Wb-rules segmentation violation
Добрый вечер!
Замечаю что падает wb-rules. Версия 2.11.1.
Лог
Jun 27 16:29:12 IQ930000 wb-rules[8889]: INFO: reloading file: /etc/wb-rules/61c1f5c65513ec7fdf74aa9a-__627913153__.js
Jun 27 16:29:15 IQ930000 wb-rules[8889]: panic: runtime error: invalid memory address or nil pointer dereference
Jun 27 16:29:15 IQ930000 wb-rules[8889]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x2d81c0]
Jun 27 16:29:15 IQ930000 wb-rules[8889]: goroutine 52 [running]:
Jun 27 16:29:15 IQ930000 wb-rules[8889]: github.com/wirenboard/wb-rules/wbrules.(*Rule).MaybeAddToCron.func1()
Jun 27 16:29:15 IQ930000 wb-rules[8889]:         github.com/wirenboard/wb-rules/wbrules/rule.go:324 +0x20
Jun 27 16:29:15 IQ930000 wb-rules[8889]: github.com/wirenboard/wb-rules/wbrules.(*RuleEngine).syncLoop(0x2560100)
Jun 27 16:29:15 IQ930000 wb-rules[8889]:         github.com/wirenboard/wb-rules/wbrules/engine.go:712 +0xf4
Jun 27 16:29:15 IQ930000 wb-rules[8889]: created by github.com/wirenboard/wb-rules/wbrules.(*RuleEngine).Start
Jun 27 16:29:15 IQ930000 wb-rules[8889]:         github.com/wirenboard/wb-rules/wbrules/engine.go:1241 +0x1e8
Jun 27 16:29:15 IQ930000 systemd[1]: wb-rules.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Jun 27 16:29:15 IQ930000 systemd[1]: wb-rules.service: Unit entered failed state.
Jun 27 16:29:15 IQ930000 systemd[1]: wb-rules.service: Failed with result 'exit-code'.
Jun 27 16:29:16 IQ930000 systemd[1]: wb-rules.service: Service hold-off time over, scheduling restart.
Jun 27 16:29:16 IQ930000 systemd[1]: Stopped MQTT Rule engine for Wiren Board.
Jun 27 16:29:16 IQ930000 systemd[1]: Started MQTT Rule engine for Wiren Board.
Jun 27 16:29:17 IQ930000 wb-rules[17325]: INFO: driver is created
Jun 27 16:29:17 IQ930000 wb-rules[17325]: INFO: [wbgo_mqtt] rules-IQ930000-17325: MQTT connection established
Jun 27 16:29:17 IQ930000 wb-rules[17325]: INFO: driver loop is started
Jun 27 16:29:17 IQ930000 wb-rules[17325]: INFO: wait for driver to become ready
Jun 27 16:29:28 IQ930000 wb-rules[17325]: INFO: driver is ready
Jun 27 16:29:28 IQ930000 wb-rules[17325]: INFO: [rule info] using file /var/lib/wirenboard/wbrules-persistent.db for persistent DB
Jun 27 16:29:28 IQ930000 wb-rules[17325]: INFO: [wbgo_mqtt] wb-rules-engine-IQ930000-17325: MQTT connection established
Jun 27 16:29:29 IQ930000 wb-rules[17325]: INFO: [engine] Starting main loop
Jun 27 16:29:29 IQ930000 wb-rules[17325]: INFO: the engine is ready
Jun 27 16:29:29 IQ930000 wb-rules[17325]: INFO: [engine] Starting sync loop
Jun 27 16:29:29 IQ930000 wb-rules[17325]: INFO: /usr/share/wb-rules-system/rules/buzzer.js is NOT under source root /etc/wb-rules
Jun 27 16:29:29 IQ930000 wb-rules[17325]: INFO: /usr/share/wb-rules-system/rules/hwmon.js is NOT under source root /etc/wb-rules
Jun 27 16:29:30 IQ930000 wb-rules[17325]: INFO: /usr/share/wb-rules-system/rules/network.js is NOT under source root /etc/wb-rules
Jun 27 16:29:30 IQ930000 wb-rules[17325]: INFO: /usr/share/wb-rules-system/rules/power_status.js is NOT under source root /etc/wb-rules
Jun 27 16:29:30 IQ930000 wb-rules[17325]: Device "ppp0" does not exist.
