Не могу установить ноду node-red-node-serialport
При попытке установить ноду выдает:
npm ERR! code 1
npm ERR! path /mnt/data/root/node_modules/@serialport/bindings-cpp
npm ERR! command failed
npm ERR! command sh -c node-gyp-build
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.0.0
npm ERR! gyp info using node@14.19.3 | linux | arm
npm ERR! gyp ERR! find Python
npm ERR! gyp ERR! find Python Python is not set from command line or npm configuration
npm ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
npm ERR! gyp ERR! find Python checking if “python3” can be used
npm ERR! gyp ERR! find Python - executable path is “/usr/bin/python3”
npm ERR! gyp ERR! find Python - version is “3.5.3”
npm ERR! gyp ERR! find Python - version is 3.5.3 - should be >=3.6.0
npm ERR! gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
npm ERR! gyp ERR! find Python checking if “python” can be used
npm ERR! gyp ERR! find Python - executable path is “/usr/bin/python”
npm ERR! gyp ERR! find Python - version is “2.7.13”
npm ERR! gyp ERR! find Python - version is 2.7.13 - should be >=3.6.0
npm ERR! gyp ERR! find Python **********************************************************
npm ERR! gyp ERR! find Python You need to install the latest version of Python.
npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
npm ERR! gyp ERR! find Python you can try one of the following options:
npm ERR! gyp ERR! find Python - Use the switch --python=“/path/to/pythonexecutable”
npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)
npm ERR! gyp ERR! find Python - Set the environment variable PYTHON
npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
npm ERR! gyp ERR! find Python npm config set python “/path/to/pythonexecutable”
npm ERR! gyp ERR! find Python For more information consult the documentation at:
npm ERR! gyp ERR! find Python GitHub - nodejs/node-gyp: Node.js native addon build tool
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Could not find any Python installation to use
npm ERR! gyp ERR! stack at PythonFinder.fail (/mnt/data/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:330:47)
npm ERR! gyp ERR! stack at PythonFinder.runChecks (/mnt/data/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:159:21)
npm ERR! gyp ERR! stack at PythonFinder. (/mnt/data/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:266:16)
npm ERR! gyp ERR! stack at PythonFinder.execFileCallback (/mnt/data/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/find-python.js:297:7)
npm ERR! gyp ERR! stack at ChildProcess.exithandler (child_process.js:374:7)
npm ERR! gyp ERR! stack at ChildProcess.emit (events.js:400:28)
npm ERR! gyp ERR! stack at maybeClose (internal/child_process.js:1088:16)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:296:5)
npm ERR! gyp ERR! System Linux 5.10.35-wb111
npm ERR! gyp ERR! command “/usr/local/bin/node” “/mnt/data/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
npm ERR! gyp ERR! cwd /mnt/data/root/node_modules/@serialport/bindings-cpp
npm ERR! gyp ERR! node -v v14.19.3
npm ERR! gyp ERR! node-gyp -v v9.0.0
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-06-19T12_03_00_240Z-debug-0.log
Я так понимаю, не устраивает версия python3? Как можно решить эту проблему? Очень нужен доступ к GSM модему из Node-red
Да, версия python требуется 3.6 или выше.
Как вариант установить дополнительно еще и более новую версию. Похожее обсуждение было здесь:
Я не очень силен в сборке приложений из исходников, можете подсказать, если я поставлю по этой инструкции, я не сломаю родной python3?
Я вообще не очень понимаю, как потом будет делаться выбор, в каком случае будет использоваться системный питон, а в каком собранный мной?
В системе установлен питон 2.7 и он используется в системных скриптах. Простая установка другой версии - сломает часть функционала.
Но почему не хотите добавить в конфиг другую, требуемую, версию как рекомендуется:
cd /usr/src
wget https://www.python.org/ftp/python/3.6.4/Python-3.6.4.tgz
tar xvf Python-3.6.4.tgz
cd Python-3.6.4
./configure --enable-optimizations
make -j8
Естественно делать лучше не на контроллере, (место, медленно).
Неплохо почитать для общей информации тут: Как переключить дефолтную версию Python в Debian 9
Но вкратце симлинк /usr/bin/python долже указывать на /usr/bin/python2.7
