Добрый день. Не работает история. При просмотре истории и выборе любого диапазона дат и любого датчика крутится колесико и ни чего не происходит.
Контроллер wb6.6, wb-mqtt-db-cli пишет что нет данных
Архив поврежден, прошу снять повторно.
Start data collecting
2024-10-22 09:30:52,813 [WARNING] Command fdtget /mnt/data/.wb-restore/factoryreset.fit / timestamp / description / compatible / firmware-version / firmware-compatible / release-name / release-suite / release-target / release-repo-prefix didn't finish in 10s
File "/usr/share/wb-diag-collect/wb/diag/collector.py", line 115, in execute_commands
proc.wait(timeout)
File "/usr/lib/python3.9/subprocess.py", line 1189, in wait
return self._wait(timeout=timeout)
File "/usr/lib/python3.9/subprocess.py", line 1911, in _wait
raise TimeoutExpired(self.args, timeout)
subprocess.TimeoutExpired: Command 'fdtget /mnt/data/.wb-restore/factoryreset.fit / timestamp / description / compatible / firmware-version / firmware-compatible / release-name / release-suite / release-target / release-repo-prefix' timed out after 10 seconds
2024-10-22 09:31:31,818 [WARNING] Command wb-gen-serial -s didn't finish in 10s
proc.wait(timeout)
subprocess.TimeoutExpired: Command 'wb-gen-serial -s' timed out after 10 seconds
2024-10-22 09:32:28,116 [WARNING] Journalctl reading journalctl -u wb-rules.service --no-pager -n 5000 didn't finish in 10s
File "/usr/share/wb-diag-collect/wb/diag/collector.py", line 152, in copy_journalctl
proc.wait(timeout)
subprocess.TimeoutExpired: Command 'journalctl -u wb-rules.service --no-pager -n 5000' timed out after 10 seconds
2024-10-22 09:32:40,717 [WARNING] Journalctl reading journalctl -u wpa_supplicant.service --no-pager -n 5000 didn't finish in 10s
proc.wait(timeout)
subprocess.TimeoutExpired: Command 'journalctl -u wpa_supplicant.service --no-pager -n 5000' timed out after 10 seconds
Data was collected successfully
diag_AGUH6JNH_2024-10-22-09.32.40.zip (338,5 КБ)
Покажите результат подписки на топики /rpc/v1/db_logger/# при выводе единственного настроенного в сервисе wb-mqtt-dm канала пожалуйста.
root@wirenboard-AGUH6JNH:~# mosquitto_sub -v -t /rpc/v1/db_logger/#
/rpc/v1/db_logger/history/get_values 1
/rpc/v1/db_logger/history/get_channels 1
Я выполняю аналогично:
mosquitto_sub -v -t '/rpc/v1/db_logger/#'
В момент нажатия кнопки “Загрузить данные”
получаю:
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-o3y5DnzbGX {"id":10,"params":{"channels":[["power_status","Vin"]],"limit":1000,"ver":1,"timestamp":{"gt":1729600619,"lt":1729687020},"min_interval":95040,"max_records":1000,"with_milliseconds":true}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-o3y5DnzbGX/reply {"error":null,"id":10,"result":{"values":[{"c":51,"i":2248898,"retain":false,"t":1729601142.079,"v":"24.5"},{"c":51,"i":2248899,"retain":false,"t":1729601142.778,"v":"24.6"},{"c":51,"i":2249052,"retain":false,"t":1729601514.487,"v":"24.5"},{"c":51,"i":2249054,"retain":false,"t":1729601515.186,"v":"24.6"},{"c":51,"i":2249365,"retain":false,"t":1729602402.079,"v":"24.5"},{"c":51,"i":2249366,"retain":false,"t":1729602402.786,"v":"24.6"},{"c":51,"i":2249367,"retain":false,"t":1729602411.187,"v":"24.5"},{"c":51,"i":2249368,"retain":false,"t":1729602411.892,"v":"24.6"},{"c":51