Jun 27 16:29:31 IQ930000 wb-rules[17325]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 27 16:29:31 IQ930000 wb-rules[17325]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 27 16:29:31 IQ930000 wb-rules[17325]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 27 16:29:31 IQ930000 wb-rules[17325]: sh: echo: I/O error
Так же wb-rules постоянно теряет mosquitto:
Лог 2
июн 27 17:32:08 IQ930000 wb-rules[12690]: INFO: LiveRemoveFile: /etc/wb-rules/61c1f5c65513ec7fdf74aa9a-__4073139077__.js
июн 27 17:32:24 IQ930000 wb-rules[12690]: ERROR: [wbgo_mqtt] MQTT error: publish was broken by timeout
июн 27 17:32:54 IQ930000 wb-rules[12690]: ERROR: [wbgo_mqtt] MQTT error: publish was broken by timeout
июн 27 17:33:24 IQ930000 wb-rules[12690]: ERROR: [wbgo_mqtt] MQTT error: publish was broken by timeout
июн 27 17:33:54 IQ930000 wb-rules[12690]: ERROR: [wbgo_mqtt] MQTT error: publish was broken by timeout
Добрый вечер! Спасибо, логи приняли, исправление постараемся скоро выкатить
Про потерю mosquitto интересно. Как часто воспроизводится? Есть ли возможность обновиться до 2.11.2 или новее? Там были исправления, которые могут повлиять.
Вчера mqtt терялся чуть ли не каждый час. Но я настраивал zigbee2mqtt, иногда его перезапускал. Поидее не должно быть связано, но вдруг. Перед уходом обновил wb-rules до самой свежей версии, буду сегодня наблюдать. В самих логах mosquitto ошибок не заметил.
Напишите как выйдет исправление этой баги? Хотелось бы сразу обновиться.
Да, напишем, конечно.
Собственно PR уже влит: https://github.com/wirenboard/wb-rules/pull/70 2 часа назад и скоро пакет будет доступен в testing
Только подошел к контроллеру, ничего не перезапускал и не трогал как wb-rules снова потерял MQTT. Лог прилагаю. Версия 2.11.3. Это же самая актуальная?
лог
Jun 28 14:00:52 IQ930000 wb-rules[10429]: Device "ppp0" does not exist.
Jun 28 14:00:58 IQ930000 wb-rules[10429]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 28 14:00:58 IQ930000 wb-rules[10429]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 28 14:00:58 IQ930000 wb-rules[10429]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 28 14:00:58 IQ930000 wb-rules[10429]: INFO: network/GPRS IP: failed to convert value '', passing raw
Jun 28 14:01:03 IQ930000 wb-rules[10429]: INFO: [rule info] 621cd3414b9ac24bd16e6968: incoming wrong value 0x00158d0006c5d3c7/state null
Jun 28 14:01:03 IQ930000 wb-rules[10429]: INFO: [rule info] 61c1f538065bbd7ac61290dc: Change wrong value of wb-mr6c_43/K3 false to true
Jun 28 14:01:13 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.PublishToken (&{{{{0 0} 0 0 0 0} 0x195b700 <nil>} 918})
Jun 28 14:01:23 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.PublishToken (&{{{{0 0} 0 0 0 0} 0x195b980 <nil>} 919})
Jun 28 14:01:33 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.PublishToken (&{{{{0 0} 0 0 0 0} 0x1ebe240 <nil>} 920})
Jun 28 14:01:43 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.PublishToken (&{{{{0 0} 0 0 0 0} 0x1ebe740 <nil>} 921})
Jun 28 14:01:48 IQ930000 wb-rules[10429]: Device "ppp0" does not exist.
