Не хватает места для установки docker
при установке докер ругается.
root@wirenboard-AZYBSN6T:~# apt update && apt install docker-ce docker-ce-cli containerd.io
Ign:1 http://deb.debian.org/debian stretch InRelease
Hit:3 http://deb.debian.org/debian stretch-updates InRelease
Hit:4 http://security.debian.org stretch/updates InRelease
Hit:5 http://deb.debian.org/debian stretch Release
Get:6 http://deb.wirenboard.com/wb6/stretch stable InRelease [3958 B]
Get:2 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease [91.8 kB]
Hit:7 https://download.docker.com/linux/debian stretch InRelease
Get:9 http://deb.wirenboard.com/wb6/stretch stable/main armhf Packages [45.5 kB]
Fetched 141 kB in 10s (12.9 kB/s)
Reading package lists... Done
Building dependency tree
14 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following additional packages will be installed:
  cgroupfs-mount iptables libip6tc0 libiptc0 libltdl7 pigz
The following NEW packages will be installed:
  cgroupfs-mount containerd.io docker-ce docker-ce-cli iptables libip6tc0 libiptc0 libltdl7 pigz
0 upgraded, 9 newly installed, 0 to remove and 14 not upgraded.
Need to get 68.7 MB of archives.
After this operation, 299 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://deb.debian.org/debian stretch/main armhf pigz armhf 2.3.4-1 [52.1 kB]
Get:2 http://deb.debian.org/debian stretch/main armhf libip6tc0 armhf 1.6.0+snapshot20161117-6 [66.4 kB]
Get:3 http://deb.debian.org/debian stretch/main armhf libiptc0 armhf 1.6.0+snapshot20161117-6 [57.6 kB]
Get:4 http://deb.debian.org/debian stretch/main armhf iptables armhf 1.6.0+snapshot20161117-6 [265 kB]
Get:5 http://deb.debian.org/debian stretch/main armhf cgroupfs-mount all 1.3 [5716 B]
Get:6 http://deb.debian.org/debian stretch/main armhf libltdl7 armhf 2.4.6-2 [386 kB]
Get:7 https://download.docker.com/linux/debian stretch/stable armhf containerd.io armhf 1.4.3-1 [20.3 MB]
Get:8 https://download.docker.com/linux/debian stretch/stable armhf docker-ce-cli armhf 5:19.03.15~3-0~debian-stretch [33.1 MB]
Get:9 https://download.docker.com/linux/debian stretch/stable armhf docker-ce armhf 5:19.03.15~3-0~debian-stretch [14.6 MB]
Fetched 68.7 MB in 52s (1317 kB/s)
Selecting previously unselected package pigz.
(Reading database ... 35607 files and directories currently installed.)
Preparing to unpack .../0-pigz_2.3.4-1_armhf.deb ...
Unpacking pigz (2.3.4-1) ...
Selecting previously unselected package libip6tc0:armhf.
Preparing to unpack .../1-libip6tc0_1.6.0+snapshot20161117-6_armhf.deb ...
Unpacking libip6tc0:armhf (1.6.0+snapshot20161117-6) ...
Selecting previously unselected package libiptc0:armhf.
Preparing to unpack .../2-libiptc0_1.6.0+snapshot20161117-6_armhf.deb ...
Unpacking libiptc0:armhf (1.6.0+snapshot20161117-6) ...
Selecting previously unselected package iptables.
Preparing to unpack .../3-iptables_1.6.0+snapshot20161117-6_armhf.deb ...
Unpacking iptables (1.6.0+snapshot20161117-6) ...
Selecting previously unselected package cgroupfs-mount.
Preparing to unpack .../4-cgroupfs-mount_1.3_all.deb ...
Unpacking cgroupfs-mount (1.3) ...
Selecting previously unselected package containerd.io.
Preparing to unpack .../5-containerd.io_1.4.3-1_armhf.deb ...
Unpacking containerd.io (1.4.3-1) ...
Selecting previously unselected package docker-ce-cli.
