Ошибки в логах
Лог следующего содержания:
05-12-2021 17:49:04.977 [wb-rules] INFO: network/Wi-Fi 2 IP: failed to convert value ‘’, passing raw
05-12-2021 17:49:04.903 [wb-rules] INFO: network/Wi-Fi IP: failed to convert value ‘’, passing raw
05-12-2021 17:49:04.862 [wb-rules] INFO: network/Ethernet 2 IP: failed to convert value ‘’, passing raw
05-12-2021 17:49:04.797 [wb-rules] INFO: network/GPRS IP: failed to convert value ‘’, passing raw
05-12-2021 17:49:04.492 [wb-rules] Device ppp0 does not exist.
05-12-2021 17:48:04.968 [wb-rules] INFO: network/Wi-Fi 2 IP: failed to convert value ‘’, passing raw
05-12-2021 17:48:04.931 [wb-rules] INFO: network/GPRS IP: failed to convert value ‘’, passing raw
05-12-2021 17:48:04.913 [wb-rules] INFO: network/Wi-Fi IP: failed to convert value ‘’, passing raw
05-12-2021 17:48:04.856 [wb-rules] Device ppp0 does not exist.
05-12-2021 17:48:04.836 [wb-rules] INFO: network/Ethernet 2 IP: failed to convert value ‘’, passing raw
05-12-2021 17:47:04.985 [wb-rules] INFO: network/GPRS IP: failed to convert value ‘’, passing raw
05-12-2021 17:47:04.969 [wb-rules] Device ppp0 does not exist.
05-12-2021 17:47:04.924 [wb-rules] INFO: network/Wi-Fi IP: failed to convert value ‘’, passing raw
05-12-2021 17:47:04.906 [wb-rules] INFO: network/Wi-Fi 2 IP: failed to convert value ‘’, passing raw
05-12-2021 17:47:04.803 [wb-rules] INFO: network/Ethernet 2 IP: failed to convert value ‘’, passing
05-12-2021 17:17:53.927 [wb-mqtt-serial] WARNING: [modbus] failed to read 6 coil(s) @ 0 of device modbus:240: Serial protocol error: request timed out
05-12-2021 17:13:25.177 [wb-mqtt-serial] WARNING: [modbus] failed to read 3 coil(s) @ 0 of device modbus:132: Serial protocol error: request timed out
05-12-2021 17:09:06.830 [wb-mqtt-db] WARNING: [dblogger] Group data limit is reached: group all, row count 102013, limit 100000
что с ними делать?
А зачем с ними, с этими warning что-то делать?
Вопрос не повлияет ли это на работу?
Ну это ж ваши правила, не системные, надо искать в папке со скриптами это сообщение об ошибке.
Нет, не повлияет.