Jun 28 14:01:53 IQ930000 wb-rules[10429]: INFO: network/GPRS IP: failed to convert value '', passing raw
Jun 28 14:01:54 IQ930000 wb-rules[10429]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 28 14:01:54 IQ930000 wb-rules[10429]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 28 14:01:54 IQ930000 wb-rules[10429]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 28 14:01:56 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad6080 <nil>} [zigbee2mqtt/0x540f57fffe896dc9] map[] 926})
Jun 28 14:02:01 IQ930000 wb-rules[10429]: INFO: [rule info] 621cd3414b9ac24bd16e6968: incoming wrong value 0x00158d0006c5d3c7/state null
Jun 28 14:02:01 IQ930000 wb-rules[10429]: INFO: [rule info] 61c1f538065bbd7ac61290dc: Change wrong value of wb-mr6c_43/K3 false to true
Jun 28 14:02:06 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad6600 <nil>} [zigbee2mqtt/0x00124b0025238768] map[] 927})
Jun 28 14:02:12 IQ930000 wb-rules[10429]: WARNING: [wbgo_mqtt] MQTT connection lost: pingresp not received, disconnecting
Jun 28 14:02:12 IQ930000 wb-rules[10429]: WARNING: [wbgo_mqtt] Cleaning up token queue
Jun 28 14:02:13 IQ930000 wb-rules[10429]: INFO: [wbgo_mqtt] wb-rules-engine-IQ930000-10429: MQTT connection established
Jun 28 14:02:16 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad6b00 <nil>} [zigbee2mqtt/0x00124b0025238924] map[] 928})
Jun 28 14:02:26 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad6f80 <nil>} [zigbee2mqtt/0x00124b0025238916] map[] 929})
Jun 28 14:02:36 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad7500 <nil>} [zigbee2mqtt/0x540f57fffe896dd1] map[] 930})
Jun 28 14:02:46 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad7940 <nil>} [zigbee2mqtt/0x00158d0006bcaaf1] map[] 931})
Jun 28 14:02:47 IQ930000 wb-rules[10429]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 28 14:02:48 IQ930000 wb-rules[10429]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 28 14:02:48 IQ930000 wb-rules[10429]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 28 14:02:48 IQ930000 wb-rules[10429]: Device "ppp0" does not exist.
Jun 28 14:02:48 IQ930000 wb-rules[10429]: INFO: network/GPRS IP: failed to convert value '', passing raw
Jun 28 14:02:56 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1ad7e00 <nil>} [zigbee2mqtt/0x00158d0006d3f512] map[] 932})
Jun 28 14:02:59 IQ930000 wb-rules[10429]: INFO: [rule info] 621cd3414b9ac24bd16e6968: incoming wrong value 0x00158d0006c5d3c7/state null
Jun 28 14:02:59 IQ930000 wb-rules[10429]: INFO: [rule info] 61c1f538065bbd7ac61290dc: Change wrong value of wb-mr6c_43/K3 false to true
Jun 28 14:03:47 IQ930000 wb-rules[10429]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 28 14:03:47 IQ930000 wb-rules[10429]: Device "ppp0" does not exist.
Jun 28 14:03:47 IQ930000 wb-rules[10429]: INFO: network/GPRS IP: failed to convert value '', passing raw
Jun 28 14:03:47 IQ930000 wb-rules[10429]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 28 14:03:47 IQ930000 wb-rules[10429]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 28 14:04:01 IQ930000 wb-rules[10429]: INFO: [rule info] 621cd3414b9ac24bd16e6968: incoming wrong value 0x00158d0006c5d3c7/state null
Jun 28 14:04:01 IQ930000 wb-rules[10429]: INFO: [rule info] 61c1f538065bbd7ac61290dc: Change wrong value of wb-mr6c_43/K3 false to true
Jun 28 14:04:11 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x19b4040 <nil>} [zigbee2mqtt/0x540f57fffe896dc9] map[] 1002})
Jun 28 14:04:21 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x19b4d00 <nil>} [zigbee2mqtt/0x00124b0025238768] map[] 1003})
Jun 28 14:04:31 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x19b5640 <nil>} [zigbee2mqtt/0x00124b0025238924] map[] 1004})
Jun 28 14:04:41 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x16da400 <nil>} [zigbee2mqtt/0x00124b0025238916] map[] 1005})
Jun 28 14:04:50 IQ930000 wb-rules[10429]: Device "ppp0" does not exist.
