Не запускается zigbe2mqtt
Устанавливал zigbee2mqtt по инструкции из wiki
Во время установки ошибок не было, в configuration.yaml порт исправил на 4.
В логах ошибка при старте Starting zigbee-herdsman.
Вывод journalctl -u zigbee2mqtt | tail -n100:
Спойлер
| ^18, you are running v12.19.0!
дек 22 13:12:00 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:info  2022-12-22 13:12:00: Logging to console and directo        ry: '/mnt/data/root/zigbee2mqtt/data/log/2022-12-22.13-12-00' filename: log.txt
дек 22 13:12:00 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:info  2022-12-22 13:12:00: Starting Zigbee2MQTT version 1        .25.2 (commit #e8528512)
дек 22 13:12:00 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:info  2022-12-22 13:12:00: Starting zigbee-herdsman (0.14        .34)
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:error 2022-12-22 13:12:04: Error while starting zigbee-he        rdsman
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:error 2022-12-22 13:12:04: Failed to start zigbee
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:error 2022-12-22 13:12:04: Check https://www.zigbee2mqtt.        io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:error 2022-12-22 13:12:04: Exiting...
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: Zigbee2MQTT:error 2022-12-22 13:12:04: Error: Error while opening ser        ialport 'Error: Error Resource temporarily unavailable Cannot lock port'
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]:     at SerialPort.<anonymous> (/mnt/data/root/zigbee2mqtt/node_module        s/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]:     at SerialPort._error (/mnt/data/root/zigbee2mqtt/node_modules/@se        rialport/stream/lib/index.js:198:14)
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]:     at /mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib        /index.js:242:12
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! code ELIFECYCLE
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! errno 1
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! zigbee2mqtt@1.25.2 start: `node index.js`
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! Exit status 1
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! Failed at the zigbee2mqtt@1.25.2 start script.
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! This is probably not a problem with npm. There is likely add        itional logging output above.
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! A complete log of this run can be found in:
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR!     /root/.npm/_logs/2022-12-22T10_12_04_878Z-debug.log
дек 22 13:12:04 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILU        RE
дек 22 13:12:04 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Unit entered failed state.
дек 22 13:12:04 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
дек 22 13:13:34 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Service hold-off time over, scheduling restart.
дек 22 13:13:34 wirenboard-A272Y2JH systemd[1]: Stopped zigbee2mqtt.
дек 22 13:13:34 wirenboard-A272Y2JH systemd[1]: Started zigbee2mqtt.
дек 22 13:13:37 wirenboard-A272Y2JH npm[15215]: > zigbee2mqtt@1.25.2 start /mnt/data/root/zigbee2mqtt
дек 22 13:13:37 wirenboard-A272Y2JH npm[15215]: > node index.js
дек 22 13:13:38 wirenboard-A272Y2JH npm[15215]:                 Zigbee2MQTT requires node version ^14 || ^16 || ^17 |        | ^18, you are running v12.19.0!
дек 22 13:13:47 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:info  2022-12-22 13:13:47: Logging to console and directo        ry: '/mnt/data/root/zigbee2mqtt/data/log/2022-12-22.13-13-47' filename: log.txt
дек 22 13:13:47 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:info  2022-12-22 13:13:47: Starting Zigbee2MQTT version 1        .25.2 (commit #e8528512)
дек 22 13:13:47 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:info  2022-12-22 13:13:47: Starting zigbee-herdsman (0.14        .34)
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Error while starting zigbee-he        rdsman
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Failed to start zigbee
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Check https://www.zigbee2mqtt.        io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Exiting...
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Error: Error while opening ser        ialport 'Error: Error Resource temporarily unavailable Cannot lock port'
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]:     at SerialPort.<anonymous> (/mnt/data/root/zigbee2mqtt/node_module        s/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]:     at SerialPort._error (/mnt/data/root/zigbee2mqtt/node_modules/@se        rialport/stream/lib/index.js:198:14)
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]:     at /mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib        /index.js:242:12
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! code ELIFECYCLE
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! errno 1
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! zigbee2mqtt@1.25.2 start: `node index.js`
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! Exit status 1
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! Failed at the zigbee2mqtt@1.25.2 start script.
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! This is probably not a problem with npm. There is likely add        itional logging output above.
