my-wb
#1
Добрый день
поставил агента snmp (apt install snmp snmpd)
при попытке старта
фев 05 16:09:39 wirenboard- systemd[1]: Starting Simple Network Management Protocol (SNMP) Daemon…
фев 05 16:09:39 wirenboard- systemd[1]: Started Simple Network Management Protocol (SNMP) Daemon…
фев 05 16:09:39 wirenboard- snmpd[12389]: pcilib: Cannot open /proc/bus/pci
фев 05 16:09:39 wirenboard- snmpd[12389]: pcilib: Cannot find any working access method.
фев 05 16:09:39 wirenboard- snmpd[12389]: pcilib: pci_init failed
фев 05 16:09:39 wirenboard- snmpd[12389]: /etc/snmp/snmpd.conf: line 145: Warning: Unknown token: defaultMonitors.
фев 05 16:09:39 wirenboard- snmpd[12389]: /etc/snmp/snmpd.conf: line 147: Warning: Unknown token: linkUpDownNotifications.
фев 05 16:09:39 wirenboard- systemd[1]: snmpd.service: Main process exited, code=exited, status=1/FAILURE
фев 05 16:09:39 wirenboard- systemd[1]: snmpd.service: Unit entered failed state.
фев 05 16:09:39 wirenboard- systemd[1]: snmpd.service: Failed with result ‘exit-code’.
Wirenboard release wb-2201 (as stable), target wb6/stretch
Воспроизвожу. После установки, перезапуска:
journalctl -u snmpd
-- Logs begin at Mon 2022-01-17 17:08:43 UTC, end at Mon 2022-02-07 07:53:53 UTC. --
Feb 07 07:53:02 wirenboard-ANHVBI4B systemd[1]: Starting Simple Network Management Protocol (SNMP) Daemon....
Feb 07 07:53:02 wirenboard-ANHVBI4B systemd[1]: Started Simple Network Management Protocol (SNMP) Daemon..
Feb 07 07:53:02 wirenboard-ANHVBI4B snmpd[21013]: pcilib: Cannot open /proc/bus/pci
Feb 07 07:53:02 wirenboard-ANHVBI4B snmpd[21013]: pcilib: Cannot find any working access method.
Feb 07 07:53:02 wirenboard-ANHVBI4B snmpd[21013]: pcilib: pci_init failed
Feb 07 07:53:03 wirenboard-ANHVBI4B snmpd[21013]: /etc/snmp/snmpd.conf: line 145: Warning: Unknown token: defaultMonitors.
Feb 07 07:53:03 wirenboard-ANHVBI4B snmpd[21013]: /etc/snmp/snmpd.conf: line 147: Warning: Unknown token: linkUpDownNotifications.
Feb 07 07:53:03 wirenboard-ANHVBI4B snmpd[21013]: Turning on AgentX master support.
Feb 07 07:53:03 wirenboard-ANHVBI4B snmpd[21013]: Created directory: /var/agentx
Feb 07 07:53:03 wirenboard-ANHVBI4B snmpd[21013]: NET-SNMP version 5.7.3
Есть ли место на контроллере?
my-wb
#4
Добрый день
Filesystem Size Used Avail Use% Mounted on
/dev/root 976M 730M 180M 81% /
devtmpfs 239M 0 239M 0% /dev
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 544K 247M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 248M 0 248M 0% /sys/fs/cgroup
/dev/mmcblk0p6 4.7G 338M 4.2G 8% /mnt/data
tmpfs 50M 0 50M 0% /run/user/0
кстати, вопрос. Влезет ли на него zigbee с тами местом?
Попробуйте запустить snmpd с отладкой, место есть.
Для NodeJS места, скорей всего, хватит, ставится-то он на mmcblk0p6
