Savick
28.Декабрь.2024 14:41:19
1
Wiren Board 7.3.4, release wb-2410
Выполнил:
apt update && apt install -y nodejs git make g++ gcc build-essential
Setting up libgcc-10-dev:armhf (10.2.1-6) …
Setting up gpgsm (2.2.27-2+deb11u2) …
Setting up nodejs (20.5.1-deb-1nodesource1) …
Setting up dirmngr (2.2.27-2+deb11u2) …
Created symlink /etc/systemd/user/sockets.target.wants/dirmngr.socket → /usr/lib/systemd/user/dirmngr.socket.
Setting up git (1:2.30.2-1+deb11u3) …
Setting up gpg-wks-server (2.2.27-2+deb11u2) …
Setting up cpp (4:10.2.1-1) …
Setting up binutils-arm-linux-gnueabihf (2.35.2-2) …
Setting up libstdc+±10-dev:armhf (10.2.1-6) …
Setting up gpg-wks-client (2.2.27-2+deb11u2) …
Setting up binutils (2.35.2-2) …
Setting up dpkg-dev (1.20.13) …
Setting up gcc-10 (10.2.1-6) …
Setting up gnupg (2.2.27-2+deb11u2) …
Setting up g+±10 (10.2.1-6) …
Setting up gcc (4:10.2.1-1) …
Setting up g++ (4:10.2.1-1) …
update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode
Setting up build-essential (12.9) …
Processing triggers for libc-bin (2.31-13+deb11u11) …
пробую NPM
root@wirenboard-AENXSLZG:~# npm
node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.30' not found (required by node)* *node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version
GLIBCXX_3.4.29’ not found (required by node)
Как быть?
Я вижу что эта библиотека установлена.
Проверьте пожалуйста - удачно ли установлена.
Вот, для примера, полный лог установки:
Reading package lists... Done
Building dependency tree... Done
The following package was automatically installed and is no longer required:
libwbmqtt1-4
Use 'apt autoremove' to remove it.
The following additional packages will be installed:
binutils binutils-arm-linux-gnueabihf binutils-common cpp cpp-10 dirmngr dpkg-dev fakeroot g++-10 gcc-10 git-man gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan6 libassuan0 libatomic1 libbinutils libcc1-0 libctf-nobfd0
libctf0 libdpkg-perl liberror-perl libfakeroot libfile-fcntllock-perl libgcc-10-dev libgomp1 libisl23 libksba8 liblocale-gettext-perl libmpc3 libmpfr6 libnpth0 libstdc++-10-dev libubsan1 patch pinentry-curses
Suggested packages:
binutils-doc cpp-doc gcc-10-locales dbus-user-session pinentry-gnome3 tor debian-keyring gcc-10-doc gcc-multilib autoconf automake libtool flex bison gdb gcc-doc gettext-base git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitweb git-cvs git-mediawiki git-svn parcimonie xloadimage scdaemon bzr libstdc++-10-doc
make-doc ed diffutils-doc pinentry-doc
The following NEW packages will be installed:
binutils binutils-arm-linux-gnueabihf binutils-common build-essential cpp cpp-10 dirmngr dpkg-dev fakeroot g++ g++-10 gcc gcc-10 git git-man gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan6 libassuan0 libatomic1
libbinutils libcc1-0 libctf-nobfd0 libctf0 libdpkg-perl liberror-perl libfakeroot libfile-fcntllock-perl libgcc-10-dev libgomp1 libisl23 libksba8 liblocale-gettext-perl libmpc3 libmpfr6 libnpth0 libstdc++-10-dev libubsan1 make nodejs patch pinentry-curses
0 upgraded, 52 newly installed, 0 to remove and 4 not upgraded.
Need to get 85.0 MB of archives.
After this operation, 360 MB of additional disk space will be used.