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! A complete log of this run can be found in:
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR!     /root/.npm/_logs/2022-12-22T10_13_51_629Z-debug.log
дек 22 13:13:51 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILU        RE
дек 22 13:13:51 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Unit entered failed state.
дек 22 13:13:51 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
root@wirenboard-A272Y2JH:~#
journalctl -u zigbee2mqtt | systemctl restart zigbee2mqtt
root@wirenboard-A272Y2JH:~# journalctl -u zigbee2mqtt | tail -n100
дек 22 13:12:04 wirenboard-A272Y2JH npm[14306]: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
дек 22 13:12:04 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
дек 22 13:13:38 wirenboard-A272Y2JH npm[15215]:                 Zigbee2MQTT requires node version ^14 || ^16 || ^17 || ^18, you are running v12.19.0!
дек 22 13:13:47 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:info  2022-12-22 13:13:47: Logging to console and directory: '/mnt/data/root/zigbee2mqtt/data/log/2022-12-22.13-13-47' filename: log.txt
дек 22 13:13:47 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:info  2022-12-22 13:13:47: Starting Zigbee2MQTT version 1.25.2 (commit #e8528512)
дек 22 13:13:47 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:info  2022-12-22 13:13:47: Starting zigbee-herdsman (0.14.34)
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Error while starting zigbee-herdsman
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: Zigbee2MQTT:error 2022-12-22 13:13:51: Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]:     at SerialPort.<anonymous> (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]:     at SerialPort._error (/mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]:     at /mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
дек 22 13:13:51 wirenboard-A272Y2JH npm[15215]: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
дек 22 13:13:51 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
дек 22 13:15:21 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Service hold-off time over, scheduling restart.
дек 22 13:15:21 wirenboard-A272Y2JH systemd[1]: Stopped zigbee2mqtt.
дек 22 13:15:21 wirenboard-A272Y2JH systemd[1]: Started zigbee2mqtt.
дек 22 13:15:24 wirenboard-A272Y2JH npm[16108]: > zigbee2mqtt@1.25.2 start /mnt/data/root/zigbee2mqtt
дек 22 13:15:24 wirenboard-A272Y2JH npm[16108]: > node index.js
дек 22 13:15:25 wirenboard-A272Y2JH npm[16108]:                 Zigbee2MQTT requires node version ^14 || ^16 || ^17 || ^18, you are running v12.19.0!
дек 22 13:15:34 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:info  2022-12-22 13:15:34: Logging to console and directory: '/mnt/data/root/zigbee2mqtt/data/log/2022-12-22.13-15-34' filename: log.txt
дек 22 13:15:34 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:info  2022-12-22 13:15:34: Starting Zigbee2MQTT version 1.25.2 (commit #e8528512)
дек 22 13:15:34 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:info  2022-12-22 13:15:34: Starting zigbee-herdsman (0.14.34)
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:error 2022-12-22 13:15:38: Error while starting zigbee-herdsman
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:error 2022-12-22 13:15:38: Failed to start zigbee
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:error 2022-12-22 13:15:38: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:error 2022-12-22 13:15:38: Exiting...
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: Zigbee2MQTT:error 2022-12-22 13:15:38: Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]:     at SerialPort.<anonymous> (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]:     at SerialPort._error (/mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]:     at /mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! code ELIFECYCLE
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! errno 1
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! zigbee2mqtt@1.25.2 start: `node index.js`
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! Exit status 1
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! Failed at the zigbee2mqtt@1.25.2 start script.
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR! A complete log of this run can be found in:
дек 22 13:15:38 wirenboard-A272Y2JH npm[16108]: npm ERR!     /root/.npm/_logs/2022-12-22T10_15_38_685Z-debug.log
дек 22 13:15:38 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
дек 22 13:15:38 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Unit entered failed state.
дек 22 13:15:38 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
дек 22 13:17:08 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Service hold-off time over, scheduling restart.
дек 22 13:17:08 wirenboard-A272Y2JH systemd[1]: Stopped zigbee2mqtt.
дек 22 13:17:08 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Start request repeated too quickly.
дек 22 13:17:08 wirenboard-A272Y2JH systemd[1]: Failed to start zigbee2mqtt.
дек 22 13:17:08 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Unit entered failed state.