,"i":2249502,"retain":false,"t":1729602725.489,"v":"24.5"},{"c":51,"i":2249504,"retain":false,"t":1729602726.184,"v":"24.6"},{"c":51,"i":2249689,"retain":false,"t":1729603242.078,"v":"24.5"},{"c":51,"i":2249690,"retain":false,"t":1729603242.788,"v":"24.6"},{"c":51,"i":2249947,"retain":false,"t":1729603865.782,"v":"24.5"},{"c":51,"i":2249948,"retain":false,"t":1729603866.487,"v":"24.6"},{"c":51,"i":2250010,"retain":false,"t":1729604068.078,"v":"24.5"},{"c":51,"i":2250011,"retain":false,"t":1729604068.778,"v":"24.6"},{"c":51,"i":2250093,"retain":false,"t":1729604285.078,"v":"24.5"},{"c":51,"i":2250137,"retain":false,"t":1729604285.778,"v":"24.6"},{"c":51,"i":2250265,"retain":false,"t":1729604762.488,"v":"24.5"},{"c":51,"i":2250266,"retain":false,"t":1729604763.187,"v":"24.6"},{"c":51,"i":2250526,"retain":false,"t":1729605457.586,"v":"24.5"},{"c":51,"i":2250527,"retain":false,"t":1729605458.287,"v":"24.6"},{"c":51,"i":2250528,"retain":false,"t":1729605468.078,"v":"24.5"},{"c":51,"i":2250529,"retain":false,"t":1729605468.787,"v":"24.6"},{"c":51,"i":2250611,"retain":false,"t":1729605700.488,"v":"24.5"},{"c":51,"i":2250653,"retain":false,"t":1729605701.187,"v":"24.6"},{"c":51,"i":2250756,"retain":false,"t":1729606121.884,"v":"24.5"},{"c":51,"i":2250757,"retain":false,"t":1729606122.59,"v":"24.6"},{"c":51,"i":2251249,"retain":false,"t":1729607393.079,"v":"24.5"},{"c":51,"i":2251250,"retain":false,"t":1729607393.786,"v":"24.6"},{"c":51,"i":2251342,"retain":false,"t":1729607645.783,"v":"24.5"},{"c":51,"i":2251344,"retain":false,"t":1729607646.489,"v":"24.6"},{"c":51,"i":2251692,"retain":false,"t":1729608604.789,"v":"24.5"},{"c":51,"i":2251693,"retain":false,"t":1729608605.487,"v":"24.6"},{"c":51,"i":2252417,"retain":false,"t":1729610620.079,"v":"24.5"},{"c":51,"i":2252418,"retain":false,"t":1729610620.787,"v":"24.6"},{"c":51,"i":2252964,"retain":false,"t":1729612113.886,"v":"24.5"},{"c":51,"i":2252965,"retain":false,"t":1729612114.587,"v":"24.6"},{"c":51,"i":2253215,"retain":false,"t":1729612729.88,"v":"24.5"},{"c":51,"i":2253216,"retain":false,"t":1729612730.588,"v":"24.6"},{"c":51,"i":2253383,"retain":false,"t":1729613190.481,"v":"24.5"},{"c":51,"i":2253385,"retain":false,"t":1729613191.179,"v":"24.6"},{"c":51,"i":2253389,"retain":false,"t":1729613204.48,"v":"24.5"},{"c":51,"i":2253390,"retain":false,"t":1729613205.18,"v":"24.6"},{"c":51,"i":2253532,"retain":false,"t":1729613525.785,"v":"24.5"},{"c":51,"i":2253534,"retain":false,"t":1729613526.487,"v":"24.6"},{"c":51,"i":2254213,"retain":false,"t":1729615396.889,"v":"24.5"},{"c":51,"i":2254214,"retain":false,"t":1729615397.589,"v":"24.6"},{"c":51,"i":2254216,"retain":false,"t":1729615401.789,"v":"24.5"},{"c":51,"i":2254217,"retain":false,"t":1729615402.49,"v":"24.6"},{"c":51,"i":2254220,"retain":false,"t":1729615422.078,"v":"24.5"},{"c":51,"i":2254221,"retain":false,"t":1729615423.487,"v":"24.6"},{"c":51,"i":2254231,"retain":false,"t":1729615455.68,"v":"24.5"},{"c":51,"i":2254232,"retain":false,"t":1729615456.385,"v":"24.6"},{"c":51,"i":2254242,"retain":false,"t":1729615493.487,"v":"24.5"},{"c":51,"i":2254243,"retain":false,"t":1729615494.187,"v":"24.6"},{"c":51,"i":2254264,"retain":false,"t":1729615514.489,"v":"24.5"},{"c":51,"i":2254265,"retain":false