Отказ боковых модулей WB6.8.1
Контроллер на объекте был до сегодня с хорошим аптаймом (более 60дней), произошла перезагрузка по watchdog.
Перезагрузке предшествовал дискретный сигнал от выключателя на WB-HVD16. В логах есть следующее:
27-07-2022 12:25:46.356 	caught signal 15 - exiting
27-07-2022 12:25:44.129 [wb-mqtt-db.service] 	ERROR: [driver] failed to accept new meta "order" on control "EXT5_R3A5" of device "wb-gpio": Invalid value "" of type "switch" @ wblib/control.cpp:512
27-07-2022 12:25:44.129 [wb-mqtt-db.service] 	ERROR: [driver] failed to accept new meta "order" on control "EXT6_DIR1" of device "wb-gpio": Invalid value "" of type "switch" @ wblib/control.cpp:512
27-07-2022 12:25:44.129 [wb-mqtt-db.service] 	ERROR: [driver] failed to accept new meta "order" on control "K3" of device "A16-MRWL1": Invalid value "" of type "switch" @ wblib/control.cpp:512
27-07-2022 12:25:44.129 [wb-mqtt-db.service] 	ERROR: [driver] failed to accept new meta "order" on control "data" of device "knx": Invalid value "" of type "text" @ wblib/control.cpp:512
27-07-2022 12:25:43.531 [wb-mqtt-db.service] 	ERROR: [driver] failed to accept new meta "order" on control "EXT6_ON1" of device "wb-gpio": Invalid value "" of type "switch" @ wblib/control.cpp:512
27-07-2022 12:25:43.531 [wb-mqtt-db.service] 	ERROR: [driver] failed to accept new meta "order" on control "EXT6_DIR2" of device "wb-gpio": Invalid value "" of type "switch" @ wblib/control.cpp:512
27-07-2022 12:25:42.693 [init.scope] 	watchdog.service: Failed to enqueue OnFailure= job: Resource deadlock avoided
27-07-2022 12:25:34.743 [wb-mqtt-knx] 	ERROR: [knx] Unknown telegram type:  @ /build/wb-mqtt-knx-cHPgH8/wb-mqtt-knx-1.5.0/src/knxconverter.cpp:179
26-07-2022 20:59:23.543 [rsyslog] 	Child 4096 has terminated, reaped by main-loop. [v8.24.0 try http://www.rsyslog.com/e/0 ]
25-07-2022 07:48:52.507 [rsyslog] 	Child 3540 has terminated, reaped by main-loop. [v8.24.0 try http://www.rsyslog.com/e/0 ]
24-07-2022 13:22:05.855 [rsyslog] 	Child 30140 has terminated, reaped by main-loop. [v8.24.0 try http://www.rsyslog.com/e/0 ]
23-07-2022 00:46:13.918 [rsyslog] 	Child 4918 has terminated, reaped by main-loop. [v8.24.0 try http://www.rsyslog.com/e/0 ]
21-07-2022 06:50:56.529 [rsyslog] 	Child 22214 has terminated, reaped by main-loop. [v8.24.0 try http://www.rsyslog.com/e/0 ]
что следует понаблюдать/ проверить/ поправить?
какие рекомендации дадите чтобы успокоить заказчика?
Какой релиз стоит на контроллере? Установлено ли что-то дополнительное из ПО?
wb-2204 (см скрин выше), дополнительного ПО нет
Скорректировал название темы, т.к. после перезагрузки вылезли непонятные проблемы с боковыми модулями WBIO-DO-R10A-8 и WBIO-DO-R10R-4.
В WUI модули отображаются, но если попробывать переключить кнопкой - реле не срабатывает, при этом есть модули с DI, дискретные сигналы принимает с выключателей.
Такое уже было в конце мая, все закончилось полной переустановкой релиза и восстановлением с бакапа.
Сейчас нахожусь не на объекте, какие либо эксперименты и апдейты/тестовые релизы не рассматриваю.
Поскольку это случалось повторно, то хотелось бы понять причину, в связи с чем и прошу помощи у техподдержки.
Диагностическая информация ниже по ссылке
diag_output_A76QND3Y_2022-07-30-15.52.12.zip (61.1 КБ)
ИМХО Боковые модули WBIO достаточно “глючно” себя ведут при первом подключении, и пока нормально не заработают, тормозят работу контроллера, “мешают” другим устройствам, выдают ошибку в терминал - кстати, как один из способов определения правильности работы.