Preparing to unpack .../6-docker-ce-cli_5%3a19.03.15~3-0~debian-stretch_armhf.deb ...
Unpacking docker-ce-cli (5:19.03.15~3-0~debian-stretch) ...
Selecting previously unselected package docker-ce.
Preparing to unpack .../7-docker-ce_5%3a19.03.15~3-0~debian-stretch_armhf.deb ...
Unpacking docker-ce (5:19.03.15~3-0~debian-stretch) ...
dpkg: error processing archive /tmp/apt-dpkg-install-oiZfmk/7-docker-ce_5%3a19.03.15~3-0~debian-stretch_armhf.deb (--unpack):
 cannot copy extracted data for './usr/bin/dockerd' to '/usr/bin/dockerd.dpkg-new': failed to write (No space left on device)
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Selecting previously unselected package libltdl7:armhf.
Preparing to unpack .../8-libltdl7_2.4.6-2_armhf.deb ...
Unpacking libltdl7:armhf (2.4.6-2) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@wirenboard-AZYBSN6T:~# docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
плюс, забит dev/root/ на 100% (как его почистить ?)
root@wirenboard-AZYBSN6T:~# df -hT
Filesystem     Type      Size  Used Avail Use% Mounted on
/dev/root      ext4      976M  955M     0 100% /
devtmpfs       devtmpfs  239M     0  239M   0% /dev
tmpfs          tmpfs     248M     0  248M   0% /dev/shm
tmpfs          tmpfs     248M  524K  247M   1% /run
tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
tmpfs          tmpfs     248M     0  248M   0% /sys/fs/cgroup
/dev/mmcblk0p6 ext4      4.7G  559M  3.9G  13% /mnt/data
tmpfs          tmpfs      50M     0   50M   0% /run/user/0
Установка Docker из-за нехватки места и не завершается корректно. Самый простой способ освободить место - перенести директории с пользовательскими программами на раздел /mnt/data так:
извините а не подскажите какой алгоритм удаления , то что вы оставили ссылку это огромная помощь го сам процесс удаления я в нем не нашел в моем случае тоже (101M /usr/lib/arm-linux-gnueabihf) занимает много места, как нужно прописать чтоб удалилось именно это cd /usr/lib/arm-linux-gnueabihf delet или как ?
Не надо удалять системные библиотеки, переносить можно только то что точно не требуется для старта.
а можно както добавить места ?
буьте добры подскажите что тут можно почистить ?
root@wirenboard-AZYBSN6T:~# du -h -d 1 /usr
4.0K    /usr/games
30M     /usr/include
6.1M    /usr/sbin
112K    /usr/local
247M    /usr/bin
4.0K    /usr/src
77M     /usr/libexec
138M    /usr/share
321M    /usr/lib
817M    /usr
На довольно дого работающем контроллере, с nodejs, zigbee вот так:
du -h -d 1 /usr
20M	/usr/include
4.0K	/usr/games
6.2M	/usr/sbin
137M	/usr/share
91M	/usr/bin
201M	/usr/lib
4.0K	/usr/src
112K	/usr/local
454M	/usr
“чистить” - очень некорректно, не бывает ненужных файлов, если они установлены - то следует удалить/перенести пакет которому они пренадлежат.
Или, например перенести,
Вот например у меня /usr/lib/node_modules весит более 100 МБ
Я точно знаю что для загрузки системы оно не нужно
Создаю /mnt/data/usr/libи переношу туда /usr/lib/node_modules
Ну и оставляю симлинк на новое расположение:
ln -s /mnt/data/usr/lib/node_modules /usr/lib/node_modules
Все, файлы фактически лежат на другом разделе.
а как мне понять что находится в этой папке ?
root@wirenboard-AZYBSN6T:~# du -h -d 1 /usr/bin
247M    /usr/bin
у меня он весит меньше но я думаю наверное тоже стоит сделать так как у вас в примере
Бинарники, исполняемые файлы.
Да, это верный путь.
