Отлично, продиагностируем.
Остановите nodered, заодно wb-rules.
Подпишитесь на устройство целиком.
Затем включите из веб-интерфейса канал реле.
а как остановить wb-rules?
Совершенно штатной для компьютера командой systemctl stop wb-rules
сделано
root@wirenboard-A7X5EPKR:~# systemctl stop wb-rules
root@wirenboard-A7X5EPKR:~# mosquitto_sub -t “/devices/wb-mrm2-mini_54/#” -v
/devices/wb-mrm2-mini_54/meta {“driver”:“wb-modbus”,“title”:{“en”:“WB-MRM2-mini/NO 54”}}
/devices/wb-mrm2-mini_54/meta/driver wb-modbus
/devices/wb-mrm2-mini_54/meta/name WB-MRM2-mini/NO 54
/devices/wb-mrm2-mini_54/controls/Input 1 0
/devices/wb-mrm2-mini_54/controls/Input 1/meta {“order”:1,“readonly”:true,“title”:{“ru”:“Вход 1”},“type”:“switch”}
/devices/wb-mrm2-mini_54/controls/Input 1/meta/order 1
/devices/wb-mrm2-mini_54/controls/Input 1/meta/readonly 1
/devices/wb-mrm2-mini_54/controls/Input 1/meta/type switch
/devices/wb-mrm2-mini_54/controls/K1 0
/devices/wb-mrm2-mini_54/controls/K1/meta {“order”:5,“readonly”:false,“type”:“switch”}
/devices/wb-mrm2-mini_54/controls/K1/meta/order 5
/devices/wb-mrm2-mini_54/controls/K1/meta/readonly 0
/devices/wb-mrm2-mini_54/controls/K1/meta/type switch
/devices/wb-mrm2-mini_54/controls/K2 0
/devices/wb-mrm2-mini_54/controls/K2/meta {“order”:6,“readonly”:false,“type”:“switch”}
/devices/wb-mrm2-mini_54/controls/K2/meta/order 6
/devices/wb-mrm2-mini_54/controls/K2/meta/readonly 0
/devices/wb-mrm2-mini_54/controls/K2/meta/type switch
/devices/wb-mrm2-mini_54/controls/Input 2 0
/devices/wb-mrm2-mini_54/controls/Input 2/meta {“order”:3,“readonly”:true,“title”:{“ru”:“Вход 2”},“type”:“switch”}
/devices/wb-mrm2-mini_54/controls/Input 2/meta/order 3
/devices/wb-mrm2-mini_54/controls/Input 2/meta/readonly 1
/devices/wb-mrm2-mini_54/controls/Input 2/meta/type switch
/devices/wb-mrm2-mini_54/controls/Input 1 counter 0
/devices/wb-mrm2-mini_54/controls/Input 1 counter/meta {“order”:2,“readonly”:true,“title”:{“ru”:“Счетчик 1”},“type”:“value”}
/devices/wb-mrm2-mini_54/controls/Input 1 counter/meta/order 2
/devices/wb-mrm2-mini_54/controls/Input 1 counter/meta/readonly 1
/devices/wb-mrm2-mini_54/controls/Input 1 counter/meta/type value
/devices/wb-mrm2-mini_54/controls/Input 2 counter 41
/devices/wb-mrm2-mini_54/controls/Input 2 counter/meta {“order”:4,“readonly”:true,“title”:{“ru”:“Счетчик 2”},“type”:“value”}
/devices/wb-mrm2-mini_54/controls/Input 2 counter/meta/order 4
/devices/wb-mrm2-mini_54/controls/Input 2 counter/meta/readonly 1
/devices/wb-mrm2-mini_54/controls/Input 2 counter/meta/type value
/devices/wb-mrm2-mini_54/controls/Serial 168173
/devices/wb-mrm2-mini_54/controls/Serial/meta {“order”:7,“readonly”:true,“title”:{“ru”:“Серийный номер”},“type”:“text”}
/devices/wb-mrm2-mini_54/controls/Serial/meta/order 7
/devices/wb-mrm2-mini_54/controls/Serial/meta/readonly 1
/devices/wb-mrm2-mini_54/controls/Serial/meta/type text
/devices/wb-mrm2-mini_54/controls/K1/on 1
/devices/wb-mrm2-mini_54/controls/K1 1
А дальше? Я вижу срабатывание входов например. Как настроено их взаимодействие с выходами?
все заработало. Я вспомнил что я раньше настраивал его на управление шторами, но потом отключил. Сейчас я снова (включил/выключил) управление шторами и заработало штатно.
Проблема не в ноде ред и не в wb-rules а в том что я включал режим штор
вот логи
/devices/wb-mrm2-mini_54/controls/Input 2 counter/meta/error (null)
/devices/wb-mrm2-mini_54/controls/K1/meta/error (null)
/devices/wb-mrm2-mini_54/controls/K2/meta/error (null)
/devices/wb-mrm2-mini_54/controls/Serial/meta/error (null)
/devices/wb-mrm2-mini_54/controls/K1/on 0
/devices/wb-mrm2-mini_54/controls/K2/on 1
/devices/wb-mrm2-mini_54/controls/K2 1
сейчас все запустил обратно (и ноду и wb rules) и все работает
