Подскажите, пожалуйста, насколько критичны следующие ошибки и как их устранить?
May 14 08:05:10 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/buzzer.js is NOT under source root /etc/wb-rules
May 14 08:05:11 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/hwmon.js is NOT under source root /etc/wb-rules
May 14 08:05:11 wirenboard-AARIERSM daemon.info wb-rules[29744]: ERROR: command ‘/bin/sh -c echo 0 > /sys/class/pwm/pwmchip0/pwm2/enable’ failed with exit status 2
May 14 08:05:12 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/network.js is NOT under source root /etc/wb-rules
May 14 08:05:12 wirenboard-AARIERSM daemon.info wb-rules[29744]: ERROR: command ‘/bin/sh -c echo 0 > /sys/class/pwm/pwmchip0/export’ failed with exit status 1
May 14 08:05:13 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/power_status.js is NOT under source root /etc/wb-rules
May 14 08:05:14 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/system.js is NOT under source root /etc/wb-rules
May 14 08:05:15 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/wb-mqtt-dac.js is NOT under source root /etc/wb-rules
May 14 08:05:17 wirenboard-AARIERSM daemon.info wb-rules[29744]: INFO: /usr/share/wb-rules-system/rules/wbmz-battery.js is NOT under source root /etc/wb-rules
[upd]
May 14 08:56:10 wirenboard-AARIERSM user.notice wb-mqtt-db[549]: 2021-05-14 08:56:10.007 NOTICE: Bulk processing took 74ms
May 14 08:56:20 wirenboard-AARIERSM auth.info sshd[1556]: rexec line 18: Deprecated option KeyRegenerationInterval
May 14 08:56:20 wirenboard-AARIERSM auth.info sshd[1556]: rexec line 19: Deprecated option ServerKeyBits
May 14 08:56:20 wirenboard-AARIERSM auth.info sshd[1556]: rexec line 30: Deprecated option RSAAuthentication
May 14 08:56:20 wirenboard-AARIERSM auth.info sshd[1556]: rexec line 37: Deprecated option RhostsRSAAuthentication
May 14 08:56:25 wirenboard-AARIERSM auth.info sshd[1556]: reprocess config line 30: Deprecated option RSAAuthentication
May 14 08:56:25 wirenboard-AARIERSM auth.info sshd[1556]: reprocess config line 37: Deprecated option RhostsRSAAuthentication
[upd2]
так же наблюдаю достаточно часто:
May 14 08:08:10 wirenboard-AARIERSM daemon.info wb-rules[29744]: ERROR: failed to SetValue for unexisting control
May 14 08:15:02 wirenboard-AARIERSM user.notice wb-daemon-watchdogs: wb-rules check failed, reload wb-rules
[upd3]
May 15 13:25:21 wirenboard-AARIERSM auth.info sshd[31187]: rexec line 18: Deprecated option KeyRegenerationInterval
May 15 13:25:21 wirenboard-AARIERSM auth.info sshd[31187]: rexec line 19: Deprecated option ServerKeyBits
May 15 13:25:21 wirenboard-AARIERSM auth.info sshd[31187]: rexec line 30: Deprecated option RSAAuthentication
May 15 13:25:21 wirenboard-AARIERSM auth.info sshd[31187]: rexec line 37: Deprecated option RhostsRSAAuthentication
May 15 13:25:25 wirenboard-AARIERSM auth.info sshd[31187]: reprocess config line 30: Deprecated option RSAAuthentication
May 15 13:25:25 wirenboard-AARIERSM auth.info sshd[31187]: reprocess config line 37: Deprecated option RhostsRSAAuthentication
[upd4]
May 15 13:29:02 wirenboard-AARIERSM authpriv.info CRON[31498]: pam_unix(cron:session): session opened for user root by (uid=0)
May 15 13:29:02 wirenboard-AARIERSM cron.info CRON[31502]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_confed.sh 2>&1 | logger -t wb-daemon-watchdogs)
May 15 13:29:07 wirenboard-AARIERSM authpriv.info CRON[31498]: pam_unix(cron:session): session closed for user root
May 15 13:30:01 wirenboard-AARIERSM authpriv.info CRON[31569]: pam_unix(cron:session): session opened for user root by (uid=0)
May 15 13:30:01 wirenboard-AARIERSM authpriv.info CRON[31570]: pam_unix(cron:session): session opened for user root by (uid=0)
May 15 13:30:01 wirenboard-AARIERSM cron.info CRON[31577]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_confed.sh 2>&1 | logger -t wb-daemon-watchdogs)
May 15 13:30:02 wirenboard-AARIERSM cron.info CRON[31578]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_wbrules.sh 2>&1 | logger -t wb-daemon-watchdogs)
May 15 13:30:04 wirenboard-AARIERSM authpriv.info CRON[31570]: pam_unix(cron:session): session closed for user root
May 15 13:30:07 wirenboard-AARIERSM authpriv.info CRON[31569]: pam_unix(cron:session): session closed for user root
May 15 13:30:29 wirenboard-AARIERSM user.notice wb-mqtt-db[554]: 2021-05-15 13:30:29.508 NOTICE: Bulk processing took 526ms