проверьте будьте добры все правильно я указываю ?
mkdir /mnt/data/usr/lib (создаю)
mv /usr/lib/node_modules /mnt/data/usr/lib (переношу)
In -s /mnt/data/usr/lib/node_modules /usr/lib/node_molules (ссылка на старое место)
у меня получается Dochker не установился но место занял
root@wirenboard-AZYBSN6T:~# dpkg-query --show --showformat='${Installed-Size}\t${Package}\n' | sort -rh | head -30 | awk '{print $1/1024, $2}'
129.517 docker-ce-cli
87.6982 containerd.io
82.3535 nodejs
50.2881 linux-image-wb6
27.6943 libicu57
26.9365 vim-runtime
19.8555 git
18.8457 binutils
17.2178 perl-modules-5.24
13.9912 gcc-6
13.834 libstdc++-6-dev
13.3828 libperl5.24
13.1484 g++-6
13.1387 coreutils
12.5938 wb-rules
12.3535 cpp-6
10.3701 libc6-dev
9.23926 libglib2.0-data
9.08691 libpython3.5-stdlib
9.0293 locales
8.18555 libc6
8.09375 wb-mqtt-homeui
7.73926 libpython2.7-stdlib
6.68066 geoip-database
6.64746 systemd
6.51855 udev
6.41113 python3.5-minimal
6.24805 dpkg
6.05469 wb-mqtt-confed
6.04004 ieee-data
я так понимаю мне нужно сделать следующее
apt purge docher
а затем заново произвети установку ?
Что выводит
apt policy docker-ce
root@wirenboard-AZYBSN6T:~# apt policy docker-ce
docker-ce:
  Installed: (none)
  Candidate: 5:19.03.15~3-0~debian-stretch
  Version table:
     5:19.03.15~3-0~debian-stretch 500
        500 https://download.docker.com/linux/debian stretch/stable armhf Packages
     5:19.03.14~3-0~debian-stretch 500
     5:19.03.13~3-0~debian-stretch 500
     5:19.03.12~3-0~debian-stretch 500
     5:19.03.11~3-0~debian-stretch 500
     5:19.03.10~3-0~debian-stretch 500
     5:19.03.9~3-0~debian-stretch 500
     5:19.03.8~3-0~debian-stretch 500
     5:19.03.7~3-0~debian-stretch 500
     5:19.03.6~3-0~debian-stretch 500
     5:19.03.5~3-0~debian-stretch 500
     5:19.03.4~3-0~debian-stretch 500
     5:19.03.3~3-0~debian-stretch 500
     5:19.03.2~3-0~debian-stretch 500
     5:19.03.1~3-0~debian-stretch 500
     5:19.03.0~3-0~debian-stretch 500
     5:18.09.9~3-0~debian-stretch 500
     5:18.09.8~3-0~debian-stretch 500
     5:18.09.7~3-0~debian-stretch 500
     5:18.09.6~3-0~debian-stretch 500
     5:18.09.5~3-0~debian-stretch 500
     5:18.09.4~3-0~debian-stretch 500
     5:18.09.3~3-0~debian-stretch 500
     5:18.09.2~3-0~debian-stretch 500
     5:18.09.1~3-0~debian-stretch 500
     5:18.09.0~3-0~debian-stretch 500
     18.06.3~ce~3-0~debian 500
     18.06.2~ce~3-0~debian 500
     18.06.1~ce~3-0~debian 500
     18.06.0~ce~3-0~debian 500
     18.03.1~ce-0~debian 500
     18.03.0~ce-0~debian 500
     17.12.1~ce-0~debian 500
     17.12.0~ce-0~debian 500
     17.09.1~ce-0~debian 500
     17.09.0~ce-0~debian 500
     17.06.2~ce-0~debian 500
     17.06.1~ce-0~debian 500
     17.06.0~ce-0~debian 500
Вы устанавливали пакеты: docker-ce docker-ce-cli containerd.io
Два из них установились, но, возможно, не сконфигурировались:
Пакет docker-ce, по-видимому, не установился, так как не хватило места. Я бы еще раз выполнил установку всех пакетов (которые уже были установлены будут переустановлены):
apt install docker-ce docker-ce-cli containerd.io --reinstall
root@wirenboard-AZYBSN6T:~# apt install docker-ce docker-ce-cli containerd.io
containerd.io is already the newest version (1.4.3-1).
docker-ce-cli is already the newest version (5:19.03.15~3-0~debian-stretch).
  docker-ce
0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded.
