Да нет, тут, второй строчкой. Благодарю.
Воспроизводится к сожалению.
Входящий звонок отключает GPRS:
Apr 19 13:24:52 wirenboard-AWI3MCGC ntpd[21837]: Soliciting pool server 2a00:18c0:1:1::5
Apr 19 13:24:55 wirenboard-AWI3MCGC systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Apr 19 13:25:08 wirenboard-AWI3MCGC ModemManager[357]: <info> [modem1] 3GPP registration state changed (home -> registering)
Apr 19 13:25:08 wirenboard-AWI3MCGC ModemManager[357]: <info> [modem1] 3GPP registration state changed (registering -> home)
Apr 19 13:25:09 wirenboard-AWI3MCGC ModemManager[357]: <info> [modem1] 3GPP registration state changed (home -> registering)
Apr 19 13:25:09 wirenboard-AWI3MCGC ModemManager[357]: <info> [modem1] 3GPP registration state changed (registering -> home)
Apr 19 13:25:10 wirenboard-AWI3MCGC ModemManager[357]: <info> [modem1/call0] call state changed: unknown -> ringing-in (incoming-new)
Apr 19 13:25:24 wirenboard-AWI3MCGC kernel: usb 3-1: USB disconnect, device number 5
Apr 19 13:25:24 wirenboard-AWI3MCGC kernel: rndis_host 3-1:1.0 usb0: unregister 'rndis_host' usb-1c1c000.usb-1, RNDIS device
Apr 19 13:25:24 wirenboard-AWI3MCGC avahi-daemon[311]: Withdrawing workstation service for usb0.
Apr 19 13:25:24 wirenboard-AWI3MCGC ModemManager[357]: <info> [base-manager] port usb0 released by device 'wbc'
Apr 19 13:25:24 wirenboard-AWI3MCGC ModemManager[357]: <info> [base-manager] port ttyUSB0 released by device 'wbc'
Apr 19 13:25:24 wirenboard-AWI3MCGC kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Apr 19 13:25:24 wirenboard-AWI3MCGC kernel: option 3-1:1.2: device disconnected
Apr 19 13:25:24 wirenboard-AWI3MCGC ModemManager[357]: <info> [base-manager] port ttyUSB1 released by device 'wbc'
Apr 19 13:25:24 wirenboard-AWI3MCGC kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Apr 19 13:25:24 wirenboard-AWI3MCGC kernel: option 3-1:1.4: device disconnected
Apr 19 13:25:24 wirenboard-AWI3MCGC pppd[21756]: Modem hangup
И да, ringing-in - это входящий.
Передам разработчикам.
На всякий случай: есть ли возможность попробовать то же в внешней, не штатной антенной?
Изначально работаем с нештатной. Кабель по-длиннее. Потому что в здании.
Каким будет решение?
Таймер на рестарт модема?
Таймер на рестарт контроллера?
Пока обсуждаем. В общем в testing уже есть автоматическое выключение-включение модема, перейдите и проверьте пожалуйста, релиз уже на днях.
Перешёл на 202404220207_testing_bullseye_wb67.
23.04.2024 10:00 Буду смотреть.
24.04.2024 10:00 Сутки продержались. Был один входящий.
