Добрый день, Контроллер 7.3.2, модуль WBE2R-R-ZIGBEE v.2.
Месяц назад внезапно отвалились все zigbee устройства, и только сейчас дошли руки посмотреть что к чему.
Лог ошибки вывода при старте службы:
> zigbee2mqtt@1.40.2 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2024-12-26 16:36:24] info: z2m: Logging to console, file (filename: log.log)
[2024-12-26 16:36:24] info: z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-12-26 16:36:24] info: z2m: Starting zigbee-herdsman (2.1.3)
[2024-12-26 16:36:28] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD4","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-12-26 16:36:28] info: zh:zstack:znp: Serialport opened
[2024-12-26 16:36:29] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-12-26 16:36:30] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-12-26 16:36:48] error: z2m: Error while starting zigbee-herdsman
[2024-12-26 16:36:48] error: z2m: Failed to start zigbee
[2024-12-26 16:36:48] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-26 16:36:48] error: z2m: Exiting...
[2024-12-26 16:36:49] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
at Controller.start (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbee.ts:69:27)
at Controller.start (/mnt/data/root/zigbee2mqtt/lib/controller.ts:161:27)
at start (/mnt/data/root/zigbee2mqtt/index.js:154:5)
В чем может быть причина z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)?