Я у себя подсоединял по одному, менял их местами, каждый раз делал перезагрузку Контроллера выключателем, пока не добился стабильной работы.
Лучше всего подключать сначала один тип, потом другой по очереди, наблюдая за работой контроллера.
Контроллер работает более года с модулями. Такое повторяется второй раз с мая 2021. Объект сдан, люди живут, эксперименты со снятием модулей не рассматриваю.
Я бы не сказал что боковые модули какие то глючные, есть баг и его нужно изловить.
Всё ещё надеюсь на проявленный интерес со стороны WB
У вас есть доступ к контроллеру? Просто я не очень понимаю, как мы можем помочь, если ставить, и обновлять софт вы не можете, что-то физически делать с контроллером не можете, доступа нет и т.д.
Пожалуйста попробуйте воспроизвести это ещё раз, параллельно запустив в консоли mosquitto_sub -v -t /# и пришлите сюда вывод.
Ещё покажите вывод cat /sys/kernel/debug/gpio до попытки переключения одного реле и после. И вывод dmesg сразу после.
Доступ есть.
Ввел ваши команды, судя по выводу значение меняется. В ближайшие дни буду на объекте, буду разбираться на месте.
Менял EXT4-R3A7
root@wirenboard-A76QND3Y:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-31, parent: platform/209c000.gpio, 209c000.gpio:
 gpio-10  (                    |mod2_sda_pullup     ) in  lo ACTIVE LOW
 gpio-11  (                    |onewire_w2          ) out hi
 gpio-13  (                    |pu                  ) out lo
 gpio-22  (                    |rts                 ) out lo
 gpio-23  (                    |sysfs               ) out lo
 gpio-26  (                    |rts                 ) out lo
 gpio-27  (                    |wb-mqtt-gpio        ) out hi
 gpio-30  (                    |scl                 ) out hi
 gpio-31  (                    |sda                 ) in  hi
gpiochip1: GPIOs 32-63, parent: platform/20a0000.gpio, 20a0000.gpio:
 gpio-48  (                    |i2c_rtc             ) out hi
 gpio-49  (                    |i2c_rtc             ) out hi
 gpio-51  (                    |watchdog            ) out lo
gpiochip2: GPIOs 64-95, parent: platform/20a4000.gpio, 20a4000.gpio:
 gpio-66  (                    |rts                 ) out lo
 gpio-67  (                    |i2c_eeprom1         ) out hi
 gpio-68  (                    |wb-mqtt-gpio        ) in  hi ACTIVE LOW
 gpio-70  (                    |i2c_eeprom2         ) out hi
 gpio-71  (                    |i2c_eeprom2         ) out hi
 gpio-72  (                    |wb-mqtt-gpio        ) in  hi
 gpio-73  (                    |wb-mqtt-gpio        ) out hi
 gpio-74  (                    |regulators:regulator) out hi
 gpio-76  (                    |i2c_eeprom1         ) out hi
 gpio-77  (                    |wb-mqtt-gpio        ) in  hi ACTIVE LOW
 gpio-78  (                    |wb-mqtt-gpio        ) in  hi ACTIVE LOW
 gpio-79  (                    |wb-mqtt-gpio        ) out hi
 gpio-80  (                    |wb-mqtt-gpio        ) out hi
 gpio-81  (                    |wb-mqtt-gpio        ) out hi
 gpio-82  (                    |wb-mqtt-gpio        ) out hi
 gpio-91  (                    |wb-mqtt-gpio        ) in  hi ACTIVE LOW
 gpio-92  (                    |wb-mqtt-gpio        ) in  hi ACTIVE LOW
gpiochip3: GPIOs 96-127, parent: platform/20a8000.gpio, 20a8000.gpio:
 gpio-107 (                    |regulators:regulator) out hi
 gpio-108 (                    |spi2 CS0            ) out hi ACTIVE LOW
 gpio-112 (                    |w1_reg_pu_dummy     ) out lo
 gpio-116 (                    |sysfs               ) out hi
 gpio-119 (                    |sysfs               ) out hi
gpiochip4: GPIOs 128-159, parent: platform/20ac000.gpio, 20ac000.gpio:
 gpio-128 (                    |sysfs               ) out hi
 gpio-129 (                    |phy-reset           ) out hi
 gpio-130 (                    |sysfs               ) out hi
gpiochip8: GPIOs 184-191, parent: i2c/1-0024, mcp23008, can sleep:
 gpio-184 (EXT4_R3A1           |wb-mqtt-gpio        ) out lo
 gpio-185 (EXT4_R3A2           |wb-mqtt-gpio        ) out lo
 gpio-186 (EXT4_R3A3           |wb-mqtt-gpio        ) out lo
 gpio-187 (EXT4_R3A4           |wb-mqtt-gpio        ) out lo
 gpio-188 (EXT4_R3A5           |wb-mqtt-gpio        ) out lo
 gpio-189 (EXT4_R3A6           |wb-mqtt-gpio        ) out lo
 gpio-190 (EXT4_R3A7           |wb-mqtt-gpio        ) out lo
 gpio-191 (EXT4_R3A8           |wb-mqtt-gpio        ) out hi
gpiochip9: GPIOs 192-199, parent: i2c/1-0020, mcp23008, can sleep:
 gpio-192 (EXT5_R3A1           |wb-mqtt-gpio        ) out hi
 gpio-193 (EXT5_R3A2           |wb-mqtt-gpio        ) out hi
 gpio-194 (EXT5_R3A3           |wb-mqtt-gpio        ) out hi
