Алиса после обновления testing
WB 8.5.1 wb-2606 testing
После сегодняшнего обновления apt update && apt upgrade не может установить связь с Алисой
18-06-2026 17:35:14.648 [wb-mqtt-alice-client] INFO: Waiting 60 seconds before reconnection attempt #33...
18-06-2026 17:35:14.646 [wb-mqtt-alice-client] WARNING: Connection attempt #32 failed
18-06-2026 17:35:14.646 [wb-mqtt-alice-client] WARNING: Socket.IO Connection Failed: 'Connection error'
18-06-2026 17:35:14.631 [wb-mqtt-alice-client] ERROR: Message from server: 'Connection error'
18-06-2026 17:35:14.631 [wb-mqtt-alice-client] ERROR: Yandex Alice integration connection refused by server
18-06-2026 17:35:14.631 [wb-mqtt-alice-client] ERROR: Manager: Socket.IO connect_error - 'Connection error'
18-06-2026 17:35:14.290 [wb-mqtt-alice-client] INFO: Connecting Socket.IO client to 'http://localhost:8042'...
18-06-2026 17:35:14.288 [wb-mqtt-alice-client] INFO: Connection attempt #32...
18-06-2026 17:34:14.276 [wb-mqtt-alice-client] INFO: Waiting 60 seconds before reconnection attempt #32...
18-06-2026 17:34:14.276 [wb-mqtt-alice-client] WARNING: Connection attempt #31 failed
18-06-2026 17:34:14.275 [wb-mqtt-alice-client] WARNING: Socket.IO Connection Failed: 'Connection error'
18-06-2026 17:34:14.263 [wb-mqtt-alice-client] ERROR: Message from server: 'Connection error'
18-06-2026 17:34:14.263 [wb-mqtt-alice-client] ERROR: Yandex Alice integration connection refused by server
18-06-2026 17:34:14.263 [wb-mqtt-alice-client] ERROR: Manager: Socket.IO connect_error - 'Connection error'
18-06-2026 17:34:13.879 [wb-mqtt-alice-client] INFO: Connecting Socket.IO client to 'http://localhost:8042'...
18-06-2026 17:34:13.878 [wb-mqtt-alice-client] INFO: Connection attempt #31...
(2,7 МБ)
​Мы проверили у себя - проблема действительно воспроизводится.
Причина в том, что Let’s Encrypt недавно изменил структуру цепочки сертификатов. Из-за этого при проверке возникает несоответствие ожидаемой длине, и соединение сбрасывается с ошибкой.
​Мы уже взяли в работу, готовим официальный фикс и постараемся выпустить обновление для всех пользователей как можно скорее.
Видимо у меня после обновления проблема 502 Bad gateway у клиента Алисы с этим же связана? Бился весь вечер, так и не смог реанимировать подключение. Stable релиз.
Это те же симптомы проблемы. Работаем над фиксом )
После обновления всё вернулось на круги своя, спасибо!
