Как можно починить следующую ситуацию? Не удается выставить regulatory domain.
root@wirenboard:~# cat /etc/default/crda
# Set REGDOMAIN to a ISO/IEC 3166-1 alpha2 country code so that iw(8) may set
# the initial regulatory domain setting for IEEE 802.11 devices which operate
# on this system.
# Governments assert the right to regulate usage of radio spectrum within
# their respective territories so make sure you select a ISO/IEC 3166-1 alpha2
# country code suitable for your location or you may infringe on local
# legislature. See `/usr/share/zoneinfo/zone.tab’ for a table of timezone
# descriptions containing ISO/IEC 3166-1 alpha2 country codes.
REGDOMAIN=RU
root@wirenboard:~#
root@wirenboard:~#
root@wirenboard:~# iw reg get
country AL:
(2402 - 2482 @ 40), (N/A, 20)
(5170 - 5250 @ 80), (N/A, 20)
(5250 - 5330 @ 80), (N/A, 20), DFS
(5490 - 5710 @ 80), (N/A, 27), DFS
root@wirenboard:~#
root@wirenboard:~#
root@wirenboard:~#uname -a
Linux wirenboard 3.13.0-imxv5-x0.1 #50 Sat May 10 19:57:01 MSK 2014 armv5tejl GNU/Linux
root@wirenboard:~# lsmod
Module Size Used by
sc16is7x2 10598 0
rtl8192cu 96271 0
rtl_usb 14208 1 rtl8192cu
rtlwifi 88715 2 rtl_usb,rtl8192cu
rtl8192c_common 65331 1 rtl8192cu
smsc95xx 19171 2
mcp251x 10745 0
can_dev 10091 1 mcp251x
w1_gpio 2946 0
wire 25336 1 w1_gpio
cn 4802 1 wire
root@wirenboard:~#