 gpio-195 (EXT5_R3A4           |wb-mqtt-gpio        ) out lo
 gpio-196 (EXT5_R3A5           |wb-mqtt-gpio        ) out lo
 gpio-197 (EXT5_R3A6           |wb-mqtt-gpio        ) out lo
 gpio-198 (EXT5_R3A7           |wb-mqtt-gpio        ) out lo
 gpio-199 (EXT5_R3A8           |wb-mqtt-gpio        ) out hi
gpiochip10: GPIOs 200-207, parent: i2c/1-0021, mcp23008, can sleep:
 gpio-200 (EXT6_DIR1           |wb-mqtt-gpio        ) out hi
 gpio-201 (EXT6_ON1            |wb-mqtt-gpio        ) out lo
 gpio-202 (EXT6_DIR2           |wb-mqtt-gpio        ) out hi
 gpio-203 (EXT6_ON2            |wb-mqtt-gpio        ) out lo
 gpio-204 (EXT6_DIR3           |wb-mqtt-gpio        ) out lo
 gpio-205 (EXT6_ON3            |wb-mqtt-gpio        ) out lo
 gpio-206 (EXT6_DIR4           |wb-mqtt-gpio        ) out lo
 gpio-207 (EXT6_ON4            |wb-mqtt-gpio        ) out lo
gpiochip5: GPIOs 256-271, parent: i2c/1-0027, mcp23017, can sleep:
 gpio-256 (EXT1_DR1            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-257 (EXT1_DR2            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-258 (EXT1_DR3            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-259 (EXT1_DR4            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-260 (EXT1_DR5            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-261 (EXT1_DR6            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-262 (EXT1_DR7            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-263 (EXT1_DR8            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-264 (EXT1_DR9            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-265 (EXT1_DR10           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-266 (EXT1_DR11           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-267 (EXT1_DR12           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-268 (EXT1_DR13           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-269 (EXT1_DR14           |wb-mqtt-gpio        ) in  lo IRQ
gpiochip6: GPIOs 296-311, parent: i2c/1-0026, mcp23017, can sleep:
 gpio-296 (EXT2_DR1            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-297 (EXT2_DR2            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-298 (EXT2_DR3            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-299 (EXT2_DR4            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-300 (EXT2_DR5            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-301 (EXT2_DR6            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-302 (EXT2_DR7            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-303 (EXT2_DR8            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-304 (EXT2_DR9            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-305 (EXT2_DR10           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-306 (EXT2_DR11           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-307 (EXT2_DR12           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-308 (EXT2_DR13           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-309 (EXT2_DR14           |wb-mqtt-gpio        ) in  lo IRQ
gpiochip7: GPIOs 336-351, parent: i2c/1-0025, mcp23017, can sleep:
 gpio-336 (EXT3_IN1            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-337 (EXT3_IN2            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-338 (EXT3_IN3            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-339 (EXT3_IN4            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-340 (EXT3_IN5            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-341 (EXT3_IN6            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-342 (EXT3_IN7            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-343 (EXT3_IN8            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-344 (EXT3_IN9            |wb-mqtt-gpio        ) in  lo IRQ
 gpio-345 (EXT3_IN10           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-346 (EXT3_IN11           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-347 (EXT3_IN12           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-348 (EXT3_IN13           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-349 (EXT3_IN14           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-350 (EXT3_IN15           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-351 (EXT3_IN16           |wb-mqtt-gpio        ) in  lo IRQ
 gpio-26  (                    |rts                 ) out hi
 gpio-190 (EXT4_R3A7           |wb-mqtt-gpio        ) out hi
вот лучше бы вывод показать.