8 not fully installed or removed.
Need to get 14.6 MB of archives.
After this operation, 69.6 MB of additional disk space will be used.
нехватит места получается
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       976M  860M   50M  95% /
/dev/mmcblk0p6  4.7G  614M  3.9G  14% /mnt/data
а можно докер установить по другому адресу ? где есть необходимое ему пространство ?
потому-что насколько я понял он устанавливает его по умолчанию в /usr/bin и на данный момент в этой папке уже занято им-же насколько мне известно 247 mb
Самый лучший и простой способ - это установить штатно, а потом переносить, как было описано выше. Найдите директории, которые были созданы при установке пакетов docker-ce-cli и containerd.io командами:
dpkg -L docker-ce-cli
dpkg -L containerd.io
и перенесите их на /mnt/data, заменив символическими ссылками. А затем уже установите пакет docker-ce
я правильно понимаю, пакеты со всеми директориями нужно по отдельности создавать на /mnt/data затем переносить их сюда и потом делать ссылку ? система небудет в шоке от такого количества ссылок ?
root@wirenboard-AZYBSN6T:~# dpkg -L docker-ce-cli
/usr
/usr/bin
/usr/bin/docker
/usr/libexec
/usr/libexec/docker
/usr/libexec/docker/cli-plugins
/usr/libexec/docker/cli-plugins/docker-app
/usr/libexec/docker/cli-plugins/docker-buildx
/usr/share
/usr/share/bash-completion
/usr/share/bash-completion/completions
/usr/share/bash-completion/completions/docker
/usr/share/doc
/usr/share/doc/docker-ce-cli
/usr/share/doc/docker-ce-cli/changelog.Debian.gz
/usr/share/fish
/usr/share/fish/vendor_completions.d
/usr/share/fish/vendor_completions.d/docker.fish
/usr/share/man
/usr/share/man/man1
/usr/share/man/man1/docker-attach.1.gz
/usr/share/man/man1/docker-build.1.gz
/usr/share/man/man1/docker-builder-build.1.gz
/usr/share/man/man1/docker-builder-prune.1.gz
/usr/share/man/man1/docker-builder.1.gz
/usr/share/man/man1/docker-checkpoint-create.1.gz
/usr/share/man/man1/docker-checkpoint-ls.1.gz
/usr/share/man/man1/docker-checkpoint-rm.1.gz
/usr/share/man/man1/docker-checkpoint.1.gz
/usr/share/man/man1/docker-commit.1.gz
/usr/share/man/man1/docker-config-create.1.gz
/usr/share/man/man1/docker-config-inspect.1.gz
/usr/share/man/man1/docker-config-ls.1.gz
/usr/share/man/man1/docker-config-rm.1.gz
/usr/share/man/man1/docker-config.1.gz
/usr/share/man/man1/docker-container-attach.1.gz
/usr/share/man/man1/docker-container-commit.1.gz
/usr/share/man/man1/docker-container-cp.1.gz
/usr/share/man/man1/docker-container-create.1.gz
/usr/share/man/man1/docker-container-diff.1.gz
/usr/share/man/man1/docker-container-exec.1.gz
/usr/share/man/man1/docker-container-export.1.gz
/usr/share/man/man1/docker-container-inspect.1.gz
/usr/share/man/man1/docker-container-kill.1.gz
/usr/share/man/man1/docker-container-logs.1.gz
/usr/share/man/man1/docker-container-ls.1.gz
/usr/share/man/man1/docker-container-pause.1.gz
