_ _ _
__ _(_)_ __ ___ _ __ | |__ ___ __ _ _ __ __| |
\ \ /\ / / | '__/ _ \ '_ \| '_ \ / _ \ / _` | '__/ _` |
\ V V /| | | | __/ | | | |_) | (_) | (_| | | | (_| |
\_/\_/ |_|_| \___|_| |_|_.__/ \___/ \__,_|_| \__,_|
Welcome to Wiren Board 6.7.2 (s/n A5A6674T), release wb-2307 (as stable)
Linux wirenboard-A5A6674T 5.10.35-wb142 #1 Thu Jul 20 07:59:09 UTC 2023 armv7l GNU/Linux
System load: 0.76 1.00 1.05 Up time: 34 days 6:29
Memory usage: 77% of 494M Usage of /: 38% of 2.0G /mnt/data: 29% of 4.7G
The following network interfaces were found in /etc/network/interfaces
which means they are currently configured by ifupdown:
- eth0
- eth1
- wlan0
If you want to manage those interfaces with NetworkManager instead
remove their configuration from /etc/network/interfaces
or use web interface config editor to remove them.
12 package updates are available; type 'apt update && apt upgrade' to update them.
при обновлении:
Настраивается пакет wb-configs (3.18.5-wb100) …
Удаляется «отклонение /etc/ssh/sshd_config в /etc/ssh/sshd_config.wb-orig из-за wb-configs»
*** OMINOUS WARNING ***: /etc/hostname is not linked to either hostname.wb or hostname.wb-orig
*** OMINOUS WARNING ***: /etc/fstab is not linked to either fstab.wb or fstab.wb-orig
*** OMINOUS WARNING ***: /etc/network/interfaces is not linked to either interfaces.wb or interfaces.wb-orig
*** OMINOUS WARNING ***: /etc/dnsmasq.conf is not linked to either dnsmasq.conf.wb or dnsmasq.conf.wb-orig
*** OMINOUS WARNING ***: /etc/hostapd.conf is not linked to either hostapd.conf.wb or hostapd.conf.wb-orig
Добавляется «отклонение /etc/ssh/sshd_config в /etc/ssh/sshd_config.wb-orig из-за wb-configs»
Failed to get unit file state for rsyslog.service: No such file or directory
rsyslog is a disabled or a static unit not running, not starting it.
Setting ownership www-data to /mnt/data/uploads
при обновлении вижу зловещие предупреждения и нет файла syslog.service, так и задумано и это можно игнорировать или сигнализирует о неисправности и надо принимать меры?
У меня точно такая же ошибка как в первом сообщении. На этом процесс обновления зависает. И перед этим Web-интерфейс стал полностью недоступен (никаких ручных действий за прошедший месяц не совершалось; все работало нормально).
Setting up wb-configs (3.18.11) …
Removing ‘diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.wb-orig by wb-configs’
*** OMINOUS WARNING ***: /etc/locale.gen is not linked to either locale.gen.wb or locale.gen.wb-orig
Adding ‘diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.wb-orig by wb-configs’
