Ошибки при попытке выполнить apt update, apt upgrade
Ошибка сертификата выдает.
Err:2 Index of /debian bullseye InRelease
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
Err:3 Index of /debian bullseye-updates InRelease
Hit:1 https://deb.wirenboard.com/wb8/bullseye stable InRelease
Err:4 Index of /debian-security bullseye-security InRelease
Reading package lists… Done
3 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Игнорим протухшие сертификаты, прописывая apt-get -o “Acquire::https::Verify-Peer=false” вместо apt, и всё заработает.
Тоже не помогает, нет доступа к серверу.
apt -o ‘Acquire::https::Verify-Peer=false’ update
Hit:2 bullseye InRelease
Hit:3 bullseye-updates InRelease
Get:4 bullseye-security InRelease [27.2 kB]
Ign:1 wb8/bullseye stable InRelease
Err:5 wb8/bullseye stable Release
404 Not Found [IP: 45.89.25.184 443]
Get:6 bullseye-security/main armhf Packages [432 kB]
Get:7 bullseye-security/main arm64 Packages [437 kB]
E: The repository ‘http://deb.wirenboard.com/wb8/bullseye stable Release’ no longer has a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
apt update && apt upgrade
Ign:1 https://deb.wirenboard.com/wb7/bullseye testing InRelease
Hit:2 Index of /debian bullseye InRelease
Err:5 https://deb.wirenboard.com/wb7/bullseye testing Release
Hit:3 Index of /debian bullseye-updates InRelease
Get:4 Index of /debian-security bullseye-security InRelease [27.2 kB]
Get:6 Index of /debian-security bullseye-security/main armhf Packages [432 kB]
E: The repository ‘http://deb.wirenboard.com/wb7/bullseye testing Release’ no longer has a Release file.
Это не помогает
Уже нет. С утра еще прокатило.
Остаётся только ждать?
Сертификаты заработали теперь
Err:5 https://deb.wirenboard.com/wb8/bullseye stable Release
Проблема устранена, попробуйте обновить систему заново.
