gpioset --help
gpioinfo --help
Usage: gpioset [OPTIONS] <line=value>…
Set values of GPIO lines.
Lines are specified by name, or optionally by offset if the chip option
is provided.
Values may be ‘1’ or ‘0’, or equivalently ‘active’/‘inactive’ or ‘on’/‘off’.
The line output state is maintained until the process exits, but after that
is not guaranteed.
Options:
–banner display a banner on successful startup
-b, --bias specify the line bias
Possible values: ‘pull-down’, ‘pull-up’, ‘disabled’.
(default is to leave bias unchanged)
–by-name treat lines as names even if they would parse as an offset
-c, --chip restrict scope to a particular chip
-C, --consumer consumer name applied to requested lines (default is ‘gpioset’)
-d, --drive specify the line drive mode
Possible values: ‘push-pull’, ‘open-drain’, ‘open-source’.
(default is ‘push-pull’)
-h, --help display this help and exit
-l, --active-low treat the line as active low
-p, --hold-period
the minimum time period to hold lines at the requested values
-s, --strict abort if requested line names are not unique
-t, --toggle [,period]…
toggle the line(s) after the specified period(s)
If the last period is 0 then gpioset exits else the sequence repeats.
–unquoted don’t quote line names
-v, --version output version information and exit
-z, --daemonize set values then detach from the controlling terminal
Chips:
A GPIO chip may be identified by number, name, or path.
e.g. ‘0’, ‘gpiochip0’, and ‘/dev/gpiochip0’ all refer to the same chip.
Periods:
Periods are taken as milliseconds unless units are specified. e.g. 10us.
Supported units are ‘m’, ‘s’, ‘ms’, and ‘us’ for minutes, seconds, milliseconds and
microseconds respectively.
Note
It should not be assumed that a line will retain its state after gpioset exits.
When a process exits, any GPIO lines it has requested are automatically released.
Once released, the state of a line may be modified by the kernel or another process.
To guarantee the requested value, by default gpioset does not exit.
Usage: gpioinfo [OPTIONS] [line]…
Print information about GPIO lines.
is provided.
If no lines are specified then all lines are displayed.
Options:
-s, --strict check all lines - don’t assume line names are unique
–unquoted don’t quote line or consumer names
Chips:
