Ошибка при переходе со Stretch на Bullseye
Попытался обновить дебиан на контроллере
Batch No
7.3.4B/2 680
Current uptime
21d 2h 17m
DTS Version
HW Revision
7.3.4
Manufacturing Date
2023-01-24 06:38:37
Release name
wb-2207-bullseye-transition
Release suite
stable
Short SN
AHLTC73O
Temperature Grade
industrial
И что-то пошло не так…
12:43:30 Get:15 Index of /debian-security bullseye-security/main Translation-en [297 kB]
12:43:30 Ign:13 Index of /debian bullseye-backports/main Translation-en
12:43:30 Ign:11 Index of /debian bullseye-backports/main all Packages
12:43:30 Err:12 Index of /debian bullseye-backports/main armhf Packages
12:43:30 404 Not Found [IP: 151.101.194.132 80]
12:43:31 Get:16 Index of /debian bullseye/main armhf Packages [7841 kB]
12:43:32 Get:17 Index of /debian bullseye/main Translation-en [6235 kB]
12:43:33 Get:18 Index of /debian bullseye-updates/main armhf Packages [16,3 kB]
12:43:33 Get:19 Index of /debian bullseye-updates/main Translation-en [10,5 kB]
12:43:37 Get:21 https://deb.wirenboard.com/wb7/bullseye stable/main armhf Packages [48,4 kB]
12:43:50 Fetched 15,0 MB in 21s (709 kB/s)
12:44:04 Reading package lists…
12:44:04 W: The repository ’ Index of /debian bullseye-backports Release’ does not have a Release file.
12:44:04 E: Failed to fetch http://deb.debian.org/debian/dists/bullseye-backports/main/binary-armhf/Packages 404 Not Found [IP: 151.101.194.132 80]
12:44:04 E: Some index files failed to download. They have been ignored, or old ones used instead.
12:44:04 Unholding packages (‘wb-update-manager’, ‘wb-release-info’)
12:44:05 Canceled hold on wb-update-manager.
12:44:05 Canceled hold on wb-release-info.
12:44:05 Cleaning up temp apt configs for bullseye transition
12:44:05 Restoring original system state
12:44:05 Generating /etc/apt/sources.list.d/wirenboard.list for SystemState(suite=‘stable’, target=‘wb7/stretch’, repo_prefix=‘’, consistent=True)
12:44:05 Generating /etc/apt/preferences.d/20wb-release for SystemState(suite=‘stable’, target=‘wb7/stretch’, repo_prefix=‘’, consistent=True)
12:44:05 Cleaning up apt cache (to make manual apt calls safe from now)
12:44:05
The subprocess (‘apt-get’, ‘-q’, ‘update’, ‘-o’, ‘Dpkg::Options::=–force-confdef’, ‘-o’, ‘Dpkg::Options::=–force-confold’, ‘–allow-downgrades’) ha
s failed with status 100
12:44:05 Try running wb-release --update-debian-release again to continue transition
С ходу рецепта не нашел. Подскажите пожалуйста
После перезагрузки:
Locale is already set, skipping…
Removing ‘diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.wb-orig by wb-configs’
*** OMINOUS WARNING ***: /etc/hostname is not linked to either hostname.wb or hostname.wb-orig
*** OMINOUS WARNING ***: /etc/fstab is not linked to either fstab.wb or fstab.wb-orig
*** OMINOUS WARNING ***: /etc/network/interfaces is not linked to either interfaces.wb or interfaces.wb-orig
*** OMINOUS WARNING ***: /etc/dnsmasq.conf is not linked to either dnsmasq.conf.wb or dnsmasq.conf.wb-orig
*** OMINOUS WARNING ***: /etc/hostapd.conf is not linked to either hostapd.conf.wb or hostapd.conf.wb-orig
Adding ‘diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.wb-orig by wb-configs’
Failed to get unit file state for rsyslog.service: No such file or directory
rsyslog is a disabled or a static unit not running, not starting it.
Setting ownership www-data to /mnt/data/uploads
Job for mosquitto.service failed because the control process exited with error code.
See “systemctl status mosquitto.service” and “journalctl -xe” for details.
dpkg: error processing package wb-configs (–configure):
installed wb-configs package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
wb-configs
E: Sub-process /usr/bin/dpkg returned an error code (1)
Москито запустился. Почему-то у него не было доступа к его конфигам. Видимо, неудачно отвалилась установка…
Обратите внимание пожалуйста, что репозитории для bullseye уже не существуют.
Вот тут описано, в том числе и про смену репозиториев.
Спасибо большое!
Кое как поборол. Интересно, что более ранние контроллеры без проблем обновились, а вот этот прям гад какой-то…