В выводе /sys/kernel/debug/gpio тоже значение поменялось. А вы уверены, что реле не щёлкает? как вы это проверяете?
и вывод dmesg ещё всё-таки покажите.
В очередной раз на данном объекте. Заметил странную особенность:
  1. при перезагрузке контроллера контролы боковых модулей (входные и выходные сигналы), а именно у меня WD14 + WD14 + HVD16 + R10A8 + R10A8 + R10A4 часть не появляется в WUI. См. например EXT6 ON1 + DIR1 и ON2 +DIR2 отсутствуют
  2. Контроллер запустился, уже идет опрос шины и спустя примерно 2-3 минуты они появляются. И ладно бы появилилсь, но они принимают значение вкл, что для меня означает перекрыть воду.
в настройках начальное состояние - выкл, в скриптах нет правил по запуску при старте.
на данный момент на объекте, могу дать доступ.
Появляются сместе с запуском работающего с ними сервиса, естественно.
Принимают состояние в котором были на момент завершения работы сервиса.
Да контролы появляются в какой-то момент при запуске контроллера, но не в полном объеме. Видимо до момента старта сервиса, поскольку те которые отображаются (до момента старта сервиса) не меняют состояние если попробовать в ручную сменить его (реле также не переключается физически).
Нет! Если применительно к EXT6_DIR3, EXT6_DIR4 - однозначно были в состояние false, до перезагрузки. После того как стартует сервис - см. скриншот они становятся true.
В конфиге не выставлено стартовое значение, почему меняются значения при старте? В скриптах команд на смену значения при старте нет.
Изложу еще раз проблему.
вводные: Wiren Board 6.8.1 (s/n A76QND3Y), release wb-2207 (as stable)
далее тезисами:
  1. сегодня в очередной раз началась чертовщина с утра пораньше у заказчика - включался свет/ менялся режим я дома/меня нет дома, краны закрылись и т.д. Логи (ведутся в иридиуме, а также в WB) показали что аномалия началась в 21-09-2022 09:42:39.535
1-09-2022 09:42:41.469 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR1     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.457 [wb-rules] 	ERROR: control wb-gpio/EXT5_R3A4 SetValue() error: This control is not writable
21-09-2022 09:42:41.446 [wb-rules] 	INFO: [rule info] impuls_switch.js : switchRelay wb-gpio/EXT5_R3A4
21-09-2022 09:42:41.441 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN4     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.432 [wb-rules] 	ERROR: failed to SetValue for unexisting control A71-MDM3/Channel: 50
21-09-2022 09:42:41.410 [wb-rules] 	ERROR: control A71-MDM3/K3 SetValue() error: This control is not writable
21-09-2022 09:42:41.408 [wb-rules] 	ERROR: control A71-MDM3/K1 SetValue() error: This control is not writable
21-09-2022 09:42:41.386 [wb-rules] 	INFO: [rule info] impuls_switch.js : S4_longPress
21-09-2022 09:42:41.376 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR10     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.373 [wb-rules] 	INFO: [rule info] impuls_switch.js : S22_longPress
21-09-2022 09:42:41.364 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN6     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.345 [wb-rules] 	ERROR: control A71-MDM3/K3 SetValue() error: This control is not writable
21-09-2022 09:42:41.321 [wb-rules] 	ERROR: control A71-MDM3/K2 SetValue() error: This control is not writable
21-09-2022 09:42:41.306 [wb-rules] 	INFO: [rule info] impuls_switch.js : S8_longPress
21-09-2022 09:42:41.294 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN5     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.276 [wb-rules] 	ERROR: control A21-MR6C3/K2 SetValue() error: This control is not writable
21-09-2022 09:42:41.270 [wb-rules] 	ERROR: control wb-gpio/EXT5_R3A4 SetValue() error: This control is not writable
21-09-2022 09:42:41.253 [wb-rules] 	ERROR: control A21-MR6C3/K1 SetValue() error: This control is not writable
21-09-2022 09:42:41.242 [wb-rules] 	INFO: [rule info] impuls_switch.js : S5_longPress
21-09-2022 09:42:41.215 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN3     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.209 [wb-rules] 	ERROR: control A71-MDM3/K3 SetValue() error: This control is not writable
21-09-2022 09:42:41.202 [wb-rules] 	ERROR: control A71-MDM3/K2 SetValue() error: This control is not writable
21-09-2022 09:42:41.193 [wb-rules] 	INFO: [rule info] impuls_switch.js : S3_longPress
21-09-2022 09:42:41.170 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN1     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.141 [wb-rules] 	ERROR: trying to stop unknown timer: 250
21-09-2022 09:42:41.133 [wb-rules] 	INFO: [rule info] impuls_switch.js : S1_longPress
21-09-2022 09:42:41.114 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR13     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:41.078 [wb-rules] 	ERROR: control A71-MDM3/K2 SetValue() error: This control is not writable
21-09-2022 09:42:41.056 [wb-rules] 	ERROR: control A71-MDM3/K3 SetValue() error: This control is not writable
21-09-2022 09:42:41.046 [wb-rules] 	INFO: [rule info] impuls_switch.js : S7_1_longPress
21-09-2022 09:42:41.037 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR12     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:40.993 [wb-rules] 	INFO: [rule info] impuls_switch.js : S22_longPress
21-09-2022 09:42:40.984 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR11     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:40.934 [wb-rules] 	INFO: [rule info] impuls_switch.js : S22_longPress
