После обновления с помощью apt update; apt upgrade до wb-2401 обнаружил, что dmesg выдает ошибки.
Сделал Factoryreset через web-интерфейс с установкой wb-2401, ошибки повторились. Wiren Board 7.3.4 (s/n AQBSK2LH), release wb-2401 (as stable). Диагностический архив и выдачу dmesg прилагаю.
Прошу помочь.
[ 0.004227] /cpus/cpu@0 missing clock-frequency property
[ 0.004279] /cpus/cpu@1 missing clock-frequency property
[ 0.004328] /cpus/cpu@2 missing clock-frequency property
[ 0.004381] /cpus/cpu@3 missing clock-frequency property
[ 1.465972] sun4i-usb-phy 1c13400.phy: Couldn’t request ID GPIO
[ 1.647148] sun4i-usb-phy 1c13400.phy: Couldn’t request ID GPIO
[ 2.634039] sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PI regulator
[ 2.640854] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
[ 2.647519] sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
[ 2.654971] sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18 on device 1c20800.pinctrl
[ 2.665823] dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
[ 2.674458] sun4i-mdio 1c0b080.mdio: supply phy not found, using dummy regulator
[ 2.683853] libphy: sun4i_mii_bus: probed
[ 2.689770] sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PH regulator
[ 2.696618] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
[ 2.703260] sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
[ 2.713439] sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PH regulator
[ 2.720304] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
[ 2.727028] sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
[ 2.734557] sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8 on device 1c20800.pinctrl
[ 2.745095] sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
[ 2.754777] sun4i-pinctrl 1c20800.pinctrl: Couldn’t get bank PA regulator
[ 2.761579] sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
[ 2.768040] sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
[ 2.775424] sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0 on device 1c20800.pinctrl
[ 2.785914] dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
[ 2.848840] vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
dmesg-log.txt (26,6 КБ)
