Топики не отображаются в web интерфейсе
День добрый!
Подскажите, пожалуйста, опубликовал со стороннего устройства топики в mosquitto wirenboard. Вижу их в очереди через mosquitto_sub -t "#" -v но в web интерфейсе в Настройки → Каналы MQTT они не отображаются.
Топики приведены к виду wirenboard - начинаются с /devices
Список:
/devices/deye/logger_status online
/devices/deye/dc/pv1/power 0.0
/devices/deye/dc/pv2/power 0.0
/devices/deye/dc/pv1/voltage 0.5
/devices/deye/dc/pv2/voltage 8.0
/devices/deye/dc/pv1/current 0.1
/devices/deye/dc/pv2/current 0.0
/devices/deye/day_energy 9.1
/devices/deye/total_energy 22.5
/devices/deye/micro_inverter_power 0.0
/devices/deye/battery/total_charge 91.2
/devices/deye/battery/total_discharge 12.4
/devices/deye/battery/daily_charge 5.2
/devices/deye/battery/daily_discharge 3.2
/devices/deye/battery/status 0.0
/devices/deye/battery/power 337.0
/devices/deye/battery/voltage 52.9
/devices/deye/battery/soc 94.0
/devices/deye/battery/current 0.6
/devices/deye/battery/temperature 21.5
/devices/deye/ac/total_grid_power 0.0
/devices/deye/ac/l1/voltage 220.6
/devices/deye/ac/l2/voltage 0.0
/devices/deye/ac/l1/ct/internal 0.0
/devices/deye/ac/l2/ct/internal 0.0
/devices/deye/ac/l1/ct/external 0.0
/devices/deye/ac/l2/ct/external 0.0
/devices/deye/ac/daily_energy_bought 0.2
/devices/deye/ac/total_energy_bought 32754990.8
/devices/deye/ac/daily_energy_sold 0.0
/devices/deye/ac/total_energy_sold 0.0
/devices/deye/ac/total_power 260.0
/devices/deye/ac/l1/current 1.4
/devices/deye/ac/l2/current 0.0
/devices/deye/ac/l1/power 260.0
/devices/deye/ac/l2/power 0.0
/devices/deye/ac/frequency 50.0
/devices/deye/radiator_temp -35.5
/devices/deye/ac/temperature 39.2
/devices/deye/timeofuse/time/1 100.0
/devices/deye/timeofuse/time/2 500.0
/devices/deye/timeofuse/time/3 900.0
/devices/deye/timeofuse/time/4 1300.0
/devices/deye/timeofuse/time/5 1700.0
/devices/deye/timeofuse/time/6 2100.0
/devices/deye/timeofuse/power/1 16000.0
/devices/deye/timeofuse/power/2 16000.0
/devices/deye/timeofuse/power/3 16000.0
/devices/deye/timeofuse/power/4 16000.0
/devices/deye/timeofuse/power/5 16000.0
/devices/deye/timeofuse/power/6 16000.0
/devices/deye/timeofuse/soc/1 50.0
/devices/deye/timeofuse/soc/2 50.0
/devices/deye/timeofuse/soc/3 50.0
/devices/deye/timeofuse/soc/4 50.0
/devices/deye/timeofuse/soc/5 50.0
/devices/deye/timeofuse/soc/6 50.0
/devices/deye/timeofuse/enabled/1 7.0
/devices/deye/timeofuse/enabled/2 7.0
/devices/deye/timeofuse/enabled/3 7.0
/devices/deye/timeofuse/enabled/4 7.0
/devices/deye/timeofuse/enabled/5 7.0
/devices/deye/timeofuse/enabled/6 7.0
/devices/deye/timeofuse/enabled 255.0
/devices/deye/timeofuse/voltage/1 49.0
/devices/deye/timeofuse/voltage/2 49.0
/devices/deye/timeofuse/voltage/3 49.0
/devices/deye/timeofuse/voltage/4 49.0
/devices/deye/timeofuse/voltage/5 49.0
/devices/deye/timeofuse/voltage/6 49.0
/devices/deye/settings/active_power_regulation 0.0
Подскажите, пожалуйста, как сделать чтобы они отображались и можно было с ними работать.
Чтобы топики отображались в веб-интерфейсе, они должны соответствовать конвенции.
Вам удалось решить проблему?
Проблема отказалась немного больше. Топики формируются правильно - это видно в списке. Они видны в правильном виде в mosquitto, но дальше не получается продвинуться. Топики не обычные, а “волшебные”. Это внутренний протокол Deye, который парсится и конвертиться в MQTT. Закачал проект с github, там ребята сумели распарсить. Причем для различных устройств (разные блоки). Но они выдают в каноническом MQTT, который похоже не воспринимается ВБ. Буду доделывать, чтобы было видно как отдельные устройства, чтобы можно было потом использовать для сценариев - переход питания на панели, переход питания на батареи, переход питания на сеть, зависимость от заряда батарей/времени суток/солнца и т.п. Система для автоматизации очень интересная и хочется докопать до конца.
Так что ответ на вопрос - нет, пока не удалось. Буду дальше пробовать, спасибо @dust за ссылку
Помечу тему как решённую. Если в будущем возникнут трудности в освоении документации или предложения по улучшению, то прошу создать новую тему со ссылкой на данную — для удобства и сохранения контекста.