Get:1 http://debian-mirror.wirenboard.com/debian bullseye/main armhf liblocale-gettext-perl armhf 1.07-4+b1 [18.3 kB]
Get:2 http://debian-mirror.wirenboard.com/debian bullseye/main armhf binutils-common armhf 2.35.2-2 [2220 kB]
Get:3 http://deb.wirenboard.com/wb6/bullseye stable/main armhf nodejs armhf 20.5.1-deb-1nodesource1 [27.0 MB]
Get:4 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libbinutils armhf 2.35.2-2 [403 kB]
Get:5 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libctf-nobfd0 armhf 2.35.2-2 [99.7 kB]
Get:6 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libctf0 armhf 2.35.2-2 [42.4 kB]
Get:7 http://debian-mirror.wirenboard.com/debian bullseye/main armhf binutils-arm-linux-gnueabihf armhf 2.35.2-2 [2408 kB]
Get:8 http://debian-mirror.wirenboard.com/debian bullseye/main armhf binutils armhf 2.35.2-2 [61.2 kB]
Get:9 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libisl23 armhf 0.23-1 [516 kB]
Get:10 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libmpfr6 armhf 4.1.0-3 [811 kB]
Get:11 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libmpc3 armhf 1.2.0-1 [36.7 kB]
Get:12 http://debian-mirror.wirenboard.com/debian bullseye/main armhf cpp-10 armhf 10.2.1-6 [6609 kB]
Get:13 http://debian-mirror.wirenboard.com/debian bullseye/main armhf cpp armhf 4:10.2.1-1 [19.7 kB]
Get:14 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libcc1-0 armhf 10.2.1-6 [39.2 kB]
Get:15 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libgomp1 armhf 10.2.1-6 [84.7 kB]
Get:16 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libatomic1 armhf 10.2.1-6 [6924 B]
Get:17 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libasan6 armhf 10.2.1-6 [2015 kB]
Get:18 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libubsan1 armhf 10.2.1-6 [746 kB]
Get:19 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libgcc-10-dev armhf 10.2.1-6 [694 kB]
Get:20 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gcc-10 armhf 10.2.1-6 [13.1 MB]
Get:21 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gcc armhf 4:10.2.1-1 [5204 B]
Get:22 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libstdc++-10-dev armhf 10.2.1-6 [1790 kB]
Get:23 http://debian-mirror.wirenboard.com/debian bullseye/main armhf g++-10 armhf 10.2.1-6 [7244 kB]
Get:24 http://debian-mirror.wirenboard.com/debian bullseye/main armhf g++ armhf 4:10.2.1-1 [1628 B]
Get:25 http://debian-mirror.wirenboard.com/debian bullseye/main armhf make armhf 4.3-4.1 [384 kB]
Get:26 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libdpkg-perl all 1.20.13 [1552 kB]
Get:27 http://debian-mirror.wirenboard.com/debian bullseye/main armhf patch armhf 2.7.6-7 [125 kB]
Get:28 http://debian-mirror.wirenboard.com/debian bullseye/main armhf dpkg-dev all 1.20.13 [2314 kB]
Get:29 http://debian-mirror.wirenboard.com/debian bullseye/main armhf build-essential armhf 12.9 [7704 B]
Get:30 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libassuan0 armhf 2.5.3-7.1 [44.2 kB]
Get:31 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gpgconf armhf 2.2.27-2+deb11u2 [532 kB]
Get:32 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libksba8 armhf 1.5.0-3+deb11u2 [105 kB]
Get:33 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libnpth0 armhf 1.6-3 [17.8 kB]
Get:34 http://debian-mirror.wirenboard.com/debian bullseye/main armhf dirmngr armhf 2.2.27-2+deb11u2 [722 kB]
Get:35 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libfakeroot armhf 1.25.3-1.1 [43.9 kB]
Get:36 http://debian-mirror.wirenboard.com/debian bullseye/main armhf fakeroot armhf 1.25.3-1.1 [85.1 kB]
Get:37 http://debian-mirror.wirenboard.com/debian bullseye/main armhf liberror-perl all 0.17029-1 [31.0 kB]
Get:38 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main armhf git-man all 1:2.30.2-1+deb11u3 [1831 kB]
Get:39 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main armhf git armhf 1:2.30.2-1+deb11u3 [5173 kB]
Get:40 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gnupg-l10n all 2.2.27-2+deb11u2 [1086 kB]
Get:41 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gnupg-utils armhf 2.2.27-2+deb11u2 [835 kB]
Get:42 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gpg armhf 2.2.27-2+deb11u2 [868 kB]
Get:43 http://debian-mirror.wirenboard.com/debian bullseye/main armhf pinentry-curses armhf 1.1.0-4 [60.6 kB]
Get:44 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gpg-agent armhf 2.2.27-2+deb11u2 [630 kB]
Get:45 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gpg-wks-client armhf 2.2.27-2+deb11u2 [509 kB]
Get:46 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gpg-wks-server armhf 2.2.27-2+deb11u2 [503 kB]
Get:47 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gpgsm armhf 2.2.27-2+deb11u2 [617 kB]
Get:48 http://debian-mirror.wirenboard.com/debian bullseye/main armhf gnupg all 2.2.27-2+deb11u2 [825 kB]
Get:49 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libalgorithm-diff-perl all 1.201-1 [43.3 kB]
Get:50 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libalgorithm-diff-xs-perl armhf 0.04-6+b1 [11.5 kB]
Get:51 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libalgorithm-merge-perl all 0.08-3 [12.7 kB]
Get:52 http://debian-mirror.wirenboard.com/debian bullseye/main armhf libfile-fcntllock-perl armhf 0.22-3+b7 [35.1 kB]
Fetched 85.0 MB in 19s (4424 kB/s)
Extracting templates from packages: 100%
Selecting previously unselected package liblocale-gettext-perl.