/usr/share/man/man1/docker-container-port.1.gz
/usr/share/man/man1/docker-container-prune.1.gz
/usr/share/man/man1/docker-container-rename.1.gz
/usr/share/man/man1/docker-container-restart.1.gz
/usr/share/man/man1/docker-container-rm.1.gz
/usr/share/man/man1/docker-container-run.1.gz
/usr/share/man/man1/docker-container-start.1.gz
/usr/share/man/man1/docker-container-stats.1.gz
/usr/share/man/man1/docker-container-stop.1.gz
/usr/share/man/man1/docker-container-top.1.gz
/usr/share/man/man1/docker-container-unpause.1.gz
/usr/share/man/man1/docker-container-update.1.gz
/usr/share/man/man1/docker-container-wait.1.gz
/usr/share/man/man1/docker-container.1.gz
/usr/share/man/man1/docker-context-create.1.gz
/usr/share/man/man1/docker-context-export.1.gz
/usr/share/man/man1/docker-context-import.1.gz
/usr/share/man/man1/docker-context-inspect.1.gz
/usr/share/man/man1/docker-context-ls.1.gz
/usr/share/man/man1/docker-context-rm.1.gz
/usr/share/man/man1/docker-context-update.1.gz
/usr/share/man/man1/docker-context-use.1.gz
/usr/share/man/man1/docker-context.1.gz
/usr/share/man/man1/docker-cp.1.gz
/usr/share/man/man1/docker-create.1.gz
/usr/share/man/man1/docker-deploy.1.gz
/usr/share/man/man1/docker-diff.1.gz
/usr/share/man/man1/docker-engine-activate.1.gz
/usr/share/man/man1/docker-engine-check.1.gz
/usr/share/man/man1/docker-engine-update.1.gz
/usr/share/man/man1/docker-engine.1.gz
/usr/share/man/man1/docker-events.1.gz
/usr/share/man/man1/docker-exec.1.gz
/usr/share/man/man1/docker-export.1.gz
/usr/share/man/man1/docker-history.1.gz
/usr/share/man/man1/docker-image-build.1.gz
/usr/share/man/man1/docker-image-history.1.gz
/usr/share/man/man1/docker-image-import.1.gz
/usr/share/man/man1/docker-image-inspect.1.gz
/usr/share/man/man1/docker-image-load.1.gz
/usr/share/man/man1/docker-image-ls.1.gz
/usr/share/man/man1/docker-image-prune.1.gz
/usr/share/man/man1/docker-image-pull.1.gz
/usr/share/man/man1/docker-image-push.1.gz
/usr/share/man/man1/docker-image-rm.1.gz
/usr/share/man/man1/docker-image-save.1.gz
/usr/share/man/man1/docker-image-tag.1.gz
/usr/share/man/man1/docker-image.1.gz
/usr/share/man/man1/docker-images.1.gz
/usr/share/man/man1/docker-import.1.gz
/usr/share/man/man1/docker-info.1.gz
/usr/share/man/man1/docker-inspect.1.gz
/usr/share/man/man1/docker-kill.1.gz
/usr/share/man/man1/docker-load.1.gz
/usr/share/man/man1/docker-login.1.gz
/usr/share/man/man1/docker-logout.1.gz
/usr/share/man/man1/docker-logs.1.gz
/usr/share/man/man1/docker-manifest-annotate.1.gz
/usr/share/man/man1/docker-manifest-create.1.gz
/usr/share/man/man1/docker-manifest-inspect.1.gz
/usr/share/man/man1/docker-manifest-push.1.gz
/usr/share/man/man1/docker-manifest.1.gz
/usr/share/man/man1/docker-network-connect.1.gz
/usr/share/man/man1/docker-network-create.1.gz
/usr/share/man/man1/docker-network-disconnect.1.gz
/usr/share/man/man1/docker-network-inspect.1.gz
/usr/share/man/man1/docker-network-ls.1.gz
