Ошибка "Cannot load WebUI config.: File not found" после обновления
Wiren Board Web UI показывает ошибку Cannot load WebUI config.: File not found после обновления. Скорее всего связано с тем, что при обновлении apt-get update; apt-get upgrade вылезает ошибка конфигурирования пакета wb-configs:
Setting up wb-configs-stretch (1.81.0) ...
dpkg-divert: error: 'diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.wb-orig by wb-configs-stretch' clashes with 'diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.wb-orig by wb-configs'
dpkg: error processing package wb-configs-stretch (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of wb-configs:
 wb-configs depends on wb-configs-wheezy (>= 1.79.5) | wb-configs-stretch (>= 1.79.4); however:
  Package wb-configs-wheezy is not installed.
  Package wb-configs-stretch is not configured yet.
dpkg: error processing package wb-configs (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of wb-utils:
 wb-utils depends on wb-configs (>= 1.69.4); however:
  Package wb-configs is not configured yet.
полный лог
# apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
10 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
dpkg: error processing package wb-utils (--configure):
dpkg: dependency problems prevent configuration of wb-homa-ism-radio:
 wb-homa-ism-radio depends on wb-utils (>= 2.1.2); however:
  Package wb-utils is not configured yet.
dpkg: error processing package wb-homa-ism-radio (--configure):
dpkg: dependency problems prevent configuration of wb-homa-adc:
 wb-homa-adc depends on wb-utils (>= 2.0.4); however:
dpkg: error processing package wb-homa-adc (--configure):
dpkg: dependency problems prevent configuration of wb-hwconf-manager:
 wb-hwconf-manager depends on wb-utils (>= 2.1.2); however:
 wb-hwconf-manager depends on wb-configs (>= 1.63); however:
dpkg: error processing package wb-hwconf-manager (--configure):
dpkg: dependency problems prevent configuration of wb-mqtt-serial:
 wb-mqtt-serial depends on wb-utils (>= 2.0); however:
dpkg: error processing package wb-mqtt-serial (--configure):
dpkg: dependency problems prevent configuration of wb-mqtt-homeui:
 wb-mqtt-homeui depends on mqtt-wss; however:
  Package mqtt-wss is not installed.
  Package wb-configs which provides mqtt-wss is not configured yet.
 wb-mqtt-homeui depends on wb-utils (>= 2.0); however:
dpkg: error processing package wb-mqtt-homeui (--configure):
dpkg: dependency problems prevent configuration of wb-homa-gpio:
 wb-homa-gpio depends on wb-utils (>= 2.0); however:
dpkg: error processing package wb-homa-gpio (--configure):
dpkg: dependency problems prevent configuration of wb-test-suite:
 wb-test-suite depends on wb-hwconf-manager (>= 1.25); however:
  Package wb-hwconf-manager is not configured yet.
 wb-test-suite depends on wb-utils (>= 1.65); however:
 wb-test-suite depends on wb-homa-adc (>= 1.14.6); however:
  Package wb-homa-adc is not configured yet.
dpkg: error processing package wb-test-suite (--configure):
Errors were encountered while processing:
 wb-configs-stretch
 wb-configs
 wb-utils
 wb-homa-ism-radio
 wb-homa-adc
 wb-hwconf-manager
 wb-mqtt-serial
 wb-mqtt-homeui
 wb-homa-gpio
 wb-test-suite
E: Sub-process /usr/bin/dpkg returned an error code (1)
Запись в `/var/log/apt/history.log` с первой ошибкой и версиями пакетов до и после (отформатировал для удобства)
Start-Date: 2019-11-06  13:31:45
Commandline: apt-get upgrade wb-homa-adc wb-homa-gpio
Install: bc:armhf (1.06.95-9+b3, automatic), u-boot-tools-wb:armhf (2:2017.03+wb-2, automatic)
Upgrade: containerd.io:armhf          (1.2.5-1,                      1.2.10-3)
         libnghttp2-14:armhf          (1.18.1-1,                     1.18.1-1+deb9u1)
         libdbus-1-3:armhf            (1.10.26-0+deb9u1,             1.10.28-0+deb9u1)
         vim-common:armhf             (2:8.0.0197-4+deb9u1,          2:8.0.0197-4+deb9u3)
         libldap-2.4-2:armhf          (2.4.44+dfsg-5+deb9u2,         2.4.44+dfsg-5+deb9u3)
         wb-homa-adc:armhf            (1.14.3,                       1.14.6)
         openssl:armhf                (1.1.0j-1~deb9u1,              1.1.0l-1~deb9u1)
         libsystemd0:armhf            (232-25+deb9u11,               232-25+deb9u12)
         libgd3:armhf                 (2.2.4-2+deb9u4,               2.2.4-2+deb9u5)
         dbus:armhf                   (1.10.26-0+deb9u1,             1.10.28-0+deb9u1)
         libicu57:armhf               (57.1-6+deb9u2,                57.1-6+deb9u3)
