Ошибки при попытке выполнить apt update, apt upgrade
Добрый день! При попытке обновить пакеты получил ошибку.
Welcome to Wiren Board 8.5.3 (s/n AXCFBMYW), release wb-2507 (as stable)
Linux wirenboard-AXCFBMYW 6.8.0-wb140 #1 SMP Fri Jul 18 08:08:05 UTC 2025 aarch64 GNU/Linux
System load: 1.97 1.92 2.14 Up time: 14 days 17:45
Memory usage: 16% of 1.94G Usage of /: 43% of 2.0G /mnt/data: 15% of 13G
eth0 ip: 192.168.12.37
2 package updates are available; type ‘apt update && apt upgrade’ to update them.
Last login: Sun Mar 15 00:23:05 2026 from 192.168.12.30
root@wirenboard-AXCFBMYW:~# apt update
Err:2 Index of /debian bullseye InRelease
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
Err:3 Index of /debian bullseye-updates InRelease
Err:4 Index of /debian-security bullseye-security InRelease
Hit:1 https://deb.wirenboard.com/wb8/bullseye stable InRelease
Reading package lists… Done
3 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 45.89.25.184 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Проблема устранена, попробуйте обновиться заново.