дек 22 13:17:08 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
дек 22 14:00:49 wirenboard-A272Y2JH systemd[1]: Started zigbee2mqtt.
дек 22 14:00:52 wirenboard-A272Y2JH npm[5893]: > zigbee2mqtt@1.25.2 start /mnt/data/root/zigbee2mqtt
дек 22 14:00:52 wirenboard-A272Y2JH npm[5893]: > node index.js
дек 22 14:00:53 wirenboard-A272Y2JH npm[5893]:                 Zigbee2MQTT requires node version ^14 || ^16 || ^17 || ^18, you are running v12.19.0!
дек 22 14:01:02 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:info  2022-12-22 14:01:02: Logging to console and directory: '/mnt/data/root/zigbee2mqtt/data/log/2022-12-22.14-01-02' filename: log.txt
дек 22 14:01:02 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:info  2022-12-22 14:01:02: Starting Zigbee2MQTT version 1.25.2 (commit #e8528512)
дек 22 14:01:02 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:info  2022-12-22 14:01:02: Starting zigbee-herdsman (0.14.34)
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:error 2022-12-22 14:01:06: Error while starting zigbee-herdsman
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:error 2022-12-22 14:01:06: Failed to start zigbee
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:error 2022-12-22 14:01:06: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:error 2022-12-22 14:01:06: Exiting...
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: Zigbee2MQTT:error 2022-12-22 14:01:06: Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]:     at SerialPort.<anonymous> (/mnt/data/root/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]:     at SerialPort._error (/mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]:     at /mnt/data/root/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! code ELIFECYCLE
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! errno 1
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! zigbee2mqtt@1.25.2 start: `node index.js`
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! Exit status 1
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! Failed at the zigbee2mqtt@1.25.2 start script.
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR! A complete log of this run can be found in:
дек 22 14:01:06 wirenboard-A272Y2JH npm[5893]: npm ERR!     /root/.npm/_logs/2022-12-22T11_01_06_960Z-debug.log
дек 22 14:01:07 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
дек 22 14:01:07 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Unit entered failed state.
дек 22 14:01:07 wirenboard-A272Y2JH systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Вывод npm start:
Спойлер
root@wirenboard-A272Y2JH:~# systemctl stop zigbee2mqtt
root@wirenboard-A272Y2JH:~# cd /mnt/data/root/zigbee2mqtt/
root@wirenboard-A272Y2JH:/mnt/data/root/zigbee2mqtt# npm start
> node index.js
Zigbee2MQTT:info  2022-12-22 14:06:00: Logging to console and directory: '/mnt/data/root/zigbee2mqtt/data/log/2022-12-22.14-06-00' filename: log.txt
Zigbee2MQTT:info  2022-12-22 14:06:00: Starting Zigbee2MQTT version 1.25.2 (commit #e8528512)
Zigbee2MQTT:info  2022-12-22 14:06:00: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:error 2022-12-22 14:06:04: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-12-22 14:06:04: Failed to start zigbee
Zigbee2MQTT:error 2022-12-22 14:06:04: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-12-22 14:06:04: Exiting...
Zigbee2MQTT:error 2022-12-22 14:06:04: Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
npm ERR! errno 1
npm ERR!
npm ERR!     /root/.npm/_logs/2022-12-22T11_06_04_344Z-debug.log
Ну и соответственно вопросы: Какой порт указан в конфиге?
Существует ли он в системе? Если да - то чем (каким процессом) он в момент до запуска z2m занят?
А, и еще: а как получилось логи сохранить с таким количеством проблелов в середине строки?
Configuration.yaml :
port: /dev/ttyMOD4
Что значит существует-ли в системе? Физически?
Лог просто скопирован выделением из Putty
Не может быть проблеммы из за того, что в mod4 установлен WBE2R-R-ZIGBEE v.2, а в MOD1 WBE2R-R-ZIGBEE-SH ?
Да, есть ли этот порт по этому пути. То есть: сконфигурирован ли модуль в wb-hardware.conf?
Нет, не думаю. Но софт который обычно работает с WBE2R-R-ZIGBEE-SH имеет свойство занимать порты. Так что, как и просил - проверьте, занят ли чем-то порт. И если занят - то чем.
Спасибо большое, всему виной был запущенный спрутхаб, хотя я им и не пользуюсь. Остановил в нём контроллер zigbee и всё заработало.
