
Ign http://httpredir.debian.org wheezy-updates/main Translation-en
W: Failed to fetch http://httpredir.debian.org/debian/dists/wheezy/main/binary-armel/Packages 404 Not Found [IP: 151.101.84.204 80]
W: Failed to fetch http://httpredir.debian.org/debian/dists/wheezy-updates/main/binary-armel/Packages 404 Not Found [IP: 151.101.84.204 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Yuriy
14.Октябрь.2019 11:59:21
5
День добрый.
Вопрос снят. Обновил прошивку, заработало.
