Не работает modbus
Настраиваю mbgate:
Часть конфига из секции inputs:
    "topic": "hwmon/CPU Temperature",
    "address": 5395,
    "unitId": 9,
    "meta_type": "temperature",
    "enabled": true,
    "format": "signed",
    "size": 2,
    "max": 0,
    "scale": 1,
    "byteswap": false,
    "wordswap": false
Он работает:
systemctl status wb-mqtt-mbgate
● wb-mqtt-mbgate.service - Wiren Board MQTT to Modbus TCP gateway
     Loaded: loaded (/lib/systemd/system/wb-mqtt-mbgate.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2023-05-15 16:22:24 UTC; 2min 13s ago
    Process: 19397 ExecStartPre=/usr/bin/wb-mqtt-mbgate-confgen -c /etc/wb-mqtt-mbgate.conf (code=exited, status=0/SUCCESS)
   Main PID: 19405 (wb-mqtt-mbgate)
      Tasks: 3 (limit: 2354)
     Memory: 2.0M
        CPU: 1.837s
     CGroup: /system.slice/wb-mqtt-mbgate.service
             └─19405 /usr/bin/wb-mqtt-mbgate -c /etc/wb-mqtt-mbgate.conf
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate-confgen[19397]: Topic wb-map6s_27/S 5 taken from old config
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate-confgen[19397]: Topic wb-map6s_27/S 6 taken from old config
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate-confgen[19397]: Topic wb-map6s_27/Serial taken from old config
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate-confgen[19397]: Topic wb-map6s_27/Urms taken from old config
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate-confgen[19397]: Topic wbrules/Rule debugging taken from old config
May 15 16:22:24 wirenboard-AWI3MCGC systemd[1]: Started Wiren Board MQTT to Modbus TCP gateway.
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate[19405]: INFO: [modbus] Modbus listening
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate[19405]: INFO: [mbgate] Start loops
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate[19405]: INFO: [mqtt] connection estabilished with code "0" <success>
May 15 16:22:24 wirenboard-AWI3MCGC wb-mqtt-mbgate[19405]: INFO: [mqtt] subscription succeeded (message id 1)
Из важного в логе:
May 15 17:02:37 wirenboard-AWI3MCGC systemd[1]: Started Wiren Board MQTT to Modbus TCP gateway.
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Modbus configuration: device /dev/ttyRS485-2, baud rate 9600, parity N, data bits 8, stop bits 2
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] MQTT configuration: host /var/run/mosquitto/mosquitto.sock, port 0, keepalive 60
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Processing store 2
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Processing store 1
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Processing store 8
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Processing store 4
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Element hwmon/CPU Temperature : 5395
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [config] Creating observer on 5395:1
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: DEBUG: [modbus] Modbus cache allocated
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: INFO: [modbus] Modbus listening
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: INFO: [mbgate] Start loops
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: INFO: [mqtt] connection estabilished with code "0" <success>
May 15 17:02:37 wirenboard-AWI3MCGC wb-mqtt-mbgate[8082]: INFO: [mqtt] subscription succeeded (message id 1)
Проверяю:
modbus_client --debug -mrtu -pnone -s2 -b9600 /dev/ttyRS485-1 -a9 -t0x04 -r5395
[09][04][15][13][00][01][C5][4B]
Waiting for a confirmation...
<09><04><02><00><23><19><28>
SUCCESS: read 1 of elements:
	Data: 0x0023
Включите пожалуйста debug в конфиге mbgate и проверте что тудапишется при запросах.
Результат.
Похоже у меня воспроизвелось, оформил багу. Ждем исправления.
Мои действия? Ждать?
Да, программисы занимаются, возможно выкатят PR сегодня.
Фикс уже доступен в testing.
Теперь не работает первый порт.
Обмен прошел 1 раз показывает что все ок. А данные не изменны.
Обмен чего с чем?
То есть - что делате, что ожидаете, что получаете?
Я ожидаю чтения раз в 1 секунду значений с устройства с адресом 10 “matrix” значений регистров:
40524
40526
40527
И обновления этих данных в веб интерфейсе…
Какая версия wb-mqtt-serial?
Как я могу это выяснить?
Cовершенно стандартная команда dpkg -s wb-mqtt-serial вернет версию. Если релиз testing - то пакет должен быть не ниже 2.85.4
Насколько я понял, после выполнения совершенно стандартной команды,
версия 2.85.4. Проверьте. И что сделать дальше?
Мои действия?
Покажите лог, как минимум.
Ну и опишите - куда подключено устройство, как настроен порт. что в шину отправляется, что из шины получается. У меня не получается догадаться что за устрйоство, какой у него шаблон, настройки.
Устройство подключено к контроллеру Segnetics Matrix через ttyRS485-1 9600 8 N 2 Modbus ID10
регистры 40524 40526 40527 40528.
Лог и скан системного журнала прилагаю.
diag_output_AI35IDA5_2023-05-30-04.15.32.zip (138 KB)
Актуальная версия wb-mqtt-serial=2.86.0
Но версия с исправлением будет сегодня, в течении дня.
Обновите пожалуста пакеты, проверьте поведение.
Ну и не забудьте отключить Debug для wb-mqtt-serial.
Использование testing релиза имеет свои особенности, да. С одной стороны - все самое новое, с другой - периодически баги.
Пакеты обновил. Версия 2.86.0. Debug отключил.
Данные прочитались один раз.
Обновления данных нет. Веб интерфейс и каналы MQTT не обновляются.
Регистр 40524 float Датчик t
Регистры 40526, 40527, 40528 signet часы, минуты, секунды.
Да, исправление будет опубликовано в следующей версии.
Опубликован 2.86.1