,"t":1729615515.188,"v":"24.6"},{"c":51,"i":2254331,"retain":false,"t":1729615730.789,"v":"24.5"},{"c":51,"i":2254332,"retain":false,"t":1729615731.487,"v":"24.6"},{"c":51,"i":2254395,"retain":false,"t":1729615846.286,"v":"24.5"},{"c":51,"i":2254437,"retain":false,"t":1729615846.988,"v":"24.6"},{"c":51,"i":2254653,"retain":false,"t":1729616570.789,"v":"24.5"},{"c":51,"i":2254654,"retain":false,"t":1729616571.487,"v":"24.6"},{"c":51,"i":2254826,"retain":false,"t":1729616955.079,"v":"24.5"},{"c":51,"i":2254827,"retain":false,"t":1729616955.778,"v":"24.6"},{"c":51,"i":2255080,"retain":false,"t":1729617694.987,"v":"24.5"},{"c":51,"i":2255081,"retain":false,"t":1729617695.688,"v":"24.6"},{"c":51,"i":2255325,"retain":false,"t":1729618362.078,"v":"24.5"},{"c":51,"i":2255326,"retain":false,"t":1729618362.788,"v":"24.6"},{"c":51,"i":2255675,"retain":false,"t":1729619339.288,"v":"24.5"},{"c":51,"i":2255676,"retain":false,"t":1729619339.987,"v":"24.6"},{"c":51,"i":2255792,"retain":false,"t":1729619615.083,"v":"24.5"},{"c":51,"i":2255793,"retain":false,"t":1729619615.788,"v":"24.6"},{"c":51,"i":2256012,"retain":false,"t":1729620285.687,"v":"24.5"},{"c":51,"i":2256013,"retain":false,"t":1729620286.387,"v":"24.6"},{"c":51,"i":2257235,"retain":false,"t":1729623605.78,"v":"24.5"},{"c":51,"i":2257237,"retain":false,"t":1729623606.486,"v":"24.6"},{"c":51,"i":2258010,"retain":false,"t":1729625735.888,"v":"24.5"},{"c":51,"i":2258011,"retain":false,"t":1729625736.588,"v":"24.6"},{"c":51,"i":2258984,"retain":false,"t":1729628481.987,"v":"24.5"},{"c":51,"i":2258985,"retain":false,"t":1729628482.689,"v":"24.6"},{"c":51,"i":2259221,"retain":false,"t":1729629063.68,"v":"24.5"},{"c":51,"i":2259222,"retain":false,"t":1729629064.386,"v":"24.6"},{"c":51,"i":2259357,"retain":false,"t":1729629478.788,"v":"24.5"},{"c":51,"i":2259358,"retain":false,"t":1729629479.487,"v":"24.6"},{"c":51,"i":2260306,"retain":false,"t":1729632076.478,"v":"24.5"},{"c":51,"i":2260307,"retain":false,"t":1729632077.188,"v":"24.6"},{"c":51,"i":2261007,"retain":false,"t":1729634022.484,"v":"24.5"},{"c":51,"i":2261008,"retain":false,"t":1729634023.188,"v":"24.6"},{"c":51,"i":2261807,"retain":false,"t":1729636205.779,"v":"24.5"},{"c":51,"i":2261809,"retain":false,"t":1729636206.487,"v":"24.6"},{"c":51,"i":2262781,"retain":false,"t":1729638883.989,"v":"24.5"},{"c":51,"i":2262782,"retain":false,"t":1729638884.687,"v":"24.6"},{"c":51,"i":2263013,"retain":false,"t":1729639565.789,"v":"24.5"},{"c":51,"i":2263015,"retain":false,"t":1729639566.485,"v":"24.6"},{"c":51,"i":2263731,"retain":false,"t":1729641546.079,"v":"24.5"},{"c":51,"i":2263732,"retain":false,"t":1729641546.787,"v":"24.6"},{"c":51,"i":2265509,"retain":false,"t":1729646481.078,"v":"24.5"},{"c":51,"i":2265510,"retain":false,"t":1729646481.787,"v":"24.6"},{"c":51,"i":2265862,"retain":false,"t":1729647462.484,"v":"24.5"},{"c":51,"i":2265863,"retain":false,"t":1729647463.185,"v":"24.6"},{"c":51,"i":2267072,"retain":false,"t":1729650825.988,"v":"24.5"},{"c":51,"i":2267073,"retain":false,"t":1729650826.686,"v":"24.6"},{"c":51,"i":2271549,"retain":false,"t":1729662926.88,"v":"24.5"},{"c":51,"i":2271550,"retain":false,"t":1729662927.587,"v":"24.6"},{"c":51,"i":2272572,"retain":false,"t":1729665695.379,"