Здравствуйте, не работает GSM модуль на wirenboard 7
Сим карта исправна
root@wirenboard-AMXMJFQI:~# wb-gsm restart_if_broken wb-gsm off wb-gsm on
Modem is not present. It should be enabled in hardware modules configuration
root@wirenboard-AMXMJFQI:~# nmcli device status
DEVICE TYPE STATE CONNECTION
wlan0 wifi connected wb-ap
eth0 ethernet connected wb-eth0
lo loopback connected (externally) lo
wlan1 wifi disconnected –
p2p-dev-wlan0 wifi-p2p disconnected –
p2p-dev-wlan1 wifi-p2p disconnected –
dbg0 ethernet unavailable –
eth1 ethernet unavailable –
sit0 iptunnel unmanaged –
root@wirenboard-AMXMJFQI:~# systemctl restart wb-gsm
root@wirenboard-AMXMJFQI:~# journalctl -u ModemManager -f
– Journal begins at Sun 2023-06-18 14:55:57 UTC. –
May 22 12:35:01 wirenboard-AMXMJFQI ModemManager[367]: ModemManager is shut down
May 22 12:35:02 wirenboard-AMXMJFQI systemd[1]: ModemManager.service: Succeeded.
May 22 12:35:02 wirenboard-AMXMJFQI systemd[1]: Stopped Modem Manager.
– Boot 9d8bd307775740cea522023b0baf7b95 –
Jun 25 13:47:21 wirenboard-AMXMJFQI systemd[1]: Starting Modem Manager…
Jun 25 13:47:22 wirenboard-AMXMJFQI ModemManager[369]: ModemManager (version 1.20.0) starting in system bus…
Jun 25 13:47:22 wirenboard-AMXMJFQI systemd[1]: Started Modem Manager.
Jun 25 13:47:25 wirenboard-AMXMJFQI ModemManager[369]: [base-manager] couldn’t check support for device ‘/sys/devices/platform/soc/1c0b000.ethernet’: not supported by any plugin
Jun 25 13:47:25 wirenboard-AMXMJFQI ModemManager[369]: [base-manager] couldn’t check support for device ‘/sys/devices/platform/soc/1c19000.usb/usb2/2-1’: not supported by any plugin
Jun 25 13:47:25 wirenboard-AMXMJFQI ModemManager[369]: [base-manager] couldn’t check support for device ‘/sys/devices/platform/soc/1c50000.ethernet’: not supported by any plugin
Jun 25 13:47:44 wirenboard-AMXMJFQI ModemManager[369]: [base-manager] couldn’t check support for device ‘/sys/devices/platform/soc/1c13000.usb/musb-hdrc.3.auto’: not supported by any plugin
