Перестают изменяться показатели c zigbee в /devices/…, причем по логам zigbee2mqtt данные поступают.
Вывод логов
root@IQ234000:~# mosquitto_sub -t /devices/# -v | grep 0x
/devices/0x00158d0005867d93/controls/temperature 17.79
/devices/0x00158d0005867d93/controls/temperature/meta/error r
/devices/0x00158d0005867d93/controls/temperature/meta/type temperature
/devices/0x00158d0005867d93/controls/temperature/meta/order 6
/devices/0x00158d0005867d93/controls/temperature/meta/readonly 1
/devices/0x00158d0005867d93/controls/voltage 2995
/devices/0x00158d0005867d93/controls/voltage/meta/type value
/devices/0x00158d0005867d93/controls/voltage/meta/order 7
/devices/0x00158d0005867d93/controls/voltage/meta/readonly 1
/devices/0x00158d0005867d93/controls/voltage/meta/error r
/devices/0x00158d0005867d93/controls/linkquality 65
/devices/0x00158d0005867d93/controls/linkquality/meta/type value
/devices/0x00158d0005867d93/controls/linkquality/meta/order 4
/devices/0x00158d0005867d93/controls/linkquality/meta/readonly 1
/devices/0x00158d0005867d93/controls/linkquality/meta/error r
/devices/0x00158d0005867d93/controls/last_seen 1614257590846
/devices/0x00158d0005867d93/controls/last_seen/meta/error r
/devices/0x00158d0005867d93/controls/last_seen/meta/type text
/devices/0x00158d0005867d93/controls/last_seen/meta/order 3
/devices/0x00158d0005867d93/controls/last_seen/meta/readonly 1
/devices/0x00158d0005867d93/controls/battery 97
/devices/0x00158d0005867d93/controls/battery/meta/type value
/devices/0x00158d0005867d93/controls/battery/meta/order 1
/devices/0x00158d0005867d93/controls/battery/meta/readonly 1
/devices/0x00158d0005867d93/controls/battery/meta/error r
/devices/0x00158d0005867d93/controls/humidity 38.42
/devices/0x00158d0005867d93/controls/humidity/meta/error r
/devices/0x00158d0005867d93/controls/humidity/meta/type rel_humidity
/devices/0x00158d0005867d93/controls/humidity/meta/order 2
/devices/0x00158d0005867d93/controls/humidity/meta/readonly 1
/devices/0x00158d0005867d93/controls/pressure 991.8
/devices/0x00158d0005867d93/controls/pressure/meta/type atmospheric_pressure
/devices/0x00158d0005867d93/controls/pressure/meta/order 5
/devices/0x00158d0005867d93/controls/pressure/meta/readonly 1
/devices/0x00158d0005867d93/meta/name 0x00158d0005867d93
/devices/0x00158d0005867d93/meta/driver wb-rules
/devices/0x00158d00058a65a7/controls/temperature 19.46
/devices/0x00158d00058a65a7/controls/temperature/meta/error r
/devices/0x00158d00058a65a7/controls/temperature/meta/type temperature
/devices/0x00158d00058a65a7/controls/temperature/meta/order 6
/devices/0x00158d00058a65a7/controls/temperature/meta/readonly 1
/devices/0x00158d00058a65a7/controls/voltage 2955
/devices/0x00158d00058a65a7/controls/voltage/meta/type value
/devices/0x00158d00058a65a7/controls/voltage/meta/order 7
/devices/0x00158d00058a65a7/controls/voltage/meta/readonly 1
/devices/0x00158d00058a65a7/controls/voltage/meta/error r
/devices/0x00158d00058a65a7/controls/linkquality 111
/devices/0x00158d00058a65a7/controls/linkquality/meta/readonly 1
/devices/0x00158d00058a65a7/controls/linkquality/meta/type value
/devices/0x00158d00058a65a7/controls/linkquality/meta/order 4
/devices/0x00158d00058a65a7/controls/linkquality/meta/error r
/devices/0x00158d00058a65a7/controls/last_seen 1614257568690
/devices/0x00158d00058a65a7/controls/last_seen/meta/error r
/devices/0x00158d00058a65a7/controls/last_seen/meta/readonly 1
/devices/0x00158d00058a65a7/controls/last_seen/meta/type text
/devices/0x00158d00058a65a7/controls/last_seen/meta/order 3
/devices/0x00158d00058a65a7/controls/battery 74
/devices/0x00158d00058a65a7/controls/battery/meta/type value
/devices/0x00158d00058a65a7/controls/battery/meta/order 1
/devices/0x00158d00058a65a7/controls/battery/meta/readonly 1
/devices/0x00158d00058a65a7/controls/battery/meta/error r
/devices/0x00158d00058a65a7/controls/humidity 33.21
/devices/0x00158d00058a65a7/controls/humidity/meta/error r
