Добрый день. Пытаюсь применить взаимоисключающее правило для WBIO-DO-SSR-8 - результата нет. Скажите, что делаю не так?
(function() { //don't touch this line
var suffix = "1"; // must be different in different JS files
var relay_up_device = "wb-gpio";
var relay_up_control = "EXT2_K1";
var relay_down_device = "wb-gpio";
var relay_down_control = "EXT2_K2";
var timeout_s = 15;
// End of settings
var relay_up_timer_id = null;
var relay_down_timer_id = null;
defineRule( "roller_shutter_up_on" + suffix, {
asSoonAs: function() {
return dev[relay_up_device][relay_up_control];
then: function () {
if (relay_up_timer_id) {
relay_up_timer_id = clearTimeout(relay_up_timer_id);
relay_up_timer_id = setTimeout(function() {
return dev[relay_up_device][relay_up_control] = 0;
}, timeout_s * 1000);
defineRule("roller_shutter_down_on" + suffix, {
return dev[relay_down_device][relay_down_control];
then: function () {
if (relay_down_timer_id) {
relay_down_timer_id = clearTimeout(relay_down_timer_id);
relay_down_timer_id = setTimeout(function() {
dev[relay_down_device][relay_down_control] = 0;
defineRule("roller_shutter_both_on" + suffix, {
return dev[relay_up_device][relay_up_control] && dev[relay_down_device][relay_down_control];
then: function () {
log("Both roller shutter relays on, switching them off");
