./build_kernel.sh - Что делать?
При выполнения скрипта выдается следующее.
./build_kernel.sh
  • Detected build host [Debian GNU/Linux 7.4 (wheezy)]
  • host: [i686]
  • git HEAD commit: [1640cd006b07c87b2dbfa1f01283a3d40ba51cb1]
    Installing: gcc-arm-none-eabi
debug: CC=/build_kernel/dl/gcc-arm-none-eabi-4_7-2013q3/bin/arm-none-eabi-
scripts/git: LINUX_GIT not defined in system.sh
cloning git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git into default location: /build_kernel/ignore/linux-src
Cloning into ‘/build_kernel/ignore/linux-src’…
remote: Counting objects: 3443123, done.
remote: Compressing objects: 100% (516290/516290), done.
remote: Total 3443123 (delta 2898435), reused 3442136 (delta 2897615)
Receiving objects: 100% (3443123/3443123), 722.54 MiB | 541 KiB/s, done.
Resolving deltas: 100% (2898435/2898435), done.
Checking out files: 100% (45940/45940), done.
scripts/git: Debug: LINUX_GIT is setup as…
[core]
repositoryformatversion = 0
filemode = true
bare = false
logallrefupdates = true
[remote “origin”]
fetch = +refs/heads/:refs/remotes/origin/
url = git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
[branch “master”]
remote = origin
merge = refs/heads/master
scripts/git: Updating LINUX_GIT tree via: git fetch
/build_kernel
Cloning into ‘/build_kernel/KERNEL’…
done.
Resolve operation not in progress, we are not resuming.
git tree is clean…
[master baa9541] empty cleanup commit
HEAD is now at baa9541 empty cleanup commit
Already on ‘master’
Your branch is ahead of ‘origin/master’ by 1 commit.
Already up-to-date.
scripts/git: pulling from: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
From git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
  • branch master -> FETCH_HEAD
    Already up-to-date.
    Checking out files: 100% (16367/16367), done.
    Switched to a new branch ‘v3.12-rc3-imxv5-x0.3’
    v3.12-rc3
    pulling dev repo
    The authenticity of host ‘github.com (192.30.252.128)’ can’t be established.
    RSA key fingerprint is 16:27:ac:a5:76:28:2d:36:63:1b:56:4d:eb:df:a6:48.
    Are you sure you want to continue connecting (yes/no)? yes
    Warning: Permanently added ‘github.com,192.30.252.128’ (RSA) to the list of known hosts.
    Bad packet length 674059733.
    Disconnecting: Packet corrupt
    fatal: The remote end hung up unexpectedly
Вы это где выполняете? ОС, окружение?
Вот это:
намекает на то, что у вас что-то почему-то не может скачаться. С сетью проблем нет?
Ошибка вопроизводится?
Конечно воспроизводится.
При последующем выполнение выходит ошибка, что permission denied(publikey).
C сетью проблем нет. Весь репозитария на раз выкачивается.
Погуглив вышел на такую страницу
Да, там видимо неправильно в скрипте написано - стоит обращение через git+ssh.
Надо либо учётную запись на github завести, либо исправить в соответствующем скрипте.
А как это сделать?