(Reading database ... 29855 files and directories currently installed.)
Preparing to unpack .../00-liblocale-gettext-perl_1.07-4+b1_armhf.deb ...
Unpacking liblocale-gettext-perl (1.07-4+b1) ...
Selecting previously unselected package binutils-common:armhf.
Preparing to unpack .../01-binutils-common_2.35.2-2_armhf.deb ...
Unpacking binutils-common:armhf (2.35.2-2) ...
Selecting previously unselected package libbinutils:armhf.
Preparing to unpack .../02-libbinutils_2.35.2-2_armhf.deb ...
Unpacking libbinutils:armhf (2.35.2-2) ...
Selecting previously unselected package libctf-nobfd0:armhf.
Preparing to unpack .../03-libctf-nobfd0_2.35.2-2_armhf.deb ...
Unpacking libctf-nobfd0:armhf (2.35.2-2) ...
Selecting previously unselected package libctf0:armhf.
Preparing to unpack .../04-libctf0_2.35.2-2_armhf.deb ...
Unpacking libctf0:armhf (2.35.2-2) ...
Selecting previously unselected package binutils-arm-linux-gnueabihf.
Preparing to unpack .../05-binutils-arm-linux-gnueabihf_2.35.2-2_armhf.deb ...
Unpacking binutils-arm-linux-gnueabihf (2.35.2-2) ...
Selecting previously unselected package binutils.
Preparing to unpack .../06-binutils_2.35.2-2_armhf.deb ...
Unpacking binutils (2.35.2-2) ...
Selecting previously unselected package libisl23:armhf.
Preparing to unpack .../07-libisl23_0.23-1_armhf.deb ...
Unpacking libisl23:armhf (0.23-1) ...
Selecting previously unselected package libmpfr6:armhf.
Preparing to unpack .../08-libmpfr6_4.1.0-3_armhf.deb ...
Unpacking libmpfr6:armhf (4.1.0-3) ...
Selecting previously unselected package libmpc3:armhf.
Preparing to unpack .../09-libmpc3_1.2.0-1_armhf.deb ...
Unpacking libmpc3:armhf (1.2.0-1) ...
Selecting previously unselected package cpp-10.
Preparing to unpack .../10-cpp-10_10.2.1-6_armhf.deb ...
Unpacking cpp-10 (10.2.1-6) ...
Selecting previously unselected package cpp.
Preparing to unpack .../11-cpp_4%3a10.2.1-1_armhf.deb ...
Unpacking cpp (4:10.2.1-1) ...
Selecting previously unselected package libcc1-0:armhf.
Preparing to unpack .../12-libcc1-0_10.2.1-6_armhf.deb ...
Unpacking libcc1-0:armhf (10.2.1-6) ...
Selecting previously unselected package libgomp1:armhf.
Preparing to unpack .../13-libgomp1_10.2.1-6_armhf.deb ...
Unpacking libgomp1:armhf (10.2.1-6) ...
Selecting previously unselected package libatomic1:armhf.
Preparing to unpack .../14-libatomic1_10.2.1-6_armhf.deb ...
Unpacking libatomic1:armhf (10.2.1-6) ...
Selecting previously unselected package libasan6:armhf.
Preparing to unpack .../15-libasan6_10.2.1-6_armhf.deb ...
Unpacking libasan6:armhf (10.2.1-6) ...
Selecting previously unselected package libubsan1:armhf.
Preparing to unpack .../16-libubsan1_10.2.1-6_armhf.deb ...
Unpacking libubsan1:armhf (10.2.1-6) ...
Selecting previously unselected package libgcc-10-dev:armhf.
Preparing to unpack .../17-libgcc-10-dev_10.2.1-6_armhf.deb ...