Jun 28 14:04:51 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x16dbb80 <nil>} [zigbee2mqtt/0x540f57fffe896dd1] map[] 1006})
Jun 28 14:04:52 IQ930000 wb-rules[10429]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 28 14:04:52 IQ930000 wb-rules[10429]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 28 14:04:52 IQ930000 wb-rules[10429]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 28 14:04:52 IQ930000 wb-rules[10429]: INFO: network/GPRS IP: failed to convert value '', passing raw
Jun 28 14:04:55 IQ930000 wb-rules[10429]: WARNING: [wbgo_mqtt] MQTT connection lost: pingresp not received, disconnecting
Jun 28 14:04:55 IQ930000 wb-rules[10429]: WARNING: [wbgo_mqtt] Cleaning up token queue
Jun 28 14:04:55 IQ930000 wb-rules[10429]: INFO: [wbgo_mqtt] wb-rules-engine-IQ930000-10429: MQTT connection established
Jun 28 14:05:01 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x161c8c0 <nil>} [zigbee2mqtt/0x00158d0006bcaaf1] map[] 1007})
Jun 28 14:05:02 IQ930000 wb-rules[10429]: INFO: [rule info] 621cd3414b9ac24bd16e6968: incoming wrong value 0x00158d0006c5d3c7/state null
Jun 28 14:05:02 IQ930000 wb-rules[10429]: INFO: [rule info] 61c1f538065bbd7ac61290dc: Change wrong value of wb-mr6c_43/K3 false to true
Jun 28 14:05:11 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x19ba440 <nil>} [zigbee2mqtt/0x00158d0006d3f512] map[] 1008})
Jun 28 14:05:21 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1924940 <nil>} [zigbee2mqtt/0x540f57fffe896dc9] map[] 1080})
Jun 28 14:05:31 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x1924c80 <nil>} [zigbee2mqtt/0x00124b0025238768] map[] 1081})
Jun 28 14:05:52 IQ930000 wb-rules[10429]: Device "ppp0" does not exist.
Jun 28 14:05:57 IQ930000 wb-rules[10429]: INFO: network/GPRS IP: failed to convert value '', passing raw
Jun 28 14:05:57 IQ930000 wb-rules[10429]: INFO: network/Ethernet IP: failed to convert value '', passing raw
Jun 28 14:05:57 IQ930000 wb-rules[10429]: INFO: network/Ethernet 2 IP: failed to convert value '', passing raw
Jun 28 14:05:57 IQ930000 wb-rules[10429]: INFO: network/Wi-Fi 2 IP: failed to convert value '', passing raw
Jun 28 14:06:32 IQ930000 wb-rules[10429]: ERROR: [wbgo_mqtt] MQTT error: publish was broken by timeout
Нет, это не самая актуальная. Нужная - wb-rules/testing 2.11.4
Обрывы MQTT исправлены именно в ней?
Там, судя по описанию - исправлены ошибки при удалении cron-объектов.
А со свежей версией пакета - тоже ловятся как вчера в логе ошибки брокера?
На 2.11.3 MQTT теряется.
До 2.11.4 еще не обновился, по поводу cron не могу сказать. Да, cron используем и довольно много.
На 2.11.4:
июн 29 14:51:31 IQ930000 systemd[1]: Stopping MQTT Rule engine for Wiren Board...
июн 29 14:51:31 IQ930000 wb-rules[10115]: ERROR: [rule error] Error in getting device: Device with given ID doesn't exist
июн 29 14:51:31 IQ930000 wb-rules[10115]: ERROR: [rule error] ECMAScript error: TypeError: invalid base value
                                                     duk_hobject_props.c:2000
                                                     anon /usr/share/wb-rules-system/rules/wb-zigbee2mqtt.js:140 preventsyield
                                                     parse  native strict preventsyield
                                                     anon /usr/share/wb-rules-system/rules/wb-zigbee2mqtt.js:150 preventsyield
июн 29 14:51:31 IQ930000 wb-rules[10115]: ERROR: command '/bin/sh -c service wb-rules restart' failed with exit status -1
июн 29 14:51:31 IQ930000 wb-rules[10115]: INFO: [engine] Stopping sync loop
июн 29 14:51:31 IQ930000 wb-rules[10115]: ERROR: [wbgo_mqtt] MQTT error: connection lost before Publish completed
июн 29 14:51:32 IQ930000 systemd[1]: Stopped MQTT Rule engine for Wiren Board.
июн 29 14:51:32 IQ930000 systemd[1]: Started MQTT Rule engine for Wiren Board.