21-09-2022 09:42:40.839 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5116 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:40.810 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5100 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:40.737 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR6     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:40.730 [wb-rules] 	ERROR: control wb-gpio/EXT5_R3A5 SetValue() error: This control is not writable
21-09-2022 09:42:40.724 [wb-rules] 	ERROR: control A21-MR6C3/K5 SetValue() error: This control is not writable
21-09-2022 09:42:40.717 [wb-rules] 	ERROR: control A21-MR6C3/K4 SetValue() error: This control is not writable
21-09-2022 09:42:40.711 [wb-rules] 	ERROR: control A21-MR6C3/K3 SetValue() error: This control is not writable
21-09-2022 09:42:40.690 [wb-rules] 	INFO: [rule info] impuls_switch.js : S17_longPress
21-09-2022 09:42:40.683 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR4     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:40.566 [wb-rules] 	INFO: [rule info] impuls_switch.js : loop
21-09-2022 09:42:40.550 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR2     >>>>>> long press - press (1) <<<<<<
21-09-2022 09:42:40.544 [wb-rules] 	INFO: [rule info] impuls_switch.js : loop
21-09-2022 09:42:40.302 [wb-rules] 	ERROR: trying to stop unknown timer: 310
21-09-2022 09:42:40.254 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN13   newValue = true
21-09-2022 09:42:40.238 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN12   newValue = true
21-09-2022 09:42:40.217 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN11   newValue = true
21-09-2022 09:42:40.203 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN10   newValue = true
21-09-2022 09:42:40.192 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5116 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:40.187 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN9   newValue = true
21-09-2022 09:42:40.174 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN8   newValue = true
21-09-2022 09:42:40.164 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5100 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:40.157 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN7   newValue = true
21-09-2022 09:42:40.149 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN2   newValue = true
21-09-2022 09:42:40.140 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR9   newValue = true
21-09-2022 09:42:40.127 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR8   newValue = true
21-09-2022 09:42:40.117 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR7   newValue = true
21-09-2022 09:42:40.107 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR5   newValue = true
21-09-2022 09:42:40.094 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR3   newValue = true
21-09-2022 09:42:40.083 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR1   newValue = true
21-09-2022 09:42:40.078 [wb-rules] 	ERROR: control wb-gpio/EXT6_ON4 SetValue() error: This control is not writable
21-09-2022 09:42:40.072 [wb-rules] 	ERROR: control wb-gpio/EXT6_ON2 SetValue() error: This control is not writable
21-09-2022 09:42:40.066 [wb-rules] 	ERROR: control wb-gpio/EXT6_ON1 SetValue() error: This control is not writable
21-09-2022 09:42:40.054 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN4   newValue = true
21-09-2022 09:42:40.046 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR10   newValue = true
21-09-2022 09:42:40.032 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN6   newValue = true
21-09-2022 09:42:40.021 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN5   newValue = true
21-09-2022 09:42:39.991 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN3   newValue = true
21-09-2022 09:42:39.986 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT3_IN1   newValue = true
21-09-2022 09:42:39.943 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR13   newValue = true
21-09-2022 09:42:39.932 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR12   newValue = true
21-09-2022 09:42:39.925 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR11   newValue = true
21-09-2022 09:42:39.571 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR6   newValue = true
21-09-2022 09:42:39.555 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR4   newValue = true
21-09-2022 09:42:39.535 [wb-rules] 	INFO: [rule info] impuls_switch.js:  on_button_press_wb-gpio_EXT1_DR2   newValue = true
21-09-2022 09:42:39.522 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5116 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:39.497 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5100 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:38.977 [zigbee2mqtt] 	e[32mZigbee2MQTT:info e[39m 2022-09-21 04:42:38: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":55,"energy":15.64,"linkquality":57,"power":795.5,"state":"ON"}'
21-09-2022 09:42:38.866 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5116 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:38.840 [wb-mqtt-serial] 	WARNING: [modbus] failed to read 16 coil(s) @ 5100 of device modbus:25: Serial protocol error: server device is busy
21-09-2022 09:42:38.268 [zigbee2mqtt] 	e[32mZigbee2MQTT:info e[39m 2022-09-21 04:42:38: MQTT publish: topic 'zigbee2mqtt/0x04cf8cdf3c8b5021', payload '{"device_temperature":55,"energy":15.64,"linkquality":57,"power":795.5,"state":"ON"}'
структура системы такая что DI от выключателей заведены на WD14 и HWD16, соответственно если возникает какая-то проблема с боковыми модулями/контроллером поведение системы становится непредсказуемым.