Unpacking libgcc-10-dev:armhf (10.2.1-6) ...
Selecting previously unselected package gcc-10.
Preparing to unpack .../18-gcc-10_10.2.1-6_armhf.deb ...
Unpacking gcc-10 (10.2.1-6) ...
Selecting previously unselected package gcc.
Preparing to unpack .../19-gcc_4%3a10.2.1-1_armhf.deb ...
Unpacking gcc (4:10.2.1-1) ...
Selecting previously unselected package libstdc++-10-dev:armhf.
Preparing to unpack .../20-libstdc++-10-dev_10.2.1-6_armhf.deb ...
Unpacking libstdc++-10-dev:armhf (10.2.1-6) ...
Selecting previously unselected package g++-10.
Preparing to unpack .../21-g++-10_10.2.1-6_armhf.deb ...
Unpacking g++-10 (10.2.1-6) ...
Selecting previously unselected package g++.
Preparing to unpack .../22-g++_4%3a10.2.1-1_armhf.deb ...
Unpacking g++ (4:10.2.1-1) ...
Selecting previously unselected package make.
Preparing to unpack .../23-make_4.3-4.1_armhf.deb ...
Unpacking make (4.3-4.1) ...
Selecting previously unselected package libdpkg-perl.
Preparing to unpack .../24-libdpkg-perl_1.20.13_all.deb ...
Unpacking libdpkg-perl (1.20.13) ...
Selecting previously unselected package patch.
Preparing to unpack .../25-patch_2.7.6-7_armhf.deb ...
Unpacking patch (2.7.6-7) ...
Selecting previously unselected package dpkg-dev.
Preparing to unpack .../26-dpkg-dev_1.20.13_all.deb ...
Unpacking dpkg-dev (1.20.13) ...
Selecting previously unselected package build-essential.
Preparing to unpack .../27-build-essential_12.9_armhf.deb ...
Unpacking build-essential (12.9) ...
Selecting previously unselected package libassuan0:armhf.
Preparing to unpack .../28-libassuan0_2.5.3-7.1_armhf.deb ...
Unpacking libassuan0:armhf (2.5.3-7.1) ...
Selecting previously unselected package gpgconf.
Preparing to unpack .../29-gpgconf_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpgconf (2.2.27-2+deb11u2) ...
Selecting previously unselected package libksba8:armhf.
Preparing to unpack .../30-libksba8_1.5.0-3+deb11u2_armhf.deb ...
Unpacking libksba8:armhf (1.5.0-3+deb11u2) ...
Selecting previously unselected package libnpth0:armhf.
Preparing to unpack .../31-libnpth0_1.6-3_armhf.deb ...
Unpacking libnpth0:armhf (1.6-3) ...
Selecting previously unselected package dirmngr.
Preparing to unpack .../32-dirmngr_2.2.27-2+deb11u2_armhf.deb ...
Unpacking dirmngr (2.2.27-2+deb11u2) ...
Selecting previously unselected package libfakeroot:armhf.
Preparing to unpack .../33-libfakeroot_1.25.3-1.1_armhf.deb ...
Unpacking libfakeroot:armhf (1.25.3-1.1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../34-fakeroot_1.25.3-1.1_armhf.deb ...
Unpacking fakeroot (1.25.3-1.1) ...
Selecting previously unselected package liberror-perl.
Preparing to unpack .../35-liberror-perl_0.17029-1_all.deb ...
Unpacking liberror-perl (0.17029-1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../36-git-man_1%3a2.30.2-1+deb11u3_all.deb ...
Unpacking git-man (1:2.30.2-1+deb11u3) ...
Selecting previously unselected package git.
Preparing to unpack .../37-git_1%3a2.30.2-1+deb11u3_armhf.deb ...
Unpacking git (1:2.30.2-1+deb11u3) ...
Selecting previously unselected package gnupg-l10n.
Preparing to unpack .../38-gnupg-l10n_2.2.27-2+deb11u2_all.deb ...
Unpacking gnupg-l10n (2.2.27-2+deb11u2) ...
Selecting previously unselected package gnupg-utils.
Preparing to unpack .../39-gnupg-utils_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gnupg-utils (2.2.27-2+deb11u2) ...
Selecting previously unselected package gpg.
Preparing to unpack .../40-gpg_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg (2.2.27-2+deb11u2) ...
Selecting previously unselected package pinentry-curses.
Preparing to unpack .../41-pinentry-curses_1.1.0-4_armhf.deb ...
Unpacking pinentry-curses (1.1.0-4) ...