/devices/0x00158d00058a65a7/controls/humidity/meta/type rel_humidity
/devices/0x00158d00058a65a7/controls/humidity/meta/order 2
/devices/0x00158d00058a65a7/controls/humidity/meta/readonly 1
/devices/0x00158d00058a65a7/controls/pressure 992.3
/devices/0x00158d00058a65a7/controls/pressure/meta/type atmospheric_pressure
/devices/0x00158d00058a65a7/controls/pressure/meta/order 5
/devices/0x00158d00058a65a7/controls/pressure/meta/readonly 1
/devices/0x00158d00058a65a7/meta/name 0x00158d00058a65a7
/devices/0x00158d00058a65a7/meta/driver wb-rules
/devices/0x00158d00058a244e/controls/voltage 2965
/devices/0x00158d00058a244e/controls/voltage/meta/type value
/devices/0x00158d00058a244e/controls/voltage/meta/order 7
/devices/0x00158d00058a244e/controls/voltage/meta/readonly 1
/devices/0x00158d00058a244e/controls/voltage/meta/error r
/devices/0x00158d00058a244e/controls/linkquality 127
/devices/0x00158d00058a244e/controls/linkquality/meta/order 4
/devices/0x00158d00058a244e/controls/linkquality/meta/readonly 1
/devices/0x00158d00058a244e/controls/linkquality/meta/type value
/devices/0x00158d00058a244e/controls/linkquality/meta/error r
/devices/0x00158d00058a244e/controls/last_seen 1614257656529
/devices/0x00158d00058a244e/controls/last_seen/meta/error r
/devices/0x00158d00058a244e/controls/last_seen/meta/readonly 1
/devices/0x00158d00058a244e/controls/last_seen/meta/type text
/devices/0x00158d00058a244e/controls/last_seen/meta/order 3
/devices/0x00158d00058a244e/controls/battery 80
/devices/0x00158d00058a244e/controls/battery/meta/type value
/devices/0x00158d00058a244e/controls/battery/meta/order 1
/devices/0x00158d00058a244e/controls/battery/meta/readonly 1
/devices/0x00158d00058a244e/controls/battery/meta/error r
/devices/0x00158d00058a244e/controls/humidity 33.17
/devices/0x00158d00058a244e/controls/humidity/meta/error r
/devices/0x00158d00058a244e/controls/humidity/meta/type rel_humidity
/devices/0x00158d00058a244e/controls/humidity/meta/order 2
/devices/0x00158d00058a244e/controls/humidity/meta/readonly 1
/devices/0x00158d00058a244e/controls/temperature 17.76
/devices/0x00158d00058a244e/controls/temperature/meta/error r
/devices/0x00158d00058a244e/controls/temperature/meta/type temperature
/devices/0x00158d00058a244e/controls/temperature/meta/order 6
/devices/0x00158d00058a244e/controls/temperature/meta/readonly 1
/devices/0x00158d00058a244e/controls/pressure 993.2
/devices/0x00158d00058a244e/controls/pressure/meta/type atmospheric_pressure
/devices/0x00158d00058a244e/controls/pressure/meta/order 5
/devices/0x00158d00058a244e/controls/pressure/meta/readonly 1
/devices/0x00158d00058a244e/meta/name 0x00158d00058a244e
/devices/0x00158d00058a244e/meta/driver wb-rules
/devices/0x00158d000589187a/controls/voltage 3025
/devices/0x00158d000589187a/controls/voltage/meta/readonly 1
/devices/0x00158d000589187a/controls/voltage/meta/type value
/devices/0x00158d000589187a/controls/voltage/meta/order 7
/devices/0x00158d000589187a/controls/voltage/meta/error r
/devices/0x00158d000589187a/controls/linkquality 65
/devices/0x00158d000589187a/controls/linkquality/meta/readonly 1
/devices/0x00158d000589187a/controls/linkquality/meta/type value
/devices/0x00158d000589187a/controls/linkquality/meta/order 4
/devices/0x00158d000589187a/controls/linkquality/meta/error r
/devices/0x00158d000589187a/controls/last_seen 1614257684868
/devices/0x00158d000589187a/controls/last_seen/meta/error r
/devices/0x00158d000589187a/controls/last_seen/meta/type text
/devices/0x00158d000589187a/controls/last_seen/meta/order 3
/devices/0x00158d000589187a/controls/last_seen/meta/readonly 1
/devices/0x00158d000589187a/controls/battery 100
/devices/0x00158d000589187a/controls/battery/meta/order 1
/devices/0x00158d000589187a/controls/battery/meta/readonly 1
/devices/0x00158d000589187a/controls/battery/meta/type value
/devices/0x00158d000589187a/controls/battery/meta/error r
/devices/0x00158d000589187a/controls/temperature 15.9
