Wb_mqtt_homeui
Добрый день, со вчерашнего дня в логи сыпятся следующие сообщения:
26-03-2025 12:58:32.818 [mosquitto]	1742983112: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:32.103 [mosquitto]	1742983112: New client connected from ::ffff:127.0.0.1:43056 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:28.694 [mosquitto]	1742983108: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:27.167 [mosquitto]	1742983107: New client connected from ::ffff:127.0.0.1:43052 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:23.720 [mosquitto]	1742983103: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:23.095 [mosquitto]	1742983103: New client connected from ::ffff:127.0.0.1:43046 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:20.278 [mosquitto]	1742983100: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:19.622 [mosquitto]	1742983099: New client connected from ::ffff:127.0.0.1:43042 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:17.347 [mosquitto]	1742983097: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:15.746 [mosquitto]	1742983095: New client connected from ::ffff:127.0.0.1:43040 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:12.643 [mosquitto]	1742983092: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:12.065 [mosquitto]	1742983092: New client connected from ::ffff:127.0.0.1:43036 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:09.615 [mosquitto]	1742983089: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
26-03-2025 12:58:08.764 [mosquitto]	1742983088: New client connected from ::ffff:127.0.0.1:43032 as wb-mqtt-homeui-VS49IM5KKE (p2, c1, k60).
26-03-2025 12:58:06.266 [mosquitto]	1742983086: Client wb-mqtt-homeui-VS49IM5KKE closed its connection.
С какой проблемой могут быть связаны эти сообщения?
Случайно обнаружили причину возникновения проблемы: на удаленном компьютере был открыт вэб-интерфейс, и в один момент, не понятно по какой причине, индикатор справа в верхнем углу подключено/отключено начал переключаться туда-обратно, тем самым контроллер считывал эти входы/выходы и документировал все в лог; после перезагрузки вэб-страницы все работает в штатном режиме.
Перед нами встала задача, возобновление сеансов в вэб-интерфейсе(перезагрузка страницы) всех подключенных пользователей, или хотя бы пользователей:
  1. Пользователь
  2. Оператор
  3. Администратор
, во избежание таких ситуаций и забивания лога, но не через F5 или image.
Такое или что-то похожее возможно реализовать?
Рад, что удалось найти причину.
Функционал ролей
— Пользователь
— Оператор
— Администратор
находится в разработке. Однако, к сожалению, примерные сроки релиза пока не озвучиваются — разработчики ещё не дали точную информацию.
Остались ли еще вопросы?
А принудительно обновлять соединение всех открытых вэб’ов реализуемо?
Добавил в Книгу пожеланий и предложений.
Может быть через терминал есть способы, которые вы бы порекомендовали?
На данный момент такой возможности, к сожалению, нет.