Selecting previously unselected package gpg-agent.
Preparing to unpack .../42-gpg-agent_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg-agent (2.2.27-2+deb11u2) ...
Selecting previously unselected package gpg-wks-client.
Preparing to unpack .../43-gpg-wks-client_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg-wks-client (2.2.27-2+deb11u2) ...
Selecting previously unselected package gpg-wks-server.
Preparing to unpack .../44-gpg-wks-server_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpg-wks-server (2.2.27-2+deb11u2) ...
Selecting previously unselected package gpgsm.
Preparing to unpack .../45-gpgsm_2.2.27-2+deb11u2_armhf.deb ...
Unpacking gpgsm (2.2.27-2+deb11u2) ...
Selecting previously unselected package gnupg.
Preparing to unpack .../46-gnupg_2.2.27-2+deb11u2_all.deb ...
Unpacking gnupg (2.2.27-2+deb11u2) ...
Selecting previously unselected package libalgorithm-diff-perl.
Preparing to unpack .../47-libalgorithm-diff-perl_1.201-1_all.deb ...
Unpacking libalgorithm-diff-perl (1.201-1) ...
Selecting previously unselected package libalgorithm-diff-xs-perl.
Preparing to unpack .../48-libalgorithm-diff-xs-perl_0.04-6+b1_armhf.deb ...
Unpacking libalgorithm-diff-xs-perl (0.04-6+b1) ...
Selecting previously unselected package libalgorithm-merge-perl.
Preparing to unpack .../49-libalgorithm-merge-perl_0.08-3_all.deb ...
Unpacking libalgorithm-merge-perl (0.08-3) ...
Selecting previously unselected package libfile-fcntllock-perl.
Preparing to unpack .../50-libfile-fcntllock-perl_0.22-3+b7_armhf.deb ...
Unpacking libfile-fcntllock-perl (0.22-3+b7) ...
Selecting previously unselected package nodejs.
Preparing to unpack .../51-nodejs_20.5.1-deb-1nodesource1_armhf.deb ...
Unpacking nodejs (20.5.1-deb-1nodesource1) ...
Setting up libksba8:armhf (1.5.0-3+deb11u2) ...
Setting up libfile-fcntllock-perl (0.22-3+b7) ...
Setting up libalgorithm-diff-perl (1.201-1) ...
Setting up binutils-common:armhf (2.35.2-2) ...
Setting up libctf-nobfd0:armhf (2.35.2-2) ...
Setting up libnpth0:armhf (1.6-3) ...
Setting up libassuan0:armhf (2.5.3-7.1) ...
Setting up libgomp1:armhf (10.2.1-6) ...
Setting up libfakeroot:armhf (1.25.3-1.1) ...
Setting up libasan6:armhf (10.2.1-6) ...
Setting up fakeroot (1.25.3-1.1) ...
update-alternatives: using /usr/bin/fakeroot-sysv to provide /usr/bin/fakeroot (fakeroot) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/fakeroot.1.gz because associated file /usr/share/man/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/man1/faked.1.gz because associated file /usr/share/man/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/es/man1/fakeroot.1.gz because associated file /usr/share/man/es/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/es/man1/faked.1.gz because associated file /usr/share/man/es/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man1/fakeroot.1.gz because associated file /usr/share/man/fr/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man1/faked.1.gz because associated file /usr/share/man/fr/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/sv/man1/fakeroot.1.gz because associated file /usr/share/man/sv/man1/fakeroot-sysv.1.gz (of link group fakeroot) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/sv/man1/faked.1.gz because associated file /usr/share/man/sv/man1/faked-sysv.1.gz (of link group fakeroot) doesn't exist
Setting up liberror-perl (0.17029-1) ...
Setting up make (4.3-4.1) ...
Setting up libmpfr6:armhf (4.1.0-3) ...
Setting up gnupg-l10n (2.2.27-2+deb11u2) ...
Setting up libmpc3:armhf (1.2.0-1) ...
Setting up libatomic1:armhf (10.2.1-6) ...
Setting up patch (2.7.6-7) ...
Setting up libdpkg-perl (1.20.13) ...
Setting up libubsan1:armhf (10.2.1-6) ...
Setting up gpgconf (2.2.27-2+deb11u2) ...
Setting up git-man (1:2.30.2-1+deb11u3) ...
Setting up libbinutils:armhf (2.35.2-2) ...
Setting up libisl23:armhf (0.23-1) ...
