Не заводимся после ребута, wb-watch-configs
root 328 0.0 0.0 1432 296 ? Ss 12:20 0:00 /bin/sh -c /usr/bin/wb-watch-configs cat /var/run/wb-configs.watch
root 331 0.0 0.3 2724 1788 ? S 12:20 0:00 _ /bin/bash /usr/bin/wb-watch-configs /etc/passwd /etc/shadow /etc/group /etc/gshadow /etc/localtime
root 349 0.0 0.0 1536 316 ? S 12:20 0:00 _ inotifywait -m --event close_write,moved_to --format %w%f %e /etc
root 350 0.0 0.2 2728 1500 ? S 12:20 0:00 _ /bin/bash /usr/bin/wb-watch-configs /etc/passwd /etc/shadow /etc/group /etc/gshadow /etc/localtime
Вот это крутится по циклу уже около часа, демоны не стартуют. Ребут был холодный, увы, но все равно - нельзя же так!
В логах ничего понятного:
Apr 2 14:01:00 wirenboard-AGPLM2T7 wb-daemon-watchdogs: Error: Connection refused
Apr 2 14:01:00 wirenboard-AGPLM2T7 wb-daemon-watchdogs[5290]: Error: Connection refused
Apr 2 14:01:04 wirenboard-AGPLM2T7 wb-daemon-watchdogs[5290]: Error: Connection refused
Apr 2 14:01:04 wirenboard-AGPLM2T7 wb-daemon-watchdogs: Error: Connection refused
Apr 2 14:01:04 wirenboard-AGPLM2T7 wb-daemon-watchdogs: wb-mqtt-confed check failed, reload wb-mqtt-confed
Apr 2 14:01:04 wirenboard-AGPLM2T7 wb-daemon-watchdogs[5290]: wb-mqtt-confed check failed, reload wb-mqtt-confed
Apr 2 14:02:01 wirenboard-AGPLM2T7 wb-daemon-watchdogs: Error: Connection refused
Apr 2 14:02:02 wirenboard-AGPLM2T7 wb-daemon-watchdogs[9496]: Error: Connection refused
Apr 2 14:02:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs: Error: Connection refused
Apr 2 14:02:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs: wb-mqtt-confed check failed, reload wb-mqtt-confed
Apr 2 14:02:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs[9496]: Error: Connection refused
Apr 2 14:02:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs[9496]: wb-mqtt-confed check failed, reload wb-mqtt-confed
Apr 2 14:03:02 wirenboard-AGPLM2T7 wb-daemon-watchdogs: Error: Connection refused
Apr 2 14:03:02 wirenboard-AGPLM2T7 wb-daemon-watchdogs[13584]: Error: Connection refused
Apr 2 14:03:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs[13584]: Error: Connection refused
Apr 2 14:03:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs: Error: Connection refused
Apr 2 14:03:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs: wb-mqtt-confed check failed, reload wb-mqtt-confed
Apr 2 14:03:05 wirenboard-AGPLM2T7 wb-daemon-watchdogs[13584]: wb-mqtt-confed check failed, reload wb-mqtt-confed
Кто-то куда-то кого-то посылает, в результате контроллер НЕ работает. Это - косяк.
Вероятной причиной была загаженная база москиты: после полугода аптайма mosquitto разгоняется от минуты до пятнадцати, пытаясь прохавать базу в пару гигов.
Удалил базу, зачавкало (от руки запустил все демоны, повторный ребут не пробовал).
Надо мне убирать persistence вообще, похоже… ибо ГДЕ регулировать максимальный размер базы, я найти не смог.
А вам, дражайшие авторы, ставить таймаут на старт москиты - скажем, 10мин, и по его истечении грохать базу и перезапускать демона. Как идея?
Сейчас работа идет по замене брокера на следующую версию. В которой уже бага нету.
Да, можно, причем КМК способом systemctl, вызывая скрипт.
