Не работает команда обновления до Bullseye
При загрузке предлагается обновиться:
Welcome to Wiren Board 7.2.1 (s/n ACZVEF3I), release wb-2207 (as stable)
Linux wb 5.10.35-wb120 #1 SMP Fri Sep 2 07:33:43 UTC 2022 armv7l GNU/Linux
Update to Debian Bullseye is available!
Run wb-release --update-debian-release to update
Но при вводе команды ошибка:
root@wb:~# wb-release --update-debian-release
usage: wb-release [-h] [-r] [-t TARGET_RELEASE] [-v] [-y] [-p]
                  [-l LOG_FILENAME] [--no-journald-log]
                  [--reset-url | --prefix PREFIX] [--no-preliminary-update]
wb-release: error: unrecognized arguments: --update-debian-release
После переключения на testing команда заработала, но завершилась ошибкой:
12:06:22 The following packages were automatically installed and are no longer required:
12:06:22   cgmanager dh-python gnupg-agent libbind9-140 libc-ares2 libcgmanager0
12:06:22   libcryptsetup4 libdns-export162 libdns162 libestr0 libevent-2.0-5
12:06:22   libfastjson4 libffi6 libgdbm3 libhogweed4 libicu57 libio-stringy-perl
12:06:22   libip4tc0 libip6tc0 libiptc0 libisc-export160 libisc160 libisccc140
12:06:22   libisccfg140 liblogging-stdlog0 liblognorm5 liblwres141 libmpdec2
12:06:22   libncurses5 libnettle6 libnih-dbus1 libnih1 libonig4 libprocps6
12:06:22   libpython3.5-minimal libpython3.5-stdlib libreadline7 libslang2 libssl1.0.2
12:06:22   libtinyxml2-4 libunistring0 libwebsockets8 mc-data python-dateutil
12:06:22   python-json-rpc python-mosquitto python-mqttrpc python-progressbar
12:06:22   python-pyparsing python3.5 python3.5-minimal rename rsyslog sgml-base sudo
12:06:22   tcpd xml-core
12:06:22 Use 'apt autoremove' to remove them.
12:06:22 The following packages will be REMOVED:
12:06:22   e2fslibs
12:06:22 The following NEW packages will be installed:
12:06:22   e2fsprogs-l10n libext2fs2 logsave
12:06:22 The following packages have been kept back:
12:06:22   dh-python
12:06:22 The following packages will be upgraded:
12:06:22   e2fsprogs
12:06:22 The following packages will be DOWNGRADED:
12:06:22   wb-release-info
12:06:23 1 upgraded, 3 newly installed, 1 downgraded, 1 to remove and 1 not upgraded.
12:06:23 Need to get 1454 kB of archives.
12:06:23 After this operation, 750 kB of additional disk space will be used.
12:06:23 Get:1 http://deb.wirenboard.com/wb7/bullseye testing/main armhf libext2fs2 armhf 1.46.2-2+wb1 [241 kB]
12:06:23 Get:2 http://deb.wirenboard.com/wb7/bullseye testing/main armhf logsave armhf 1.46.2-2+wb1 [74.5 kB]
12:06:23 Get:3 http://deb.wirenboard.com/wb7/bullseye testing/main armhf e2fsprogs armhf 1.46.2-2+wb1 [591 kB]
12:06:24 Err:4 http://deb.wirenboard.com/wb7/bullseye testing/main armhf wb-release-info all 1.0-testing~wb7+bullseye~20221130152457
12:06:24   404  Not Found [IP: 52.218.120.172 80]
12:06:24 Get:5 http://deb.wirenboard.com/wb7/bullseye testing/main armhf e2fsprogs-l10n all 1.46.2-2+wb1 [546 kB]
12:06:24 Fetched 1452 kB in 2s (758 kB/s)
12:06:24 W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:1 and /etc/apt/sources.list.d/debian-upstream.list:1
12:06:24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:1 and /etc/apt/sources.list.d/debian-upstream.list:1
12:06:24 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:1 and /etc/apt/sources.list.d/debian-upstream.list:1
12:06:24 W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:2 and /etc/apt/sources.list.d/debian-upstream.list:2
12:06:24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:2 and /etc/apt/sources.list.d/debian-upstream.list:2
12:06:24 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:2 and /etc/apt/sources.list.d/debian-upstream.list:2
12:06:24 W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:3 and /etc/apt/sources.list.d/debian-upstream.list:3
12:06:24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:3 and /etc/apt/sources.list.d/debian-upstream.list:3
12:06:24 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:3 and /etc/apt/sources.list.d/debian-upstream.list:3
12:06:24 W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:4 and /etc/apt/sources.list.d/debian-upstream.list:4
12:06:24 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:4 and /etc/apt/sources.list.d/debian-upstream.list:4
12:06:24 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/debian-upstream-bullseye-temp.list:4 and /etc/apt/sources.list.d/debian-upstream.list:4
12:06:24 E: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/pool/main/w/wb-release-info/wb-release-info_1.0-testing%7ewb7%2bbullseye%7e20221130152457_all.deb  404  Not Found [IP: 52.218.120.172 80]
12:06:24 E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Как завершить обновление корректно?