v":"24.5"},{"c":51,"i":2272573,"retain":false,"t":1729665696.078,"v":"24.6"},{"c":51,"i":2273068,"retain":false,"t":1729667076.479,"v":"24.5"},{"c":51,"i":2273069,"retain":false,"t":1729667077.187,"v":"24.6"},{"c":51,"i":2274034,"retain":false,"t":1729669676.988,"v":"24.5"},{"c":51,"i":2274035,"retain":false,"t":1729669677.686,"v":"24.6"},{"c":51,"i":2274240,"retain":false,"t":1729670182.383,"v":"24.5"},{"c":51,"i":2274241,"retain":false,"t":1729670183.078,"v":"24.6"},{"c":51,"i":2274610,"retain":false,"t":1729671170.081,"v":"24.5"},{"c":51,"i":2274611,"retain":false,"t":1729671170.788,"v":"24.6"},{"c":51,"i":2275250,"retain":false,"t":1729672921.486,"v":"24.5"},{"c":51,"i":2275252,"retain":false,"t":1729672922.187,"v":"24.6"},{"c":51,"i":2275579,"retain":false,"t":1729673768.486,"v":"24.5"},{"c":51,"i":2275580,"retain":false,"t":1729673769.182,"v":"24.6"},{"c":51,"i":2275586,"retain":false,"t":1729673781.789,"v":"24.5"},{"c":51,"i":2275587,"retain":false,"t":1729673782.487,"v":"24.6"},{"c":51,"i":2275614,"retain":false,"t":1729673855.288,"v":"24.5"},{"c":51,"i":2275615,"retain":false,"t":1729673855.986,"v":"24.6"},{"c":51,"i":2275936,"retain":false,"t":1729674710.687,"v":"24.5"},{"c":51,"i":2275938,"retain":false,"t":1729674711.388,"v":"24.6"},{"c":51,"i":2275959,"retain":false,"t":1729674755.489,"v":"24.5"},{"c":51,"i":2275960,"retain":false,"t":1729674756.189,"v":"24.6"},{"c":51,"i":2276130,"retain":false,"t":1729675244.092,"v":"24.5"},{"c":51,"i":2276131,"retain":false,"t":1729675244.788,"v":"24.6"},{"c":51,"i":2276239,"retain":false,"t":1729675552.078,"v":"24.5"},{"c":51,"i":2276240,"retain":false,"t":1729675552.79,"v":"24.6"},{"c":51,"i":2276279,"retain":false,"t":1729675644.484,"v":"24.5"},{"c":51,"i":2276280,"retain":false,"t":1729675645.188,"v":"24.6"},{"c":51,"i":2276370,"retain":false,"t":1729675825.788,"v":"24.5"},{"c":51,"i":2276415,"retain":false,"t":1729675826.491,"v":"24.6"},{"c":51,"i":2276464,"retain":false,"t":1729676072.889,"v":"24.5"},{"c":51,"i":2276512,"max":"24.6","min":"24.5","retain":false,"t":1729676192.89,"v":"24.6"},{"c":51,"i":2276556,"max":"24.6","min":"24.5","retain":false,"t":1729676312.89,"v":"24.6"},{"c":51,"i":2276598,"max":"24.6","min":"24.5","retain":false,"t":1729676432.892,"v":"24.6"},{"c":51,"i":2276644,"retain":false,"t":1729676572.688,"v":"24.5"},{"c":51,"i":2276685,"retain":false,"t":1729676573.381,"v":"24.6"},{"c":51,"i":2277015,"retain":false,"t":1729677604.488,"v":"24.5"},{"c":51,"i":2277016,"retain":false,"t":1729677605.187,"v":"24.6"},{"c":51,"i":2277054,"retain":false,"t":1729677667.488,"v":"24.5"},{"c":51,"i":2277055,"retain":false,"t":1729677668.188,"v":"24.6"},{"c":51,"i":2277144,"retain":false,"t":1729677934.883,"v":"24.5"},{"c":51,"i":2277145,"retain":false,"t":1729677935.589,"v":"24.6"},{"c":51,"i":2277166,"retain":false,"t":1729678004.203,"v":"24.5"},{"c":51,"i":2277215,"retain":false,"t":1729678004.888,"v":"24.6"},{"c":51,"i":2277283,"max":"24.6","min":"24.5","retain":false,"t":1729678244.205,"v":"24.6"},{"c":51,"i":2277568,"retain":false,"t":1729679045.784,"v":"24.5"},{"c":51,"i":2277570,"retain":false,"t":1729679046.489,"v":"24.6"},{"c":51,"i":2277617,"retain":false,"t":1729679176.679,"v":"24.5"},{"c":51,"i":2277618,"retain":false,"t":1