Received incomplete update FIT /var/www/uploads/wb-console.log, don’t starting update
Received good update FIT /var/www/uploads/202411131656_wb-2410_bullseye_wb7x.fit, starting update
Fri Nov 15 11:14:20 UTC 2024: started update from /mnt/data/uploads/202411131656_wb-2410_bullseye_wb7x.fit
Description: WirenBoard firmware update
Compatible device: wirenboard,wirenboard-720
Firmware version: 202411131656
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix +fit-immutable-support +wb8-debug-network-update-fix +update-from-cloud
Release name: wb-2410
Release suite: stable
Release target: wb7/bullseye
Release repo prefix:
Time of creation: Wed Nov 13 17:04:43 UTC 2024
>>> Checking SHA1 hash of install
>>> SHA1 hash of install ok
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00177733 s, 9.2 MB/s
tar: stdout: write error
>>> Firmware seems to be compatible with this controller
>>> Extracting install script
>>> Running install script
>>> Console logging enabled; tempfile /tmp/tmp.CMCdd0B0ec, final file /mnt/data/uploads/wb-console.log will be written on exit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.000771584 s, 21.2 MB/s
>>> Checking SHA1 hash of rootfs
>>> SHA1 hash of rootfs ok
>>> rootfs is valid, installing firmware update
>>> Getting mmcpart from U-Boot environment
>>> Will install to /dev/mmcblk0p3
>>> Debian: bullseye -> bullseye
>>> Cleaning up /dev/mmcblk0p3
>>> Cleaning up using rsync
>>> Mounting /dev/mmcblk0p3 at /tmp/tmp.2QccPGa2th
>>> Extracting files to new rootfs
/tmp/tmp.2QccPGa2th /
>>> Recovering device certificates
>>> Mount /dev, /proc and /sys to rootfs /tmp/tmp.2QccPGa2th
>>> Running post-install scripts
>>> > Processing /tmp/tmp.2QccPGa2th/usr/lib/wb-image-update/postinst/10update-u-boot
Skipping u-boot update (use factory reset to do it)
>>> > Processing /tmp/tmp.2QccPGa2th/usr/lib/wb-image-update/postinst/10update-wbec-firmware
Skipping WBEC firmware update (use factory reset to do it)
>>> Unmounting /dev, /proc and /sys from rootfs /tmp/tmp.2QccPGa2th
>>> Switching to new rootfs
>>> Done!
>>> Removing FIT /mnt/data/uploads/202411131656_wb-2410_bullseye_wb7x.fit
>>> Unmounting rootfs
>>> Reboot system
Fri Nov 15 13:53:34 UTC 2024: started update from /mnt/data/uploads/202411131656_wb-2410_bullseye_wb7x.fit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00186971 s, 8.8 MB/s
>>> Console logging enabled; tempfile /tmp/tmp.4k5ZoaqndG, final file /mnt/data/uploads/wb-console.log will be written on exit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00106792 s, 15.3 MB/s
>>> Will install to /dev/mmcblk0p2
>>> Cleaning up /dev/mmcblk0p2
>>> Mounting /dev/mmcblk0p2 at /tmp/tmp.R4okeSaT27
/tmp/tmp.R4okeSaT27 /
>>> Mount /dev, /proc and /sys to rootfs /tmp/tmp.R4okeSaT27
>>> > Processing /tmp/tmp.R4okeSaT27/usr/lib/wb-image-update/postinst/10update-u-boot
>>> > Processing /tmp/tmp.R4okeSaT27/usr/lib/wb-image-update/postinst/10update-wbec-firmware
>>> Unmounting /dev, /proc and /sys from rootfs /tmp/tmp.R4okeSaT27
>>> Done!
>>> Unmounting rootfs
>>> Reboot system
Можно подробнее? Я этот вывод могу сейчас из какого-то файла скопировать или его надо копировать откуда-то в момент обновления прошивки?
Что делать по шагам?
