Up/down ethernet интерфейс wb 8.5
наблюдаю в логах вот такую картину:
[Mon Mar 9 22:22:33 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Mon Mar 9 22:22:35 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Mon Mar 9 22:35:00 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Mon Mar 9 22:35:03 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Mon Mar 9 22:49:32 2026] RTW: recv eapol packet - WPA Group Key 1/2
[Mon Mar 9 22:49:32 2026] RTW: set group key camid:2, addr:64:d1:54:70:21:01, kid:1, type:AES
[Mon Mar 9 22:49:32 2026] RTW: send eapol packet - WPA Group Key 2/2
[Mon Mar 9 22:50:12 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Mon Mar 9 22:50:14 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Mon Mar 9 23:49:32 2026] RTW: recv eapol packet - WPA Group Key 1/2
[Mon Mar 9 23:49:32 2026] RTW: send eapol packet - WPA Group Key 2/2
[Mon Mar 9 23:49:32 2026] RTW: set group key camid:1, addr:64:d1:54:70:21:01, kid:2, type:AES
[Mon Mar 9 23:50:41 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Mon Mar 9 23:50:43 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 00:49:32 2026] RTW: recv eapol packet - WPA Group Key 1/2
[Tue Mar 10 00:49:32 2026] RTW: set group key camid:2, addr:64:d1:54:70:21:01, kid:1, type:AES
[Tue Mar 10 00:49:32 2026] RTW: send eapol packet - WPA Group Key 2/2
[Tue Mar 10 00:50:07 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 00:50:11 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 01:10:06 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 01:10:08 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 01:37:43 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 01:37:45 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 01:49:32 2026] RTW: recv eapol packet - WPA Group Key 1/2
[Tue Mar 10 01:49:32 2026] RTW: set group key camid:1, addr:64:d1:54:70:21:01, kid:2, type:AES
[Tue Mar 10 01:49:32 2026] RTW: send eapol packet - WPA Group Key 2/2
[Tue Mar 10 02:11:15 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 02:11:19 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 02:21:22 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 02:21:24 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 02:35:48 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 02:35:51 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 02:49:32 2026] RTW: recv eapol packet - WPA Group Key 1/2
[Tue Mar 10 02:49:32 2026] RTW: set group key camid:2, addr:64:d1:54:70:21:01, kid:1, type:AES
[Tue Mar 10 02:49:32 2026] RTW: send eapol packet - WPA Group Key 2/2
[Tue Mar 10 03:37:38 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 03:37:42 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 03:46:09 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 03:46:11 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 03:49:32 2026] RTW: recv eapol packet - WPA Group Key 1/2
[Tue Mar 10 03:49:32 2026] RTW: set group key camid:1, addr:64:d1:54:70:21:01, kid:2, type:AES
[Tue Mar 10 03:49:32 2026] RTW: send eapol packet - WPA Group Key 2/2
[Tue Mar 10 03:52:25 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 03:52:27 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 04:00:29 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 04:00:32 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 04:03:48 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 04:03:51 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[Tue Mar 10 04:39:27 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Down
[Tue Mar 10 04:39:29 2026] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Судя по описанию, причина может быть связана с физическим подключением или сетевой инфраструктурой. Чаще всего подобные ситуации возникают из-за патч-корда, некачественного обжима или контакта в разъёме RJ-45. Также стоит учитывать возможные проблемы со стороны коммутатора или роутера, а в редких случаях — особенности работы самого Ethernet-порта.
Рекомендую по возможности проверить кабель (попробовать заведомо исправный), подключить контроллер в другой порт коммутатора и посмотреть, не совпадает ли момент обрыва связи с перезагрузкой сетевого оборудования или просадкой питания. Если используется PoE или промежуточные переходники, можно временно исключить их из схемы для проверки.
Поменял патчкорд, переткнул в другую активку, подожду сутки и отпишусь по результатам.
Хорошо, буду ждать обратной связи.
Пропали падения на eth0.
Но я пошёл дальше - подключил eth1 wb в тот-же порт в который раньше был подключен eth0 и теперь eth1 точно так-же дёргается.
Попробую полностью исключить физику и порт на активке, просто остаётся подозрение на какую-то несовместимость.
Если используется управляемый коммутатор, рекомендую проверить, нет ли переключений между full duplex и half duplex. При возможности лучше зафиксировать режим работы порта вручную.
Также прошу обратить внимание на следующую еррату, не используется ли подобное оборудлование и не совпадают ли ревизии?
И, пожалуйста, пришлите диагностический архив контроллера для анализа.
Не совсем, но тоже MikroTik RB760iGS r2.
Режим фиксировал не помогло.
cat /sys/devices/platform/external-ethernet-phys/external-ethernet-phys:soft-mdio0/mdio_bus/gpio-0/gpio-0:00/phy_id
0x001cc816
Архив позже сформирую и закину.
Хорошо, ожидаю обратной связи. Если есть возможность, попробуйте подключить контроллер через другое оборудование — например, любой неуправляемый коммутатор. Такой тест будет полезен, так как влияние физического уровня пока полностью не исключено.
Добрый день, удалось ли решить ворос?
пока ещё нет, завтра планирую провести все эксперименты для исключения влияния физики и подготовлю архив диагностический.
Окончательно всё протестировал, исключил всю физику - переключил на заведомо исправный патчкорд, переключил в заведомо исправный порт, проблема так и осталась.
(552,5 КБ)
Давайте мы бесплатно поменяем вам оборудование. Курьер привезёт новое оборудование и заберёт старое.
WB-8 - 1 шт.
  • ссылку на эту тему, Up/down ethernet интерфейс wb 8.5 - #13
Получил и установил новый контроллер, пол суток прошли интерфейс не скачет. Свой контроллер сегодня отправил, оставил всю конфигурацию, только поменял пароль root на дефолтный и переключил на dhcp интерфейсы.
Рад, что все работает!
Доброго дня (инженер по ремонту). Скажите пожалуйста, с выданным на замену оборудованием есть, ли проблемы? Изучал ваш возвратный, по тестам проблемы Up/Down не выявлено.
Добрый день, с новым оборудованием такой проблемы ни разу не возникло с момента установки, подключил тем-же патчкордом в тот-же порт маршрутизатора.