         wb-configs:armhf             (1.75.3,                       1.81.0)
         openssh-sftp-server:armhf    (1:7.4p1-10+deb9u6,            1:7.4p1-10+deb9u7)
         udev:armhf                   (232-25+deb9u11,               232-25+deb9u12)
         libmagic1:armhf              (1:5.30-1+deb9u2,              1:5.30-1+deb9u3)
         wb-utils:armhf               (1.75.2,                       2.1.3)
         libexpat1:armhf              (2.2.0-2+deb9u1,               2.2.0-2+deb9u3)
         libudev1:armhf               (232-25+deb9u11,               232-25+deb9u12)
         wb-homa-gpio:armhf           (1.19,                         1.19.5)
         libmagic-mgc:armhf           (1:5.30-1+deb9u2,              1:5.30-1+deb9u3)
         systemd-sysv:armhf           (232-25+deb9u11,               232-25+deb9u12)
         libldap-common:armhf         (2.4.44+dfsg-5+deb9u2,         2.4.44+dfsg-5+deb9u3)
         vim-runtime:armhf            (2:8.0.0197-4+deb9u1,          2:8.0.0197-4+deb9u3)
         vim:armhf                    (2:8.0.0197-4+deb9u1,          2:8.0.0197-4+deb9u3)
         libpam-systemd:armhf         (232-25+deb9u11,               232-25+deb9u12)
         python-wb-common:armhf       (1.3.2,                        1.3.3)
         xxd:armhf                    (2:8.0.0197-4+deb9u1,          2:8.0.0197-4+deb9u3)
         openssh-server:armhf         (1:7.4p1-10+deb9u6,            1:7.4p1-10+deb9u7)
         unzip:armhf                  (6.0-21+deb9u1,                6.0-21+deb9u2)
         wb-homa-ism-radio:armhf      (1.17.1,                       1.17.3)
         openssh-client:armhf         (1:7.4p1-10+deb9u6,            1:7.4p1-10+deb9u7)
         wb-mqtt-serial:armhf         (1.43,                         1.55.0)
         usbutils:armhf               (1:007-4+b1,                   1:007-4+deb9u1)
         libglib2.0-data:armhf        (2.50.3-2,                     2.50.3-2+deb9u1)
         file:armhf                   (1:5.30-1+deb9u2,              1:5.30-1+deb9u3)
         wb-hwconf-manager:armhf      (1.21.2,                       1.29.0)
         libssl1.1:armhf              (1.1.0j-1~deb9u1,              1.1.0l-1~deb9u1)
         wb-mqtt-homeui:armhf         (1.7,                          2.0~beta12)
         wb-configs-stretch:armhf     (1.75.3,                       1.81.0)
         u-boot-tools:armhf           (2017.03+wb-1,                 2:2017.03+wb-2)
         libglib2.0-0:armhf           (2.50.3-2,                     2.50.3-2+deb9u1)
         debian-archive-keyring:armhf (2017.5,                       2017.5+deb9u1)
         docker-ce:armhf              (5:18.09.6~3-0~debian-stretch, 5:19.03.4~3-0~debian-stretch)
         libxslt1.1:armhf             (1.1.29-2.1,                   1.1.29-2.1+deb9u1)
         libssl1.0.2:armhf            (1.0.2r-1~deb9u1,              1.0.2t-1~deb9u1)
         base-files:armhf             (9.9+deb9u9,                   9.9+deb9u11)
         docker-ce-cli:armhf          (5:18.09.6~3-0~debian-stretch, 5:19.03.4~3-0~debian-stretch)
         tzdata:armhf                 (2019a-0+deb9u1,               2019c-0+deb9u1)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2019-11-06  13:37:51
Подскажите, как правильно это исправить, пожалуйста.
Попробуйте
apt install wb-configs wb-utils
и сюда полный текст команды и вывода.
Если не ошибаюсь, вывод apt всегда один и тот же на любую команду, полный лог под спойлером в оригинальном сообщении. Я попробую именно эту команду, спасибо, но скорее всего там то же самое.
@poglazov
root@wirenboard-AIKZ7GXF:~# apt install wb-configs wb-utils
wb-configs is already the newest version (1.81.0).
wb-utils is already the newest version (2.1.3).
wb-utils set to manually installed.
Do you want to continue? [Y/n] y
 wb-configs-stretch
 wb-configs
 wb-utils
 wb-homa-ism-radio
 wb-homa-adc
 wb-hwconf-manager
 wb-mqtt-serial
 wb-mqtt-homeui
Коллега говорит, что решение может оказаться долгим, и может быть проще обновиться через флешку https://wirenboard.com/wiki/index.php/Обновление_прошивки#.D0.9E.D0.B1.D0.BD.D0.BE.D0.B2.D0.BB.D0.B5.D0.BD.D0.B8.D0.B5_.D0.BF.D1.80.D0.BE.D1.88.D0.B8.D0.B2.D0.BA.D0.B8_.D1.81_.D0.BF.D0.BE.D0.BC.D0.BE.D1.89.D1.8C.D1.8E_USB-.D0.BD.D0.B0.D0.BA.D0.BE.D0.BF.D0.B8.D1.82.D0.B5.D0.BB.D1.8F (только внимательно прочитайте, какие файлы/настройки вы можете потерять).
Если такой вариант не подходит, то пришлите, пожалуйста, вывод cat /var/lib/dpkg/diversions