729679177.387,"v":"24.6"},{"c":51,"i":2277663,"retain":false,"t":1729679297.78,"v":"24.5"},{"c":51,"i":2277664,"retain":false,"t":1729679298.487,"v":"24.6"},{"c":51,"i":2277730,"max":"24.6","min":"24.5","retain":false,"t":1729679418.488,"v":"24.6"},{"c":51,"i":2277779,"retain":false,"t":1729679552.581,"v":"24.5"},{"c":51,"i":2277822,"retain":false,"t":1729679553.287,"v":"24.6"},{"c":51,"i":2277864,"max":"24.6","min":"24.5","retain":false,"t":1729679792.583,"v":"24.6"},{"c":51,"i":2277929,"retain":false,"t":1729679950.888,"v":"24.5"},{"c":51,"i":2277971,"max":"24.6","min":"24.5","retain":false,"t":1729680070.889,"v":"24.6"},{"c":51,"i":2278036,"retain":false,"t":1729680285.487,"v":"24.5"},{"c":51,"i":2278078,"retain":false,"t":1729680286.189,"v":"24.6"},{"c":51,"i":2278142,"retain":false,"t":1729680592.081,"v":"24.5"},{"c":51,"i":2278208,"retain":false,"t":1729680592.787,"v":"24.6"},{"c":51,"i":2278250,"max":"24.6","min":"24.5","retain":false,"t":1729680832.082,"v":"24.6"},{"c":51,"i":2278297,"max":"24.6","min":"24.5","retain":false,"t":1729680952.082,"v":"24.6"},{"c":51,"i":2278338,"max":"24.6","min":"24.5","retain":false,"t":1729681072.083,"v":"24.6"},{"c":51,"i":2278380,"max":"24.6","min":"24.5","retain":false,"t":1729681192.083,"v":"24.6"},{"c":51,"i":2278424,"max":"24.6","min":"24.5","retain":false,"t":1729681312.084,"v":"24.6"},{"c":51,"i":2278511,"retain":false,"t":1729681536.392,"v":"24.5"},{"c":51,"i":2278554,"retain":false,"t":1729681537.079,"v":"24.6"},{"c":51,"i":2278595,"max":"24.6","min":"24.5","retain":false,"t":1729681776.393,"v":"24.6"},{"c":51,"i":2278663,"max":"24.6","min":"24.5","retain":false,"t":1729681896.393,"v":"24.6"},{"c":51,"i":2278748,"retain":false,"t":1729682140.488,"v":"24.5"},{"c":51,"i":2278749,"retain":false,"t":1729682141.183,"v":"24.6"},{"c":51,"i":2278791,"max":"24.6","min":"24.5","retain":false,"t":1729682261.184,"v":"24.6"},{"c":51,"i":2278835,"max":"24.6","min":"24.5","retain":false,"t":1729682381.184,"v":"24.6"},{"c":51,"i":2279310,"retain":false,"t":1729683715.479,"v":"24.5"},{"c":51,"i":2279311,"retain":false,"t":1729683716.186,"v":"24.6"},{"c":51,"i":2279375,"retain":false,"t":1729683882.788,"v":"24.5"},{"c":51,"i":2279376,"retain":false,"t":1729683883.491,"v":"24.6"},{"c":51,"i":2279445,"retain":false,"t":1729684085.783,"v":"24.5"},{"c":51,"i":2279447,"retain":false,"t":1729684086.488,"v":"24.6"},{"c":51,"i":2279634,"retain":false,"t":1729684526.079,"v":"24.5"},{"c":51,"i":2279635,"retain":false,"t":1729684526.788,"v":"24.6"},{"c":51,"i":2279721,"retain":false,"t":1729684802.587,"v":"24.5"},{"c":51,"i":2279847,"retain":false,"t":1729685127.387,"v":"24.6"},{"c":51,"i":2279848,"retain":false,"t":1729685128.079,"v":"24.5"},{"c":51,"i":2279893,"max":"24.6","min":"24.5","retain":false,"t":1729685248.079,"v":"24.6"},{"c":51,"i":2279936,"max":"24.6","min":"24.5","retain":false,"t":1729685368.079,"v":"24.6"},{"c":51,"i":2280000,"max":"24.6","min":"24.5","retain":false,"t":1729685488.079,"v":"24.6"},{"c":51,"i":2280044,"max":"24.6","min":"24.5","retain":false,"t":1729685608.08,"v":"24.6"},{"c":51,"i":2280088,"max":"24.6","min":"24.5","retain":false,"t":1729685728.08,"v":"24.5"},{"c":51,"i":2280131,"max":"24.6","min":"24.5","retain":false,"t":1729685848.081,"v":