Увы. Снова слетело ((
|24-04-2024 12:26:15.819| [modem0] simple connect state (7/10): wait to get packet service state attached|
|24-04-2024 12:26:15.816| [modem0] simple connect state (6/10): register|
|24-04-2024 12:26:15.813| [modem0] simple connect started…|
|24-04-2024 12:26:05.328| [modem0] simple connect state (7/10): wait to get packet service state attached|
|24-04-2024 12:26:05.313| [modem0] simple connect state (6/10): register|
|24-04-2024 12:26:05.309| [modem0] simple connect started…|
|24-04-2024 12:25:55.100| [modem0] simple connect state (7/10): wait to get packet service state attached|
|24-04-2024 12:25:55.099| [modem0] simple connect state (6/10): register|
|24-04-2024 12:25:55.096| [modem0] simple connect started…|
|24-04-2024 12:25:52.521| [modem0/call1] call state changed: ringing-in → terminated (unknown)|
|24-04-2024 12:25:44.807| [modem0] simple connect state (7/10): wait to get packet service state attached|
|24-04-2024 12:25:44.806| [modem0] simple connect state (6/10): register|
|24-04-2024 12:25:44.802| [modem0] simple connect started…|
|24-04-2024 12:25:37.522| [modem0] mobile equipment request to activate context (cid 1)|
|24-04-2024 12:25:34.274| [modem0] simple connect state (7/10): wait to get packet service state attached|
|24-04-2024 12:25:34.270| [modem0] simple connect state (6/10): register|
|24-04-2024 12:25:34.205| [modem0/bearer0] connection #1 finished: duration 94706s|
|24-04-2024 12:25:34.170| [modem0] simple connect state (5/10): wait after enabled|
|24-04-2024 12:25:34.162| [modem0] state changed (disconnecting → registered)|
|24-04-2024 12:25:33.664| [modem0] simple connect state (4/10): wait to get fully enabled|
|24-04-2024 12:25:33.663| [modem0] simple connect started…|
|24-04-2024 12:25:33.032| [modem0] state changed (connected → disconnecting)|
|24-04-2024 12:25:28.891| [modem0/bearer0] explicitly disconnected|
|24-04-2024 12:25:28.883| [modem0] network request to deactivate context (cid 1)|
|24-04-2024 12:25:21.764| [modem0/call1] call state changed: unknown → ringing-in (incoming-new)|
|24-04-2024 08:40:48.836| [modem0/call0] call state changed: ringing-in → terminated (unknown)|
|24-04-2024 08:40:17.768| [modem0/call0] call state changed: unknown → ringing-in (incoming-new)|
|24-04-2024 08:40:15.873| [modem0] 3GPP registration state changed (registering → home)|
|24-04-2024 08:40:15.791| [modem0] 3GPP registration state changed (home → registering)|
|23-04-2024 10:07:11.400| [modem0] simple connect state (10/10): all done|
|23-04-2024 10:07:11.342| [modem0] state changed (connecting → connected)|
|23-04-2024 10:07:11.187| [modem0] state changed (registered → connecting)|
Выложите пожалуйста диагностический архив.
Хочу посмотреть что с модемом происходило в dmesg
diag_output_AKU6B4TK_2024-04-24-15.38.44.zip (139,0 КБ)
Так, вижу.
И это - баг.
Сейчас привлеку разработчика, теперь достаточно информации.
Apr 23 10:07:11 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (10/10): all done
Apr 24 08:40:15 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] 3GPP registration state changed (home -> registering)
Apr 24 08:40:15 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] 3GPP registration state changed (registering -> home)
Apr 24 08:40:17 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0/call0] call state changed: unknown -> ringing-in (incoming-new)
Apr 24 08:40:48 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0/call0] call state changed: ringing-in -> terminated (unknown)
Apr 24 12:25:21 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0/call1] call state changed: unknown -> ringing-in (incoming-new)
Apr 24 12:25:28 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] network request to deactivate context (cid 1)
Apr 24 12:25:28 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0/bearer0] explicitly disconnected
Apr 24 12:25:33 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] state changed (connected -> disconnecting)
Apr 24 12:25:33 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect started...
Apr 24 12:25:33 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (4/10): wait to get fully enabled
Apr 24 12:25:34 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] state changed (disconnecting -> registered)
Apr 24 12:25:34 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (5/10): wait after enabled
Apr 24 12:25:34 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0/bearer0] connection #1 finished: duration 94706s
Apr 24 12:25:34 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (6/10): register
Apr 24 12:25:34 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (7/10): wait to get packet service state attached
Apr 24 12:25:37 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] mobile equipment request to activate context (cid 1)
Apr 24 12:25:44 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect started...
Apr 24 12:25:44 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (6/10): register
Apr 24 12:25:44 wirenboard-AKU6B4TK ModemManager[254]: <info> [modem0] simple connect state (7/10): wait to get packet service state attached
Обновите пока прошивку модема, прикладываю файл.
BinFile_7600_A39_B09.bin (6,2 МБ)
Если вам не затруднит, можно ссылку на инструкцию обновления прошивки модема.
Конечно, вот: Прошивка модемов SIMCom A76xxE-H — Wiren Board
Прошу прощения за вопрос (новичок).
- Установите на контроллер пакет
flash-simcom-a76xx
.- apt update && apt install flash-simcom-a76xx
Как установить пакет если у контроллера нет выхода в интернет?
Либо дать интернет либо выкачать пакет на компьютере.
Пакет установил.
Вопрос по следующему пункту
Как понять?
Загрузите прошивку, в итоге должно получиться так:
Загрузить прошивку какой командой? Откуда?
Что в итоге должно получиться ТАК?
Или на скрине команда загрузки прошивки?
Ещё раз извиняюсь. Я плохо знаю Linux (очень)
Всё. Получилось. Прошился модем.
До прошивки.
После прошивки
И ждём сборку?
