Стала пропадать периодически связь с устройством по ModbusTCP/IP, что совпадает с появлением в журнале странных предупреждений (Serial protocol error: serial write failed: Broken pipe (32)), что они означают? Просто к WB7 (
wb-2310) подключено одно устройство по ModbusTCP/IP и опрашиваются (тип регистра input) всего 10 регистров у него, на запись ничего нету.
|25-11-2024 01:12:43.433 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1023 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:12:43.431 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1022 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:12:43.428 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1021 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:12:43.426 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1020 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:12:43.424 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1030 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:12:43.420 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1029 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:12:43.420 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1028 of device modbus-tcp:1: Serial protocol error: serial write failed: Connection reset by peer (104)|
|25-11-2024 01:12:43.416 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1027 of device modbus-tcp:1: Serial protocol error: request timed out|
|25-11-2024 01:12:42.561 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1026 of device modbus-tcp:1: Serial protocol error: request timed out|
|25-11-2024 01:12:19.514 [wb-mqtt-opcua]|INFO: [OPCUA] channel: Connection 8 | SecureChannel 16 | SecureChannel renewed with a revised lifetime of 600.00s|
|25-11-2024 01:06:47.572 [wb-mqtt-serial]|INFO: [serial device] device modbus-tcp:1 is connected|
|25-11-2024 01:06:47.540 [wb-mqtt-serial]|WARNING: <192.168.0.100:502>: closed due to repetitive errors|
|25-11-2024 01:06:42.539 [wb-mqtt-serial]|INFO: [serial device] device modbus-tcp:1 is disconnected|
|25-11-2024 01:06:42.539 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1029 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1028 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1027 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1026 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1025 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1024 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1023 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1022 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1021 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1020 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.636 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1030 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1029 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1028 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1027 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1026 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1025 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1024 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1023 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1022 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1021 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
|25-11-2024 01:06:41.629 [wb-mqtt-serial]|WARNING: [modbus] failed to read 1 input(s) @ 1020 of device modbus-tcp:1: Serial protocol error: serial write failed: Broken pipe (32)|