/usr/share/man/man1/docker-network-prune.1.gz
/usr/share/man/man1/docker-network-rm.1.gz
/usr/share/man/man1/docker-network.1.gz
/usr/share/man/man1/docker-node-demote.1.gz
/usr/share/man/man1/docker-node-inspect.1.gz
/usr/share/man/man1/docker-node-ls.1.gz
/usr/share/man/man1/docker-node-promote.1.gz
/usr/share/man/man1/docker-node-ps.1.gz
/usr/share/man/man1/docker-node-rm.1.gz
/usr/share/man/man1/docker-node-update.1.gz
/usr/share/man/man1/docker-node.1.gz
/usr/share/man/man1/docker-pause.1.gz
/usr/share/man/man1/docker-plugin-create.1.gz
/usr/share/man/man1/docker-plugin-disable.1.gz
/usr/share/man/man1/docker-plugin-enable.1.gz
/usr/share/man/man1/docker-plugin-inspect.1.gz
/usr/share/man/man1/docker-plugin-install.1.gz
/usr/share/man/man1/docker-plugin-ls.1.gz
/usr/share/man/man1/docker-plugin-push.1.gz
/usr/share/man/man1/docker-plugin-rm.1.gz
/usr/share/man/man1/docker-plugin-set.1.gz
/usr/share/man/man1/docker-plugin-upgrade.1.gz
/usr/share/man/man1/docker-plugin.1.gz
/usr/share/man/man1/docker-port.1.gz
/usr/share/man/man1/docker-ps.1.gz
/usr/share/man/man1/docker-pull.1.gz
/usr/share/man/man1/docker-push.1.gz
/usr/share/man/man1/docker-rename.1.gz
/usr/share/man/man1/docker-restart.1.gz
/usr/share/man/man1/docker-rm.1.gz
/usr/share/man/man1/docker-rmi.1.gz
/usr/share/man/man1/docker-run.1.gz
/usr/share/man/man1/docker-save.1.gz
/usr/share/man/man1/docker-search.1.gz
/usr/share/man/man1/docker-secret-create.1.gz
/usr/share/man/man1/docker-secret-inspect.1.gz
/usr/share/man/man1/docker-secret-ls.1.gz
/usr/share/man/man1/docker-secret-rm.1.gz
/usr/share/man/man1/docker-secret.1.gz
/usr/share/man/man1/docker-service-create.1.gz
/usr/share/man/man1/docker-service-inspect.1.gz
/usr/share/man/man1/docker-service-logs.1.gz
/usr/share/man/man1/docker-service-ls.1.gz
/usr/share/man/man1/docker-service-ps.1.gz
/usr/share/man/man1/docker-service-rm.1.gz
/usr/share/man/man1/docker-service-rollback.1.gz
/usr/share/man/man1/docker-service-scale.1.gz
/usr/share/man/man1/docker-service-update.1.gz
/usr/share/man/man1/docker-service.1.gz
/usr/share/man/man1/docker-stack-deploy.1.gz
/usr/share/man/man1/docker-stack-ls.1.gz
/usr/share/man/man1/docker-stack-ps.1.gz
/usr/share/man/man1/docker-stack-rm.1.gz
/usr/share/man/man1/docker-stack-services.1.gz
/usr/share/man/man1/docker-stack.1.gz
/usr/share/man/man1/docker-start.1.gz
/usr/share/man/man1/docker-stats.1.gz
/usr/share/man/man1/docker-stop.1.gz
/usr/share/man/man1/docker-swarm-ca.1.gz
/usr/share/man/man1/docker-swarm-init.1.gz
/usr/share/man/man1/docker-swarm-join-token.1.gz
/usr/share/man/man1/docker-swarm-join.1.gz
/usr/share/man/man1/docker-swarm-leave.1.gz
/usr/share/man/man1/docker-swarm-unlock-key.1.gz
/usr/share/man/man1/docker-swarm-unlock.1.gz
/usr/share/man/man1/docker-swarm-update.1.gz
/usr/share/man/man1/docker-swarm.1.gz
/usr/share/man/man1/docker-system-df.1.gz
