С последней прошивкой для wb5 не работает rfsniffer, ругается:
root@wirenboard-ABAMCBRO:/dev# apt-get install wb-homa-rfsniffer
Reading package lists… Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
wb-homa-rfsniffer : Depends: liblog4cpp5 but it is not installable
E: Unable to correct problems, you have held broken packages.
Прошивка: 201807181620_webupd_wb58_stretch.fit
Вот такая ошибка:
root@wirenboard-ABAMCBRO:~# apt-get install wb-homa-rfsniffer
The following NEW packages will be installed:
wb-homa-rfsniffer
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/111 kB of archives.
After this operation, 341 kB of additional disk space will be used.
dpkg: unrecoverable fatal error, aborting:
unknown group ‘crontab’ in statoverride file
W: No sandbox user ‘_apt’ on the system, can not drop privileges
E: Sub-process /usr/bin/dpkg returned an error code (2)