/devices/0x00158d000589187a/controls/temperature/meta/error r
/devices/0x00158d000589187a/controls/temperature/meta/type temperature
/devices/0x00158d000589187a/controls/temperature/meta/order 6
/devices/0x00158d000589187a/controls/temperature/meta/readonly 1
/devices/0x00158d000589187a/controls/humidity 36.34
/devices/0x00158d000589187a/controls/humidity/meta/error r
/devices/0x00158d000589187a/controls/humidity/meta/type rel_humidity
/devices/0x00158d000589187a/controls/humidity/meta/order 2
/devices/0x00158d000589187a/controls/humidity/meta/readonly 1
/devices/0x00158d000589187a/controls/pressure 992.2
/devices/0x00158d000589187a/controls/pressure/meta/order 5
/devices/0x00158d000589187a/controls/pressure/meta/readonly 1
/devices/0x00158d000589187a/controls/pressure/meta/type atmospheric_pressure
/devices/0x00158d000589187a/meta/name 0x00158d000589187a
/devices/0x00158d000589187a/meta/driver wb-rules
^C
root@IQ234000:~# ^C
root@IQ234000:~# journalctl -u zigbee2mqtt -f
– Logs begin at Thu 2021-02-25 14:33:28 UTC. –
фев 25 15:42:39 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:42:39: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a65a7’, payload ‘{“battery”:74,“humidity”:32.65,“last_seen”:1614267759813,“linkquality”:124,“pressure”:992.7,“temperature”:20.12,“voltage”:2955}’
фев 25 15:46:32 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:32: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a24b7’, payload ‘{“battery”:100,“humidity”:29.61,“last_seen”:1614267992142,“linkquality”:31,“pressure”:992.6,“temperature”:21.02,“voltage”:3005}’
фев 25 15:46:32 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:32: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a24b7’, payload ‘{“battery”:100,“humidity”:29.53,“last_seen”:1614267992254,“linkquality”:33,“pressure”:992.6,“temperature”:21.02,“voltage”:3005}’
фев 25 15:46:32 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:32: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a24b7’, payload ‘{“battery”:100,“humidity”:29.53,“last_seen”:1614267992304,“linkquality”:31,“pressure”:992.9,“temperature”:21.02,“voltage”:3005}’
фев 25 15:46:33 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:33: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a244e’, payload ‘{“battery”:80,“humidity”:31.2,“last_seen”:1614267993442,“linkquality”:119,“pressure”:993.5,“temperature”:19.55,“voltage”:2965}’
фев 25 15:46:33 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:33: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a244e’, payload ‘{“battery”:80,“humidity”:31.56,“last_seen”:1614267993608,“linkquality”:119,“pressure”:993.5,“temperature”:19.55,“voltage”:2965}’
фев 25 15:46:33 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:33: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a244e’, payload ‘{“battery”:80,“humidity”:31.56,“last_seen”:1614267993658,“linkquality”:119,“pressure”:994,“temperature”:19.55,“voltage”:2965}’
фев 25 15:46:43 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:43: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a244e’, payload ‘{“battery”:80,“humidity”:31.56,“last_seen”:1614268003768,“linkquality”:127,“pressure”:994,“temperature”:19.47,“voltage”:2965}’
фев 25 15:46:43 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:43: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a244e’, payload ‘{“battery”:80,“humidity”:31.59,“last_seen”:1614268003808,“linkquality”:127,“pressure”:994,“temperature”:19.47,“voltage”:2965}’
фев 25 15:46:43 IQ234000 npm[1303]: Zigbee2MQTT:info 2021-02-25 15:46:43: MQTT publish: topic ‘zigbee2mqtt/0x00158d00058a244e’, payload ‘{“battery”:80,“humidity”:31.59,“last_seen”:1614268003864,“linkquality”:127,“pressure”:993.6,“temperature”:19.47,“voltage”:2965}’
^C
root@IQ234000:~# date
Чт фев 25 15:47:37 UTC 2021
Если не ошибаюсь, данные не шли примерно 3 часа. После перезапуска zigbee2mqtt данные в /devices/… стали обновляться.