Setting up libalgorithm-diff-xs-perl (0.04-6+b1) ...
Setting up libcc1-0:armhf (10.2.1-6) ...
Setting up liblocale-gettext-perl (1.07-4+b1) ...
Setting up gpg (2.2.27-2+deb11u2) ...
Setting up cpp-10 (10.2.1-6) ...
Setting up libalgorithm-merge-perl (0.08-3) ...
Setting up gnupg-utils (2.2.27-2+deb11u2) ...
Setting up libctf0:armhf (2.35.2-2) ...
Setting up pinentry-curses (1.1.0-4) ...
Setting up gpg-agent (2.2.27-2+deb11u2) ...
Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-browser.socket → /usr/lib/systemd/user/gpg-agent-browser.socket.
Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-extra.socket → /usr/lib/systemd/user/gpg-agent-extra.socket.
Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-ssh.socket → /usr/lib/systemd/user/gpg-agent-ssh.socket.
Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent.socket → /usr/lib/systemd/user/gpg-agent.socket.
Setting up libgcc-10-dev:armhf (10.2.1-6) ...
Setting up gpgsm (2.2.27-2+deb11u2) ...
Setting up nodejs (20.5.1-deb-1nodesource1) ...
Setting up dirmngr (2.2.27-2+deb11u2) ...
Setting up git (1:2.30.2-1+deb11u3) ...
Setting up gpg-wks-server (2.2.27-2+deb11u2) ...
Setting up cpp (4:10.2.1-1) ...
Setting up binutils-arm-linux-gnueabihf (2.35.2-2) ...
Setting up libstdc++-10-dev:armhf (10.2.1-6) ...
Setting up gpg-wks-client (2.2.27-2+deb11u2) ...
Setting up binutils (2.35.2-2) ...
Setting up dpkg-dev (1.20.13) ...
Setting up gcc-10 (10.2.1-6) ...
Setting up gnupg (2.2.27-2+deb11u2) ...
Setting up g++-10 (10.2.1-6) ...
Setting up gcc (4:10.2.1-1) ...
Setting up g++ (4:10.2.1-1) ...
Setting up build-essential (12.9) ...
Processing triggers for libc-bin (2.31-13+deb11u11) ...
Соответственно:
npm -v
9.8.0
Savick
28.Декабрь.2024 16:04:55
3
“Проверьте пожалуйста - удачно ли установлена.” - каким образом?
в логе ошибок нет.
полный лог:
root@wirenboard-AENXSLZG:~# apt update && apt install -y nodejs git make g++ gcc build-essential
Hit:1 http://debian-mirror.wirenboard.com/debian bullseye InRelease
Hit:2 http://debian-mirror.wirenboard.com/debian bullseye-updates InRelease
Hit:3 http://debian-mirror.wirenboard.com/debian bullseye-backports InRelease
Hit:4 http://debian-mirror.wirenboard.com/debian-security bullseye-security InRelease
Hit:5 http://deb.wirenboard.com/wb7/bullseye stable InRelease
All packages are up to date.
Suggested packages:
pinentry-curses
0 upgraded, 52 newly installed, 0 to remove and 0 not upgraded.
Get:3 http://deb.wirenboard.com/wb7/bullseye stable/main armhf nodejs armhf 20.5.1-deb-1nodesource1 [27.0 MB]
Fetched 85.0 MB in 10s (8904 kB/s)
(Reading database ... 29627 files and directories currently installed.)
введите или вставьте сюда код
Существует ли сам файл /lib/arm-linux-gnueabihf/libstdc++.so.6 - начать проверку целесообразно с этого.
Точнее - это симлинк, посмотрите куда он указывает, ну и сам файл - точно ли библиотека.
На котролллере работа с библиотеками не отличается от такой же на компьютере.
Savick
28.Декабрь.2024 16:17:00
5
Да. файл есть.
там же сказано … нужна версия - GLIBCXX_3.4.29 и GLIBCXX_3.4.30
а libstdc++.so.6 версия максимум GLIBCXX_3.4.28
Аналогично:
И
ls /lib/arm-linux-gnueabihf/ |grep libstdc
libstdc++.so.6
libstdc++.so.6.0.28
Выполните
apt update && apt upgrade -y
Savick
29.Декабрь.2024 12:41:27
7
не помогает говорит что все уже новое.
node хочет версии 29 и 30
Не воспроизводится.
Проверьте - сбросив контроллер к дефолтным установками образом релиза 2410.
Добрый день. Получилось сбросить?
