Массовые Warning в логах после обновления
После обновления на wb-2310 и прошивки WB-MAP3E fw2 (Update: 2.3.5 → 2.7.5)
в логах появились массовые WARNING - можно это как-то устранить?
15-11-2023 14:18:32.331 [wb-mqtt-serial] WARNING: [driver] Failed to save value “-115.6” of control “Voltage angle L3” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:32.317 [wb-mqtt-serial] WARNING: [driver] Failed to save value “124.4” of control “Voltage angle L2” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:32.301 [wb-mqtt-serial] WARNING: [driver] Failed to save value “-31.6” of control “Phase angle L3” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.963 [wb-mqtt-serial] WARNING: [driver] Failed to save value “-25.3” of control “Phase angle L2” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.950 [wb-mqtt-serial] WARNING: [driver] Failed to save value “-20.9” of control “Phase angle L1” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.943 [wb-mqtt-serial] WARNING: [driver] Failed to save value “50.01” of control “Frequency” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.475 [wb-mqtt-serial] WARNING: [driver] Failed to save value “393.1” of control “U L3-L1” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.475 [wb-mqtt-serial] WARNING: [driver] Failed to save value “366” of control “U L2-L3” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.463 [wb-mqtt-serial] WARNING: [driver] Failed to save value “370.4” of control “U L1-L2” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
15-11-2023 14:18:31.455 [wb-mqtt-serial] WARNING: [driver] Failed to save value “0.3013” of control “Irms L3” of device “wb-map3e_133” to storage: [storage] Set error: no transaction @ wblib/private/storage_bdb.cpp:241
Версия контроллера
DTS Version
680
HW Revision
6.8.2
Manufacturing Date
2021-11-24 09:00:07+00:00
Reboot
Release name
wb-2310
Release suite
stable
Short SN
AD6ZJ5R3
Temperature Grade
industrial
Пожалуйста проверьте файл /var/lib/wb-mqtt-serial/libwbmqtt.db на корректность.
Если некорректен - удалите и перезапустите сервис.
Спасибо - помогло - ошибка исчезла.
