После обновления не запускается. Статус и Лог:
root@wirenboard-AQXRWOCR:~# systemctl status zigbee2mqtt
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2025-07-26 16:12:46 MSK; 38min ago
Process: 8551 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 8551 (code=exited, status=1/FAILURE)
CPU: 28.508s
Jul 26 16:11:15 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Consumed 28.508s CPU time.
Jul 26 16:12:46 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart coun>
Jul 26 16:12:46 wirenboard-AQXRWOCR systemd[1]: Stopped zigbee2mqtt.
Jul 26 16:12:46 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Consumed 28.508s CPU time.
Jul 26 16:12:46 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Start request repeated too quickly.
Jul 26 16:12:46 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Failed with result ‘exit-code’.
Jul 26 16:12:46 wirenboard-AQXRWOCR systemd[1]: Failed to start zigbee2mqtt.
Jul 26 16:57:28 wirenboard-AQXRWOCR wb-mqtt-serial[1561]: WARNING: </dev/ttyRS485-2 2400 8 N 1>: closed >
Jul 26 16:57:30 wirenboard-AQXRWOCR npm[1091]: > zigbee2mqtt@2.1.1 start
Jul 26 16:57:30 wirenboard-AQXRWOCR npm[1091]: > node index.js
Jul 26 16:57:32 wirenboard-AQXRWOCR npm[1159]: Starting Zigbee2MQTT without watchdog.
Jul 26 16:57:34 wirenboard-AQXRWOCR wb-mqtt-serial[1561]: WARNING: </dev/ttyRS485-2 2400 8 N 1>: closed >
Jul 26 16:57:37 wirenboard-AQXRWOCR NetworkManager[488]: [1753538257.1401] audit: op="connection>
Jul 26 16:57:37 wirenboard-AQXRWOCR NetworkManager[488]: [1753538257.4552] audit: op="connection>
Jul 26 16:57:39 wirenboard-AQXRWOCR wb-mqtt-serial[1561]: WARNING: </dev/ttyRS485-2 2400 8 N 1>: closed >
Jul 26 16:57:44 wirenboard-AQXRWOCR wb-mqtt-serial[1561]: WARNING: </dev/ttyRS485-2 2400 8 N 1>: closed >
Jul 26 16:57:46 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:46] info: z2m: Logging to conso>
Jul 26 16:57:46 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:46] info: z2m: Starting Zigbee2>
Jul 26 16:57:46 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:46] info: z2m: Starting zigbee->
Jul 26 16:57:47 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:47] info: zh:zstack:znp: Openin>
Jul 26 16:57:47 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:47] info: zh:zstack:znp: Serial>
Jul 26 16:57:47 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:47] error: zh:adapter:zstack:ma>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:48] error: zh:adapter:zstack:ma>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:48] error: z2m: Error while sta>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:48] error: z2m: Failed to start>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:48] error: z2m: Check https://w>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:48] error: z2m: Exiting…
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: [2025-07-26 16:57:48] error: z2m: Error: startup >
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at ZnpAdapterManager.determineStrategy (/mnt/data/roo>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at ZnpAdapterManager.start (/mnt/data/root/zigbee2mqt>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at ZStackAdapter.start (/mnt/data/root/zigbee2mqtt/no>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at Controller.start (/mnt/data/root/zigbee2mqtt/node_>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbe>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at Controller.start (/mnt/data/root/zigbee2mqtt/lib/c>
Jul 26 16:57:48 wirenboard-AQXRWOCR npm[1159]: at start (/mnt/data/root/zigbee2mqtt/index.js:161:5)
Jul 26 16:57:48 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, s>
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: Debian -- User Support
░░ An ExecStart= process belonging to unit zigbee2mqtt.service has exited.
░░ The process’ exit code is ‘exited’ and its exit status is 1.
Jul 26 16:57:48 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Failed with result ‘exit-code’.
░░ Subject: Unit failed
░░ The unit zigbee2mqtt.service has entered the ‘failed’ state with result ‘exit-code’.
Jul 26 16:57:48 wirenboard-AQXRWOCR systemd[1]: zigbee2mqtt.service: Consumed 28.590s CPU time.