июн 29 14:51:33 IQ930000 wb-rules[10543]: INFO: driver is created
июн 29 14:51:33 IQ930000 wb-rules[10543]: INFO: [wbgo_mqtt] rules-IQ930000-10543: MQTT connection established
июн 29 14:51:33 IQ930000 wb-rules[10543]: INFO: driver loop is started
июн 29 14:51:33 IQ930000 wb-rules[10543]: INFO: wait for driver to become ready
июн 29 14:51:43 IQ930000 wb-rules[10543]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x219ce80 <nil>} [/devices/+/controls/+] map[] 8})
июн 29 14:51:54 IQ930000 wb-rules[10543]: INFO: driver is ready
июн 29 14:51:54 IQ930000 wb-rules[10543]: INFO: [rule info] using file /var/lib/wirenboard/wbrules-persistent.db for persistent DB
июн 29 14:51:54 IQ930000 wb-rules[10543]: INFO: [wbgo_mqtt] wb-rules-engine-IQ930000-10543: MQTT connection established
июн 29 14:51:55 IQ930000 wb-rules[10543]: INFO: [engine] Starting main loop
июн 29 14:51:55 IQ930000 wb-rules[10543]: INFO: the engine is ready
июн 29 14:51:55 IQ930000 wb-rules[10543]: INFO: [engine] Starting sync loop
июн 29 14:51:55 IQ930000 wb-rules[10543]: INFO: /usr/share/wb-rules-system/rules/buzzer.js is NOT under source root /etc/wb-rules
А persistens storage для mosquitto отключен?
И покажите логи mosquitto? Нет ли чего-то в моменты возникновения ошибок?
Отключен. Включение может привести к печальным последствиям:
Ага, просто уточнил. Так и логи самого брокера - покажите тоже пожалуйста. Ну и насколько загружен CPU, если есть информация.
Момент потери связи wb-rules с MQTT
июн 29 15:28:37 IQ930000 wb-rules[31438]: INFO: wb-adc/Vin: failed to convert value '17.55', passing raw
июн 29 15:28:37 IQ930000 wb-rules[31438]: INFO: wb-map12e_12/Ch 1 RP energy L1: failed to convert value '0.19976', passing raw
июн 29 15:28:37 IQ930000 wb-rules[31438]: INFO: wb-msw-v3_182/ROM19 size: failed to convert value '', passing raw
июн 29 15:28:37 IQ930000 wb-rules[31438]: INFO: wb-map12e_12/Ch 1 P L1: failed to convert value '-94.48', passing raw
июн 29 15:28:37 IQ930000 wb-rules[31438]: WARNING: [wbgo_mqtt] MQTT connection lost: pingresp not received, disconnecting
июн 29 15:28:37 IQ930000 wb-rules[31438]: WARNING: [wbgo_mqtt] Cleaning up token queue
июн 29 15:28:43 IQ930000 wb-rules[31438]: WARNING: [wbgo_mqtt] MQTT connection lost: pingresp not received, disconnecting
июн 29 15:28:43 IQ930000 wb-rules[31438]: WARNING: [wbgo_mqtt] Cleaning up token queue
июн 29 15:28:43 IQ930000 wb-rules[31438]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.PublishToken (&{{{{0 0} 0 0 0 0} 0x200ee40 <nil>} 54})
июн 29 15:28:47 IQ930000 wb-rules[31438]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.PublishToken (&{{{{0 0} 0 0 0 0} 0x2045ec0 <nil>} 1238})
июн 29 15:28:57 IQ930000 wb-rules[31438]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x20f4500 <nil>} [/devices/0x540f57fffe896dd1/controls/energy/on] map[] 1239})
июн 29 15:29:03 IQ930000 wb-rules[31438]: INFO: [wbgo_mqtt] rules-IQ930000-31438: MQTT connection established
июн 29 15:29:03 IQ930000 wb-rules[31438]: INFO: wb-map12e_12/Ch 1 P L2: failed to convert value '94.44', passing raw
июн 29 15:29:03 IQ930000 wb-rules[31438]: INFO: [wbgo_mqtt] wb-rules-engine-IQ930000-31438: MQTT connection established
июн 29 15:29:07 IQ930000 wb-rules[31438]: INFO: [rule info] 62b42e4e6a1c117c042b80d0 Server timestamp unknown. Attempt 1
mosquitto.txt (1.2 МБ)
А для проверки, если отключить бриджи - ошибки пропадают?
Возможно с нашей стороны ошибка, как выясню, напишу.
Здравствуйте! Получилось ли решить проблему?
Да, на ветке testing больше проблем не возникало. Перезапуски wb-rules были связны с нашим вочдогом, который был не правильно настроен для этого конкретного контроллера.
Очень ждем исправлений в stable.