bullseye.txt (235.4 КБ)
Выполнил apt update && upgrade, достаточно ли этого ?
root@wb:~# apt update
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:4 https://download.docker.com/linux/debian stretch InRelease [44.8 kB]
Get:5 http://deb.wirenboard.com/wb7/stretch testing InRelease [3960 B]
Get:6 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
Get:7 https://download.zerotier.com/debian/stretch stretch InRelease [33.6 kB]
Get:9 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
Get:8 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease [99.9 kB]
Get:10 http://security.debian.org/debian-security bullseye-security/main armhf Packages [204 kB]
Get:11 http://security.debian.org/debian-security bullseye-security/main Translation-en [135 kB]
Get:12 http://deb.debian.org/debian bullseye/main armhf Packages [7944 kB]
Get:13 http://deb.debian.org/debian bullseye/main Translation-en [6239 kB]
Get:14 http://deb.debian.org/debian bullseye-updates/main armhf Packages [12.0 kB]
Get:15 http://deb.debian.org/debian bullseye-updates/main Translation-en [7929 B]
Get:16 http://deb.wirenboard.com/wb7/stretch testing/main armhf Packages [46.6 kB]
Get:17 https://download.docker.com/linux/debian stretch/stable armhf Packages [15.5 kB]
Get:18 http://deb.debian.org/debian bullseye-backports/main armhf Packages [358 kB]
Get:19 http://deb.debian.org/debian bullseye-backports/main Translation-en [299 kB]
Get:20 https://download.zerotier.com/debian/stretch stretch/main armhf Packages [5735 B]
Get:21 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [781 B]
Get:22 http://cdn-fastly.deb.debian.org/debian stretch-backports/main armhf Packages [600 kB]
Get:23 http://cdn-fastly.deb.debian.org/debian stretch-backports/main Translation-en [467 kB]
Fetched 16.8 MB in 24s (709 kB/s)
Reading package lists... Done
Building dependency tree... Done
7 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@wb:~# apt list --upgradable
Listing... Done
dh-python/stable 4.20201102+nmu1 all [upgradable from: 2.20170125]
libcom-err2/bullseye-backports 1.46.5-2~bpo11+2 armhf [upgradable from: 1.46.2-2+wb1]
libip4tc0/stretch-backports 1.6.2-1.1~bpo9+1 armhf [upgradable from: 1.6.0+snapshot20161117-6]
libip6tc0/stretch-backports 1.6.2-1.1~bpo9+1 armhf [upgradable from: 1.6.0+snapshot20161117-6]
libss2/bullseye-backports 1.46.5-2~bpo11+2 armhf [upgradable from: 1.46.2-2+wb1]
linux-libc-dev/stable-security 5.10.149-2 armhf [upgradable from: 5.10.35-wb123]
wb-release-info/testing 1.0-testing~wb7+stretch~20221201045721 all [upgradable from: 1.0-testing~wb7+stretch~20221201042921]
root@wb:~# apt upgrade
Calculating upgrade... Done
  cgmanager dh-python gnupg-agent libbind9-140 libc-ares2 libcgmanager0 libcryptsetup4 libdns-export162 libdns162 libestr0 libevent-2.0-5 libfastjson4 libffi6 libgdbm3 libhogweed4
  libicu57 libio-stringy-perl libip4tc0 libip6tc0 libiptc0 libisc-export160 libisc160 libisccc140 libisccfg140 liblogging-stdlog0 liblognorm5 liblwres141 libmpdec2 libncurses5
  libnettle6 libnih-dbus1 libnih1 libonig4 libprocps6 libpython3.5-minimal libpython3.5-stdlib libreadline7 libslang2 libssl1.0.2 libtinyxml2-4 libunistring0 libwebsockets8 mc-data
  python-dateutil python-json-rpc python-mosquitto python-mqttrpc python-progressbar python-pyparsing python3.5 python3.5-minimal rename rsyslog sgml-base sudo tcpd xml-core
  dh-python
  libcom-err2 libip4tc0 libip6tc0 libss2 linux-libc-dev wb-release-info
6 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 1808 kB of archives.
