Нестандартные функции выключателей
(function () {
'use strict';
var ActionButtons = {};
 * Function that identifies what kind of press was performed: single, double or long press;
 * and assigns an action for each type of press.
 * @param  {string} trigger         -  Name of device and control in the following format: "<device>/<control>".
 * @param  {object} action          -  Defines actions to be taken for each type of button press.
 *                                  Key: "singlePress" or "doublePress" or "longPress" or "longRelease".
 *                                  Value: Object of the following structure {func: <function name>, prop: <array of parameters to be passed>}
 *                                  Example:
 *                                      singlePress: {func: myFunc1, prop: ["wb-mr6c_1", "K1"]},
 *                                      doublePress: {func: myFunc2, prop: ["wb-mrgbw-d_2", "RGB", "255;177;85"]},
 *                                      longPress: {func: myFunc3, prop: []},
 *                                      longRelease: {func: myFunc4, prop: []}
 * @param  {number} timeToNextPress -  Time (ms) after button up to wait for the next press before reseting the counter. Default is 300 ms.
 * @param  {number} timeOfLongPress -  Time (ms) after button down to be considered as as a long press. Default is 1000 ms (1 sec).
ActionButtons.onButtonPress = function (trigger, action, timeToNextPress, timeOfLongPress) {
    log.info("LongPress ActionButtons.onButtonPress")//Это лог. Он попадает в /var/log/messages
    var buttonPressedCounter = 0;
    var timerWaitNextShortPress = null;
    var timerLongPress = null;
    var isLongPress = false;
    var ruleName = "on_button_press_" + trigger.replace("/", "_");
    defineRule(ruleName, {
        whenChanged: trigger,
          log.info("LongPress defineRule")//Это лог. Он попадает в /var/log/messages
            // If button is pressed, wait for a long press
            if (newValue) {
                if (timerWaitNextShortPress) {
                    clearTimeout(timerWaitNextShortPress);
                timerLongPress = setTimeout(function () {
                    if (typeof action.longPress === "object") {
                        if (typeof action.longPress.func === "function") {
                            action.longPress.func.apply(this, action.longPress.prop);
                    // log(">>>>>>> long press <<<<<<");
                    isLongPress = true;  // Long press identified, we will skip short press
                }, timeOfLongPress);
            // If button is released, then it is not a "long press", start to count clicks
            else {
                if (!isLongPress) {
                    clearTimeout(timerLongPress);
                    buttonPressedCounter += 1;
                    timerWaitNextShortPress = setTimeout(function () {
                        switch (buttonPressedCounter) {
                        // Counter equals 1 - it's a single short press
                        case 1:
                            if (typeof action.singlePress === "object") {
                                if (typeof action.singlePress.func === "function") {
                                    action.singlePress.func.apply(this, action.singlePress.prop);
                            // log(">>>>>> short press - single <<<<<<");
                            break;
                        // Counter equals 2 - it's a double short press
                        case 2:
                            if (typeof action.doublePress === "object") {
                                if (typeof action.doublePress.func === "function") {
                                    action.doublePress.func.apply(this, action.doublePress.prop);
                            // log(">>>>>> short press - double <<<<<<");
                            break;
                        // Reset the counter
                    }, timeToNextPress);
                // Catch button released after long press
                else {
                    if (typeof action.longRelease === "object") {
                        if (typeof action.longRelease.func === "function") {
                            if (typeof action.longRelease.prop === "array") {
                                action.longRelease.func.apply(this, action.longRelease.prop);
                            } else {
                                action.longRelease.func.apply(this, []);
// export as Node module / AMD module / browser variable
if (typeof exports === 'object' && typeof module !== 'undefined') {
    module.exports = ActionButtons;
} else if (typeof define === 'function' && define.amd) {
    define(ActionButtons);
} else {
    global.ActionButtons = ActionButtons;
ActionButtons.onButtonPress(
"wb-mio-gpio_157:1/IN14",          //Вход, за которым следим.
    singlePress: {
       func: switchRelay,
       prop: ["wb-mio-gpio_157:2", "K1"]
    doublePress: {
       func: switchRelay, prop: ["wb-mio-gpio_157:2", "K2"]
        //func: switchDimmerRGB,
        //prop: ["wb-mr6c_10", "K2", "wb-mrgbw-d_24"]
    longPress: {
       func: switchRelay, prop: ["wb-mio-gpio_157:2", "K3"]
        //func: setRandomRGB,
300, 1000
* Helper Functions
function switchRelay(device, control) { //Принимает в параметрах устройство и выход. Переключает состояние выхода на противоположное.
  log.info("LongPress switchRelay" ,device, control)//Это лог. Он попадает в /var/log/messages
  dev[device][control] = !dev[device + "/" + control];
function switchDimmerRGB(relayDevice, relayControl, dimmerDevice) {
   dev[relayDevice][relayControl] = true;
   if (dev[dimmerDevice + "/RGB"] !== "0;0;0") {
     dev[dimmerDevice]["RGB"] = "0;0;0";
   else {
     dev[dimmerDevice]["RGB"] = dev[relayDevice + "/RGB"];
function setRandomRGB(relayDevice, relayControl, dimmerDevice) {
  dev[relayDevice + "/RGB"] = "" + Math.floor(Math.random() * 255) + ";" + Math.floor(Math.random() * 255) + ";" + Math.floor(Math.random() * 255);
Все вставляем в один скрипт.
singlePress
doublePress
longPress
вызывают хелпер-функции соответственно. В них можно уже то что нужно прописать.