"24.6"},{"c":51,"i":2280175,"max":"24.6","min":"24.5","retain":false,"t":1729685968.082,"v":"24.5"},{"c":51,"i":2280219,"max":"24.6","min":"24.5","retain":false,"t":1729686088.083,"v":"24.5"},{"c":51,"i":2280261,"max":"24.6","min":"24.5","retain":false,"t":1729686208.083,"v":"24.5"},{"c":51,"i":2280304,"max":"24.6","min":"24.5","retain":false,"t":1729686328.083,"v":"24.6"},{"c":51,"i":2280347,"max":"24.6","min":"24.5","retain":false,"t":1729686448.084,"v":"24.6"},{"c":51,"i":2280387,"max":"24.6","min":"24.5","retain":false,"t":1729686568.085,"v":"24.6"},{"c":51,"i":2280451,"max":"24.6","min":"24.5","retain":false,"t":1729686688.086,"v":"24.6"},{"c":51,"i":2280495,"max":"24.6","min":"24.5","retain":false,"t":1729686808.086,"v":"24.6"},{"c":51,"i":2280537,"max":"24.6","min":"24.5","retain":false,"t":1729686928.086,"v":"24.6"}]}}
У вас вывод отличается?
Да, отличается
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-TdAxvZVR9s {"id":3,"params":{"channels":[["power_status","Vin"]],"limit":1000,"ver":1,"timestamp":{"gt":1729621319,"lt":1729707720},"min_interval":95040,"max_records":1000,"with_milliseconds":true}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-TdAxvZVR9s/reply {"error":null,"id":3,"result":{"values":[]}}
Я вижу что по запрошенному топику нет записей. А так как в конфиге указан только один - то выполните запрос именно по сконфигурированному.
То есть - вы настроили сохранение только одного топика но запрашиваете данные по другому?
Добрый день, странно на другом WB показывается история по всем устройствам по умолчанию, но там в конфиге написано all b по устройствам ++, на этом контроллере я сейчас в рамках устранения проблемы настроил 3 канала история, вчера история по ним вела так как и по всем остальным - колесио и данных нет, сегодня заработало. Магия…
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-5nGmhYSfHf {"id":6,"params":{"channels":[["wb-gpio","W2_IN"]],"limit":1000,"ver":1,"timestamp":{"gt":1729322639,"lt":1729468800},"min_interval":160776,"max_records":550,"with_milliseconds":true}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-5nGmhYSfHf/reply {"error":null,"id":6,"result":{"values":[]}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-5nGmhYSfHf {"id":7,"params":{"channels":[["wb-gpio","W2_IN"]],"limit":1000,"ver":1,"timestamp":{"gt":1729468801,"lt":1729641600},"min_interval":190080,"max_records":550,"with_milliseconds":true}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-5nGmhYSfHf/reply {"error":null,"id":7,"result":{"values":[{"c":1,"i":1,"retain":false,"t":1729525146.559,"v":"1"}]}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-5nGmhYSfHf {"id":8,"params":{"channels":[["wb-gpio","W2_IN"]],"limit":1000,"ver":1,"timestamp":{"gt":1729641601,"lt":1729754640},"min_interval":124344,"max_records":550,"with_milliseconds":true}}
/rpc/v1/db_logger/history/get_values/wb-mqtt-homeui-5nGmhYSfHf/reply {"error":null,"id":8,"result":{"values":[{"c":1,"i":2,"retain":false,"t":1729673462.216,"v":"1"}]}}
А вчера в истории данные уже были по этим каналам?
Нет, вчера данных не было
Были ли “вчера” события в настроенных каналах?
Да, напряжение в сети точно изменялось.
Пока вопрос решился, давайте будем считать тему закрытой.
Понаблюдаю, если что вернусь