After this operation, 76.8 kB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 http://security.debian.org/debian-security bullseye-security/main armhf linux-libc-dev armhf 5.10.149-2 [1519 kB]
Get:2 http://deb.debian.org/debian bullseye-backports/main armhf libcom-err2 armhf 1.46.5-2~bpo11+2 [75.1 kB]
Get:3 http://deb.debian.org/debian bullseye-backports/main armhf libss2 armhf 1.46.5-2~bpo11+2 [78.7 kB]
Get:4 http://deb.wirenboard.com/wb7/stretch testing/main armhf wb-release-info all 1.0-testing~wb7+stretch~20221201045721 [1590 B]
Get:5 http://http.debian.net/debian stretch-backports/main armhf libip4tc0 armhf 1.6.2-1.1~bpo9+1 [66.7 kB]
Get:6 http://http.debian.net/debian stretch-backports/main armhf libip6tc0 armhf 1.6.2-1.1~bpo9+1 [66.9 kB]
Fetched 1808 kB in 2s (1149 kB/s)
(Reading database ... 34365 files and directories currently installed.)
Preparing to unpack .../libcom-err2_1.46.5-2~bpo11+2_armhf.deb ...
Unpacking libcom-err2:armhf (1.46.5-2~bpo11+2) over (1.46.2-2+wb1) ...
Setting up libcom-err2:armhf (1.46.5-2~bpo11+2) ...
Preparing to unpack .../libss2_1.46.5-2~bpo11+2_armhf.deb ...
Unpacking libss2:armhf (1.46.5-2~bpo11+2) over (1.46.2-2+wb1) ...
Setting up libss2:armhf (1.46.5-2~bpo11+2) ...
Preparing to unpack .../wb-release-info_1.0-testing~wb7+stretch~20221201045721_all.deb ...
Unpacking wb-release-info (1.0-testing~wb7+stretch~20221201045721) over (1.0-testing~wb7+stretch~20221201042921) ...
Setting up wb-release-info (1.0-testing~wb7+stretch~20221201045721) ...
Preparing to unpack .../libip4tc0_1.6.2-1.1~bpo9+1_armhf.deb ...
Unpacking libip4tc0:armhf (1.6.2-1.1~bpo9+1) over (1.6.0+snapshot20161117-6) ...
Preparing to unpack .../libip6tc0_1.6.2-1.1~bpo9+1_armhf.deb ...
Unpacking libip6tc0:armhf (1.6.2-1.1~bpo9+1) over (1.6.0+snapshot20161117-6) ...
Preparing to unpack .../linux-libc-dev_5.10.149-2_armhf.deb ...
Unpacking linux-libc-dev:armhf (5.10.149-2) over (5.10.35-wb123) ...
Setting up libip6tc0:armhf (1.6.2-1.1~bpo9+1) ...
Setting up libip4tc0:armhf (1.6.2-1.1~bpo9+1) ...
Setting up linux-libc-dev:armhf (5.10.149-2) ...
Processing triggers for libc-bin (2.31-13+deb11u5) ...
root@wb:~#
После перезагрузки пишет такое:
Welcome to Wiren Board 7.2.1 (s/n ACZVEF3I), release wb-2207-bullseye-transition (as testing)
Linux wb 5.10.35-wb123 #1 SMP Mon Nov 21 10:53:14 UTC 2022 armv7l GNU/Linux
 There are potentially obsolete sources lists in:
  * /etc/apt/sources.list.d/docker.list
  * /etc/apt/sources.list.d/stretch-backports.list
  * /etc/apt/sources.list.d/wirenboard.list
  * /etc/apt/sources.list.d/zerotier.list
 Please modify these files manually.
Здравствуйте! Полагаю, что обновление прошло не до конца.
Попробуйте удалить /etc/apt/sources.list.d/stretch-backports.list и после этого сделайте
apt update && apt dist-upgrade -y
Подключу еще разработчиков: @webconn
root@wb:~# rm /etc/apt/sources.list.d/stretch-backports.list
root@wb:~# apt update && apt dist-upgrade -y
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
Hit:5 http://deb.wirenboard.com/wb7/stretch testing InRelease
Hit:6 https://download.docker.com/linux/debian bullseye InRelease
Hit:7 https://download.zerotier.com/debian/bullseye bullseye InRelease
Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
All packages are up to date.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Покажите вывод команды
wb-release
и пришлите, пожалуйста, архив с диагностической информацией контроллера. Создание архива описано в документации.
# wb-release
Wirenboard release wb-2207-bullseye-transition (as testing), target wb7/stretch
You can get this info in scripts from /usr/lib/wb-release.
diag_ACZVEF3I_2022-12-01-13.14.11.zip (93.4 КБ)
Скрипт перехода не отработал полностью. Разработчики советуют обновиться с помощью fit-образа и обещают исправить данную проблему в будущем:
http://fw-releases.wirenboard.com/fit_image/testing/7x/latest.fit
Про обновление можно почитать в документации: Обновление прошивки контроллера Wiren Board — Wiren Board
