Failed to convert value '0', passing raw
Можно тоже спросить? У меня вот этих умных слов про wb-ADC нету, у меня всё приземлённее:
25-12-2021 23:57:53.649 [wb-rules] INFO: DC6xDR_0x10/HardWare: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.646 [wb-rules] INFO: DC6xDR_0x10/HardWare: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.639 [wb-rules] INFO: DC6xDR_0x10/Sensor1res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.626 [wb-rules] INFO: DC6xDR_0x10/Sensor1res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.622 [wb-rules] INFO: DC6xDR_0x10/Sensor1res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.615 [wb-rules] INFO: DC6xDR_0x10/Sensor1res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.606 [wb-rules] INFO: DC6xDR_0x10/Sensor3res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.591 [wb-rules] INFO: DC6xDR_0x10/Sensor3res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.585 [wb-rules] INFO: DC6xDR_0x10/Sensor3res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.575 [wb-rules] INFO: DC6xDR_0x10/Sensor3res: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.565 [wb-rules] INFO: DC6xDR_0x10/command: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.559 [wb-rules] INFO: DC6xDR_0x10/command: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.546 [wb-rules] INFO: DC6xDR_0x10/command: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.538 [wb-rules] INFO: DC6xDR_0x10/command: failed to convert value ‘’, passing raw
25-12-2021 23:57:53.533 [wb-rules] INFO: wb-mio-gpio_3:2/IN4: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.524 [wb-rules] INFO: wb-mio-gpio_3:2/IN3: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.504 [wb-rules] INFO: wb-mio-gpio_3:2/IN2: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.498 [wb-rules] INFO: wb-mio-gpio_3:2/IN8: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.491 [wb-rules] INFO: wb-mio-gpio_3:2/IN1: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.488 [wb-rules] INFO: wb-mio-gpio_3:2/IN6: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.476 [wb-rules] INFO: wb-mio-gpio_3:2/IN5: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.473 [wb-rules] INFO: wb-mio-gpio_3:2/IN7: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.467 [wb-rules] INFO: wb-mio-gpio_3:1/K4: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.455 [wb-rules] INFO: wb-mio-gpio_3:1/K5: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.448 [wb-rules] INFO: wb-mio-gpio_3:1/K3: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.443 [wb-rules] INFO: wb-mio-gpio_3:1/K2: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.435 [wb-rules] INFO: wb-mio-gpio_3:1/K1: failed to convert value ‘0’, passing raw
25-12-2021 23:57:53.433 [wb-rules] INFO: wb-mio-gpio_3:1/K6: failed to convert value ‘0’, passing raw
Что делать? Лог слать?
Здравствуйте! Перенес ваше сообщение в отдельную тему.
В данном случае это связано с введением более строгой проверки типов в wb-rules. Можно это пока игнорировать.
Как скажете :slight_smile:
Этот ответ все еще актуален? Оно ведь логи заполняет
wb-rules у меня пустой, не использую
tail -f /var/log/messages
Jun 14 11:18:43 wirenboard-AP5QU4A5 wb-rules[2173]: Device “ppp0” does not exist.
Jun 14 11:18:43 wirenboard-AP5QU4A5 wb-rules[2173]: INFO: network/GPRS IP: failed to convert value ‘’, passing raw
Jun 14 11:18:43 wirenboard-AP5QU4A5 wb-rules[2173]: INFO: network/Ethernet 2 IP: failed to convert value ‘’, passing raw
Jun 14 11:18:43 wirenboard-AP5QU4A5 wb-rules[2173]: INFO: network/Wi-Fi 2 IP: failed to convert value ‘’, passing raw
Jun 14 11:18:50 wirenboard-AP5QU4A5 dhclient[5561]: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 9
Jun 14 11:21:43 wirenboard-AP5QU4A5 wb-rules[2173]: Device “ppp0” does not exist.
смущает постоянно посторяющееся failed to convert value ‘’, passing raw для интерфейсов.
интернет только по Eth1. WiFI включен на запас, но не испльзуется
нормально ли /mnt/data/var/log - 483M ?
root@wirenboard-AP5QU4A5:/mnt/data# du -shc /mnt/data/var/*
57M /mnt/data/var/cache
84M /mnt/data/var/lib
483M /mnt/data/var/log
624M итого
Да, актуален. На контроллере есть еще системные правила, которые мониторят наличие сконфигурированных интерфейсов и выводят их в окно Network на странице Devices. Отсюда и сообщения. Было в планах убрать вывод этих сообщений.
В целом это не страшно. Директория /var находится на большом разделе /mnt/data. Но если вам хочется уменьшить размер логов, то можно их удалить, а также изменить настройки утилит логгирования logrotate и journald, ограничив максимальный размер их файлов:
https://docs.openshift.com/container-platform/4.8/logging/config/cluster-logging-systemd.html
