WBE2S-R-433MHZ не могу завести
Куплен и установлен вместе с ZigBee.
Дома лежит датчик THGN132N. RFSniffer установлен.
Проблемы следующие - устройств в интерфейсе нет. Не могу понять, толи сам rfsniffer не работает, толи модуль. Выводы статусов и логов
root@wirenboard-AD4ALVSH:~# service wb-homa-ism-radio status
● wb-homa-ism-radio.service - LSB: MQTT driver for WB HomA for RFM69 ISM radio
Loaded: loaded (/etc/init.d/wb-homa-ism-radio; generated; vendor preset: enabled)
Active: active (exited) since Tue 2020-02-18 21:13:23 +07; 13min ago
Docs: man:systemd-sysv-generator(8)
Process: 1030 ExecStart=/etc/init.d/wb-homa-ism-radio start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/wb-homa-ism-radio.service
Feb 18 21:13:12 wirenboard-AD4ALVSH systemd[1]: Starting LSB: MQTT driver for WB HomA for RFM69 ISM radio…
Feb 18 21:13:23 wirenboard-AD4ALVSH wb-homa-ism-radio[1030]: Starting MQTT driver for WB HomA for RFM69 ISM radio: wb-homa-rcd.
Feb 18 21:13:23 wirenboard-AD4ALVSH systemd[1]: Started LSB: MQTT driver for WB HomA for RFM69 ISM radio.
root@wirenboard-AD4ALVSH:~# cat /etc/wb-homa-rfsniffer.conf
“debug”: {
“dump_stream”: false,
“log”: [
“console_level”: 5,
“file_level”: 3,
“file_name”: “/run/wb-homa-rfsniffer.log”,
“log_time”: “yes”,
“name”: “Main”
“save_path”: “~/”
“devices”: {
“known_devices”: [
“heartbeat”: 7300,
“name”: “noolite_rx_0x149f”,
“politics”: “show”
“unknown_devices_politics”: “show”,
“use_devices_list”: true
“enabled_features”: {
“noolite_tx”: {
“addrs”: []
“enabled_protocols”: [
“X10”,
“RST”,
“Raex”,
“Livolo”,
“Oregon”,
“nooLite”,
“Rubitek”,
“MotionSensor”,
“EV1527”
“mqtt”: {
“host”: “localhost”
“radio”: {
“lirc_device”: “/dev/lirc1”,
“rfm_irq”: 38,
“rssi”: -90,
“spi_device”: “/dev/spidev10.0”
root@wirenboard-AD4ALVSH:~# cat /run/wb-homa-rfsniffer.log
1582035189 INFO : RFSniffer parameters
1582035189 INFO : || config = ‘/etc/wb-homa-rfsniffer.conf’
1582035189 INFO : || bDebug = false
1582035189 INFO : || bDumpAllRegs = false
1582035189 INFO : || bLircPedantic = true
1582035189 INFO : || spiDevice = ‘/dev/spidev10.0’
1582035189 INFO : || spiSpeed = 500000
1582035189 INFO : || gpioInt = 38
1582035189 INFO : || fixedThresh = 0
1582035189 INFO : || rssi = -90
1582035189 INFO : || bRfmEnable = true
1582035189 INFO : || bCoreTestMod = false
1582035189 INFO : || lircDevice = ‘/dev/lirc1’
1582035189 INFO : || mqttHost = ‘localhost’
1582035189 INFO : || scannerParams = ‘’
1582035189 INFO : || bDumpAllLircStream = false
1582035189 INFO : || bSimultaneouslyDumpStreamAndWork = false
1582035189 INFO : || savePath = ‘~/’
1582035189 INFO : || inverted = false
а точно /dev/spidev10.0? у меня /dev/spidev0.0
а wb-homa-ism-radio нужно дизейблить или удалять, они вместе не живут точно
точно /dev/spidev10.0 , потому что убирал модуль zigbee и оставалось одно устройство. это, конечно, справедливо, если энумератор не переименовывает их каждый раз.
wb-homa-ism-radio удалено перед установкой rfsniffer .
очередной раз перечитывая вики по wb6 наткнулся на фразу " радиомодуль RFM69H устанавливается в контроллер при производстве (в версиях до 6.4)". Я воткнул модуль WBE2S-R-433MHZ в WB6 r.63 . Получается, он аппаратно не совместим?
можно ли модуль самого RF выпаять из модуля WBE2S-R-433MHZ и запаять на плату WB6? Какую-то ещё обвеску допаять?
Паяльником владею, микрухи уровня LQFP-48 перепаиваю успешно.
Я понимаю, что сам лажанул, но прошу содействия.
вообще радиомодуль совместим и со старыми контроллерами тоже. Не нужно ничего перепаивать. Рекомендую сначала попробовать работать с wb-homa-ism-radio .
Помог рецепт отсюда . Его бы в официальную документацию.
А какой именно пост в той теме?
после перехода на WB6 увидел, что rfsniffer стал работать на порядок лучше. Похоже, что на WB5 ему не хватает ресурсов.
