После перезагрузки, слетают настройки /etc/wb-mqtt-serial.conf Симптомы 1 в 1 как в этой теме После перезагрузки содержимое /etc/wb-mqtt-serial.conf возвращается к прежнему виду
mosquitto_sub -v -t “/rpc/#”
/rpc/v1/confed/Editor/List 1
/rpc/v1/confed/Editor/Load 1
/rpc/v1/confed/Editor/Save 1
/rpc/v1/db_logger/history/get_channels 1
/rpc/v1/db_logger/history/get_values 1
/rpc/v1/wbrules/Editor/ChangeState 1
/rpc/v1/wbrules/Editor/List 1
/rpc/v1/wbrules/Editor/Load 1
/rpc/v1/wbrules/Editor/Remove 1
/rpc/v1/wbrules/Editor/Save 1
/rpc/v1/confed/Editor/List/QzufyCat {“id”:1,“params”:{}}
/rpc/v1/confed/Editor/List/QzufyCat/reply {“id”:1,“result”:[{“title”:“Network Interface Configuration”,“description”:“Specifies network configuration of the system”,“configPath”:"/etc/network/interfaces",“schem
aPath”:"/usr/share/wb-mqtt-confed/schemas/interfaces.schema.json"},{“title”:“NTP configuration”,“description”:“Specifies NTP network time sync daemon configuration”,“configPath”:"/etc/ntp.conf",“schemaPath”:"/u
sr/share/wb-mqtt-confed/schemas/ntp.schema.json"},{“title”:“Hardware Modules Configuration”,“description”:“Lists additional hardware modules configuration”,“configPath”:"/etc/wb-hardware.conf",“schemaPath”:"/us
r/share/wb-mqtt-confed/schemas/wb-hardware.schema.json"},{“title”:“ADC Driver Configuration”,“description”:“Analog inputs configuration”,“configPath”:"/etc/wb-mqtt-adc.conf",“schemaPath”:"/usr/share/wb-mqtt-con
fed/schemas/wb-mqtt-adc.schema.json"},{“title”:“Analog Outputs Configuration”,“description”:"",“configPath”:"/etc/wb-mqtt-dac.conf",“schemaPath”:"/usr/share/wb-mqtt-confed/schemas/wb-mqtt-dac.schema.json"},{“ti
tle”:“MQTT History Configuration”,“description”:"",“configPath”:"/etc/wb-mqtt-db.conf",“schemaPath”:"/usr/share/wb-mqtt-confed/schemas/wb-mqtt-db.schema.json"},{“title”:“GPIO Driver Configuration Type”,“descrip
tion”:“Digital inputs and outputs configuration”,“configPath”:"/etc/wb-mqtt-gpio.conf",“schemaPath”:"/usr/share/wb-mqtt-confed/schemas/wb-mqtt-gpio.schema.json"},{“title”:“MQTT to Modbus TCP and RTU slave gatew
ay configuration”,“description”:"",“configPath”:"/etc/wb-mqtt-mbgate.conf",“schemaPath”:"/usr/share/wb-mqtt-confed/schemas/wb-mqtt-mbgate.schema.json"},{“title”:“Serial Device Driver Configuration”,“description
“:“Lists devices attached to RS-485 ports”,“configPath”:”/etc/wb-mqtt-serial.conf”,“schemaPath”:"/usr/share/wb-mqtt-confed/wb-mqtt-serial.schema.json"},{“title”:“Alarm Configuration”,“description”:“Lists alarms
“,“configPath”:”/etc/wb-rules/alarms.conf”,“schemaPath”:"/usr/share/wb-mqtt-confed/schemas/alarms.schema.json"},{“title”:“WebUI Configuration”,“description”:“For internal use, edit with caution”,“configPath”:"/
etc/wb-webui.conf",“schemaPath”:"/usr/share/wb-mqtt-confed/schemas/webui.schema.json"}]}
/rpc/v1/confed/Editor/List/YIDrgAVy {“id”:1,“params”:{}}
/rpc/v1/confed/Editor/List/YIDrgAVy/reply {“id”:1,“result”:[{“title”:“Network Interface Configuration”,“description”:“Specifies network configuration of the system”,“configPath”:"/etc/network/interfaces",“schem
