Приветствую
при загрузке WB5 ругается на
failed systemd-tmpfiles-setup.service
Работе вроде явно не мешает. хотя как то странно, /var/og/messages не пишется уже давно. Может и не связано)
Ошибка вот такая:
● systemd-tmpfiles-setup.service - Create Volatile Files and Directories
Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-setup.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2016-11-03 20:31:24 MSK; 1 years 9 months ago
Docs: man:tmpfiles.d(5)
man:systemd-tmpfiles(8)
Main PID: 248 (code=exited, status=1/FAILURE)
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd-tmpfiles[248]: [/usr/lib/tmpfiles.d/systemd.conf:21] Unknown user ‘systemd-network’.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd-tmpfiles[248]: [/usr/lib/tmpfiles.d/systemd.conf:25] Unknown group ‘systemd-journal’.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd-tmpfiles[248]: [/usr/lib/tmpfiles.d/systemd.conf:26] Unknown group ‘systemd-journal’.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd-tmpfiles[248]: [/usr/lib/tmpfiles.d/systemd.conf:32] Unknown group ‘systemd-journal’.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd-tmpfiles[248]: [/usr/lib/tmpfiles.d/systemd.conf:33] Unknown group ‘systemd-journal’.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd-tmpfiles[248]: [/usr/lib/tmpfiles.d/systemd.conf:34] Unknown group ‘systemd-journal’.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd[1]: systemd-tmpfiles-setup.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd[1]: Failed to start Create Volatile Files and Directories.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd[1]: systemd-tmpfiles-setup.service: Unit entered failed state.
Nov 03 20:31:24 wirenboard-ABAMCBRO systemd[1]: systemd-tmpfiles-setup.service: Failed with result ‘exit-code’.
Надо куда-то копать?