/usr/share/man/man1/docker-system-events.1.gz
/usr/share/man/man1/docker-system-info.1.gz
/usr/share/man/man1/docker-system-prune.1.gz
/usr/share/man/man1/docker-system.1.gz
/usr/share/man/man1/docker-tag.1.gz
/usr/share/man/man1/docker-top.1.gz
/usr/share/man/man1/docker-trust-inspect.1.gz
/usr/share/man/man1/docker-trust-key-generate.1.gz
/usr/share/man/man1/docker-trust-key-load.1.gz
/usr/share/man/man1/docker-trust-key.1.gz
/usr/share/man/man1/docker-trust-revoke.1.gz
/usr/share/man/man1/docker-trust-sign.1.gz
/usr/share/man/man1/docker-trust-signer-add.1.gz
/usr/share/man/man1/docker-trust-signer-remove.1.gz
/usr/share/man/man1/docker-trust-signer.1.gz
/usr/share/man/man1/docker-trust.1.gz
/usr/share/man/man1/docker-unpause.1.gz
/usr/share/man/man1/docker-update.1.gz
/usr/share/man/man1/docker-version.1.gz
/usr/share/man/man1/docker-volume-create.1.gz
/usr/share/man/man1/docker-volume-inspect.1.gz
/usr/share/man/man1/docker-volume-ls.1.gz
/usr/share/man/man1/docker-volume-prune.1.gz
/usr/share/man/man1/docker-volume-rm.1.gz
/usr/share/man/man1/docker-volume.1.gz
/usr/share/man/man1/docker-wait.1.gz
/usr/share/man/man1/docker.1.gz
/usr/share/man/man5
/usr/share/man/man5/Dockerfile.5.gz
/usr/share/man/man5/docker-config-json.5.gz
/usr/share/man/man8
/usr/share/man/man8/dockerd.8.gz
/usr/share/zsh
/usr/share/zsh/vendor-completions
/usr/share/zsh/vendor-completions/_docker
root@wirenboard-AZYBSN6T:~# dpkg -L containerd.io
/etc
/etc/containerd
/etc/containerd/config.toml
/lib
/lib/systemd
/lib/systemd/system
/lib/systemd/system/containerd.service
/usr
/usr/bin
/usr/bin/containerd
/usr/bin/containerd-shim
/usr/bin/containerd-shim-runc-v1
/usr/bin/containerd-shim-runc-v2
/usr/bin/ctr
/usr/bin/runc
/usr/share
/usr/share/doc
/usr/share/doc/containerd.io
/usr/share/doc/containerd.io/changelog.Debian.gz
/usr/share/doc/containerd.io/copyright
/usr/share/man
/usr/share/man/man5
/usr/share/man/man5/containerd-config.toml.5.gz
/usr/share/man/man8
/usr/share/man/man8/containerd-config.8.gz
/usr/share/man/man8/containerd.8.gz
/usr/share/man/man8/ctr.8.gz
возможно можно содержимое директории /usr/bin перенести и связать ссылкой ?
Не нужно переносить абсолютно все. Выберите несколько директорий, которые занимают всех больше места, их и перенесите.
Например, /usr/share/doc/containerd.io, /usr/libexec/docker.
если я все правильно понимаю он не-видит мою ссылку ? которую я создавал ранее
/dev/root       976M  786M  124M  87% /
/dev/mmcblk0p6  4.7G  691M  3.8G  16% /mnt/data
root@wirenboard-AZYBSN6T:~# apt install docker-ce docker-ce-cli containerd.io --reinstall
  docker-ce
0 upgraded, 1 newly installed, 2 reinstalled, 0 to remove and 14 not upgraded.
Get:1 https://download.docker.com/linux/debian stretch/stable armhf docker-ce armhf 5:19.03.15~3-0~debian-stretch [14.6 MB]
Fetched 14.6 MB in 12s (1195 kB/s)
E: Internal Error, No file name for containerd.io:armhf
