ON / OFF при старте zigbee2mqtt
При старте сервиса реле переходит в статус ON и через секунду OFF
Подскажите, чо это за фича/баг.
Feb 21 11:08:26 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:26: zigbee-herdsman started
Feb 21 11:08:26 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:26: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":2,"minorrel":0,"product":0,"revision":"","transportrev":2},"type":"zStack12"}'
Feb 21 11:08:27 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:27: Currently 2 devices are joined:
Feb 21 11:08:27 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:27: MOES_1 (0x842e14fffe0e137d): MS-104Z - Moes Smart light switch module (1 gang) (Router)
Feb 21 11:08:27 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:27: 0x842e14fffe0e1332 (0x842e14fffe0e1332): MS-104Z - Moes Smart light switch module (1 gang) (Router)
Feb 21 11:08:27 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:27: Zigbee: disabling joining new devices.
Feb 21 11:08:27 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:27: Started frontend on port 0.0.0.0:8081
Feb 21 11:08:27 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:27: Connecting to MQTT server at mqtt://localhost
Feb 21 11:08:28 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:28: Connected to MQTT server
Feb 21 11:08:28 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:28: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Feb 21 11:08:28 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:28: MQTT publish: topic 'zigbee2mqtt/MOES_1', payload '{"last_seen":1645422689006,"state":"OFF"}'
Feb 21 11:08:28 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:28: MQTT publish: topic 'zigbee2mqtt/0x842e14fffe0e1332', payload '{"last_seen":1643129127714,"state":"OFF"}'
Feb 21 11:08:29 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:29: MQTT publish: topic 'zigbee2mqtt/MOES_1', payload '{"last_seen":1645423709428,"linkquality":96,"state":"ON"}'
Feb 21 11:08:29 wirenboard-ANIE34IU npm[445]: Zigbee2MQTT:info  2022-02-21 11:08:29: MQTT publish: topic 'zigbee2mqtt/MOES_1', payload '{"last_seen":1645423709837,"linkquality":96,"state":"OFF"}'
Перезапускаете именно zigbee2mqtt?
Если перезапустить его при остановленном wb-rules - то же самое?
Перезапускаю mosquitto - moes_1 мыргает.
В логах москита только mqttjs и нодеред мелькают
mqttjs - это я так понимаю zigbee2mqtt ?
хоть zigbee2mqtt хоть mosquitto реле вкл/выкл.
А зачем брокер перезапускать? Немного не понимаю цели.
Нет.
zigbee2mqtt - процесс node index.js
mqttjs - что-то из NodeRed.
открытие ворот при включении или рестарте WB.
Происходит именно CLICK
nodered - остановил все потоки.
mqttjs_f7f2a631 0 zigbee2mqtt/# Появляется при рестарте отдноименного сервиса.
Больше обращений к топику не вижу, только от mqttjs_f7f2a631
приконнектил zigbee2mqtt к пустому mosquitto - та же ерунда. Два моеса оба мыргают при старте.
Да, просмотрел - увидел
mqttjs:client _sendPacket :: (mqttjs_4def23d2) ::  end +0ms
Если реле физически срабатыdает, а только отображение в топиках - но и физика - похоже на баг при восстановлении связи.
Sonoff при перезапуске zigbee2mqtt - остаются в прежнем состоянии.
