Проблема с 4g модулем
Модем явно не включился.
По DEBUG=true wb-gsm restart_if_broken не включается? Что выводит?
root@wirenboard-A3VCMPDR:~# DEBUG=true wb-gsm restart_if_broken
DEBUG: main: Called from pid 3831 (bash)
DEBUG: guess_of_node: Got of_gsm_node: /soc/bus@2100000/usb@2184200/usb-hub@1/wbc-modem@2
DEBUG: restart_if_broken: Modem switched off, switch it on instead of testing the connection
DEBUG: ensure_on: switching on GSM modem using POWER FET
DEBUG: toggle: toggle GSM modem state using PWRKEY
[ 4355.194791] usb 2-1.3: new high-speed USB device number 80 using ci_hdrc
DEBUG: ensure_on: Waiting for modem to start
[ 4355.360038] usb 2-1.3: New USB device found, idVendor=1286, idProduct=812a, bcdDevice= 0.00
[ 4355.368591] usb 2-1.3: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 4355.376087] usb 2-1.3: Product: WUKONG
[ 4355.379881] usb 2-1.3: Manufacturer: MARVELL
[ 4355.666649] usb 2-1.3: USB disconnect, device number 80
DEBUG: init_usb_connection: Will wait up to 30s untill usb port becomes available
[ 4361.854853] usb 2-1.3: new high-speed USB device number 81 using ci_hdrc
[ 4362.015337] usb 2-1.3: config 1 has an invalid interface number: 5 but max is 4
[ 4362.022696] usb 2-1.3: config 1 has no interface number 3
[ 4362.044337] usb 2-1.3: New USB device found, idVendor=1e0e, idProduct=9011, bcdDevice= 1.00
[ 4362.052783] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4362.060155] usb 2-1.3: Product: Mobile Composite Device Bus
[ 4362.065764] usb 2-1.3: Manufacturer: Marvell
[ 4362.070039] usb 2-1.3: SerialNumber: 200806006809080000
[ 4362.128338] rndis_host 2-1.3:1.0 usb0: register 'rndis_host' at usb-ci_hdrc.1-1.3, RNDIS device, 36:7f:44:c7:5f:76
[ 4362.164993] option 2-1.3:1.2: GSM modem (1-port) converter detected
[ 4362.188981] usb 2-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 4362.211739] option 2-1.3:1.4: GSM modem (1-port) converter detected
[ 4362.235730] usb 2-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 4362.261777] option 2-1.3:1.5: GSM modem (1-port) converter detected
[ 4362.281119] usb 2-1.3: GSM modem (1-port) converter now attached to ttyUSB2
DEBUG: probe_usb_ports: Probing all modem's usb ports
DEBUG: test_connection: (port:/dev/ttyUSB1; timeout:2) => 0
DEBUG: probe_usb_ports: Modem's usb ports: ttyUSB0 ttyUSB1 ttyUSB2
DEBUG: probe_usb_ports: Answered to 'AT': /dev/ttyUSB1
DEBUG: init_usb_connection: Got modem model a7600x from dtso => reversing port symlinks
DEBUG: link_ports: /dev/ttyUSB1 => /dev/ttyGSM0
DEBUG: link_ports: /dev/ttyGSM0 => /dev/ttyGSM
DEBUG: test_connection: (port:/dev/ttyGSM; timeout:5) => 0
Если нужен коннект до устройства, что-то посмотреть, потестить готов дать.
Если модем продолжает не включаться - тогда да, интересно.
Пока не нужно, пару раз перезапускал,вроде норм, на своей стороне нашел ошибку.