Из лога видно что в 21-09-2022 09:42:39.535 одномоментно все входные DI модулелй WD14 и HVD16 выставились в true (сужу по сообщениям из скрипта который следит за коротким, двойным, долгим нажатием).
  1. После посмотрел состояние входов:
 gpio-51  (                    |watchdog            ) out hi
 gpio-191 (EXT4_R3A8           |wb-mqtt-gpio        ) out lo
 gpio-192 (EXT5_R3A1           |wb-mqtt-gpio        ) out lo
 gpio-200 (EXT6_DIR1           |wb-mqtt-gpio        ) out lo
 gpio-202 (EXT6_DIR2           |wb-mqtt-gpio        ) out lo
 gpio-206 (EXT6_DIR4           |wb-mqtt-gpio        ) out hi
меня интересовал gpio-351 (EXT3_IN16 |wb-mqtt-gpio ) in lo IRQ, на него заведен сигнал с переключателя ручной/автомат управления кранами (к сожалению не через MWAC, а через R10A4 управляю). Как видим состояние дискрета в false, для меня означает что состояние “авто”, блокировка ручная снята и я могу через автоматику подать питание на краны через скрипты.
В веб интерфейсе также EXT3_IN16 = false
  1. пробую переключить, для этого есть скрипт
var timerPowerValve = null;
defineRule("powervalve", {
  whenChanged: "Virtual/PowerValve",
    log.info("powervalve.js / powervalve = " + newValue + "     wb-gpio/EXT3_IN16 = " + dev["wb-gpio/EXT3_IN16"] );
    if (dev["wb-gpio/EXT3_IN16"] != true) {
    	log.info("powervalve.js / powervalve = " + newValue);
        dev["wb-gpio"]["EXT6_ON1"] = newValue;
    	dev["wb-gpio"]["EXT6_ON2"] = newValue;
    	//dev["wb-gpio"]["EXT6_ON3"] = newValue;
    	dev["wb-gpio"]["EXT6_ON4"] = newValue;
    	if (timerPowerValve){
        	clearTimeout(timerPowerValve);
   	timerPowerValve = setTimeout(function () {
		    dev["Virtual"]["PowerValve"] = false;
		}, 120000)
те виртуальный переключатель если переключить и снята блокировка, то подается/сниматеся питание. Когда ввел вывод состояния в лог очень удивился:
2022-09-21 12:29:55powervalve.js / powervalve = true wb-gpio/EXT3_IN16 = true
  1. если посмотреть историю то значения также застыли в true
  2. Перезагружаюсь. См. после перезагрузки состояние
 gpio-204 (EXT6_DIR3           |wb-mqtt-gpio        ) out hi
gpio-205 (EXT6_ON3            |wb-mqtt-gpio        ) out hi
обращаю внимание на EXT6 - посмотрите до (false) и после (true), также сообщаю что до перезагрузки в WUI данные контролы были false.
Так откуда берутся значения после старта?
Что приводит к одномоментной установыки hi на дискретах?
Жду рекомендаций
Итак, если я верно понимаю:
сервис вернул сообщение на установку значения?
После этого еще несколько топиков:
Что в указанное время в логе брокера?
Ведь:
Текущее предположение: брокер перезапустился, кто-то удалил (изменил) часть топиков.
