Sqlite3
Не могу установить npm i sqlite3:
node-pre-gyp WARN Pre-built binaries not found for sqlite3@5.0.0 and node@13.14.0 (node-v79 ABI, glibc) (falling back to source compile with node-gyp)
Может подскажете как?
Подскажите, какими командами уствили npm (какой версии?).
Npm обновлён до последней версии.
Это мне тоже первое в голову пришло.
Воспроизвел по инструкции https://wirenboard.com/wiki/index.php?title=Node-Red&mobileaction=toggle_view_desktop
Хвост от установки:
added 343 packages from 311 contributors in 364.632s
root@wirenboard-ACAX3M6K:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       980M  681M  233M  75% /
devtmpfs        241M     0  241M   0% /dev
tmpfs           249M     0  249M   0% /dev/shm
tmpfs           249M   26M  224M  11% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           249M     0  249M   0% /sys/fs/cgroup
/dev/mmcblk0p6  1.3G  235M  978M  20% /mnt/data
tmpfs            50M     0   50M   0% /run/user/0
Запустил:
root@wirenboard-ACAX3M6K:~# npm i sqlite3
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
> sqlite3@5.0.0 install /mnt/data/root/node_modules/sqlite3
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v5.0.0/napi-v3-linux-arm.tar.gz
node-pre-gyp WARN Pre-built binaries not found for sqlite3@5.0.0 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
make: Entering directory '/mnt/data/root/node_modules/sqlite3/build'
  CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
  AR(target) Release/obj.target/../node-addon-api/src/nothing.a
  COPY Release/nothing.a
  ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3310100/sqlite3.c
  TOUCH Release/obj.target/deps/action_before_build.stamp
  CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3310100/sqlite3.o
Ну и установилось без ошибок.
У вас каталог /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/ есть?
Да, есть, причем создан в апреле, т.е до продажи нам.
Единственный вчерашний файл - simple_copy.pyc.
Там где у Вас make, у меня:
gyp ERR! build error
gyp ERR! stack Error: not found: make
make найти не может почему то
apt-get install -y nodejs git make g++ gcc build-essential
из Вашей ссылки помогло
Правильно, пакет с make не стоял.
