Не удается установить Node-Red после обновления системы с W2201 на W2207
apt update && apt install -y nodejs git make g++ gcc build-essential
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 Index of /debian stretch InRelease
Hit:3 Index of /debian stretch-updates InRelease
Hit:4 Index of /debian stretch Release
Hit:5 http://deb.wirenboard.com/wb6/stretch stable InRelease
Hit:6 Index of /debian stretch-backports InRelease
Reading package lists… Done
Building dependency tree
1 package can be upgraded. Run ‘apt list --upgradable’ to see it.
build-essential is already the newest version (12.3).
g++ is already the newest version (4:6.3.0-4).
gcc is already the newest version (4:6.3.0-4).
git is already the newest version (1:2.11.0-3+deb9u7).
make is already the newest version (4.1-9.1).
The following NEW packages will be installed:
nodejs
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 16.2 MB of archives.
After this operation, 86.4 MB of additional disk space will be used.
Get:1 http://deb.wirenboard.com/wb6/stretch stable/main armhf nodejs armhf 12.19.0-1nodesource1 [16.2 MB]
Fetched 16.2 MB in 8min 51s (30.5 kB/s)
Selecting previously unselected package nodejs.
(Reading database … 30354 files and directories currently installed.)
Preparing to unpack …/nodejs_12.19.0-1nodesource1_armhf.deb …
Unpacking nodejs (12.19.0-1nodesource1) …
Setting up nodejs (12.19.0-1nodesource1) …
root@wirenboard-AE3UHZCX:~# npm install -g --unsafe-perm node-red@2.2
npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
npm ERR! Unexpected end of JSON input while parsing near ‘…id":"SHA256:jl3bwswu8’
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-12-28T19_41_13_108Z-debug.log
Нужна помощь
